I run a couple test with the PPK2 on our board to measure and optimize the power consumption, but I had some weird results and I'm hopping you can help me out to understand the behavior. Our custom board is a BC40C module from Fanstel (nRF5340 with the DC/DC and crystals components), and a WM02C From Fanstel (nRF7002), with a flash memory and an IMU.
So to sum things up, I have a debut build with uart0 and logs enabled, and a production build with uart0 and log disabled, plus that overlay:
CONFIG_SERIAL=y CONFIG_UART_NRFX=y CONFIG_LOG=n CONFIG_PRINTK=n CONFIG_CONSOLE=n CONFIG_EARLY_CONSOLE=n CONFIG_CONSOLE_SUBSYS=n CONFIG_UART_CONSOLE=n CONFIG_BOOT_BANNER=n CONFIG_PM_DEVICE=y CONFIG_PM_DEVICE_RUNTIME=y CONFIG_NRF_WIFI_LOW_POWER=y CONFIG_INIT_STACKS=n CONFIG_NRF_APPROTECT_LOCK=n CONFIG_BOARD_ENABLE_DCDC_APP=y CONFIG_BOARD_ENABLE_DCDC_NET=y CONFIG_BOARD_ENABLE_DCDC_HV=y
However, I have a lower power consumption wih the debug build then with the prod build. Furthermore, when I put the device into power off (with sys_poweroff()), I have a quite high power consumption too, see images below.
Debug build
Prod build
System Off (prod build)
I followed the recommandation in the documentations and the blog post here, but I still have those results, and I'm currently running out of ideas...
Any solutions? I'm joining the dts and .config files from each build here if you want to take a look, but they are pretty much the same except the differences for the logs.
Michael
