nrf5340 bootloader
I am a bit stuck with configuring nrf5340 project to include the bootloader properly.
The SDK-toolchain I use is v3.0.2
What I need:
encrypted and signed update image. At least for the application core, as the network core FW comes from a library anyway, and it is freely available to anybody.
Currently, I am in a stage, following various examples, where I can generate the required images. Encrypted and signed for the app core, signed image for network core.
But the thing I want to change is to use a non-simultaneous update for the cores. That is because I do not want to use an additional partition for the network core update; there is no external flash included in the project, and there will not be one. I want to use only two partitions: primary, where the active application is running, and secondary, which is used for either network core update or for the application core update. I.e., I want to get rid of the mcuboot_secondary_1 256KB partition and free it for either settings or extend the other two partitions.
I do not have static partitioning yet, just plan to create one after I get the project correctly configured.
Some extra information: I need the firmware update functionality only in mcuboot, over the USB-CDC. The application will use retained memory to fall back into the bootloader if necessary. This one is working fine. FW update over BT should not be there.
Is there a ready-made example for nrf5340 to have that kind of functionality? Updating both cores from mcuboot, not app, and using only two partitions for that?
Current prj.conf
CONFIG_PRINTK=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_GPIO=y
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_LB"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
CONFIG_RETAINED_MEM=y
CONFIG_RETENTION=y
CONFIG_RETAINED_MEM_ZEPHYR_RAM=y
CONFIG_RETENTION_BOOT_MODE=y
CONFIG_REBOOT=y
sysbuild.conf
# https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/migration/migration_sysbuild.html
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=y
SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=2
SB_CONFIG_SECURE_BOOT_NETCORE=y
SB_CONFIG_NETCORE_APP_UPDATE=y
# DFU zip package will include un-encrypted images
SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD=n
#SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_APP=y
#SB_CONFIG_DFU_MULTI_IMAGE_PACKAGE_NET=y
SB_CONFIG_BOOT_ENCRYPTION=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="${APPLICATION_CONFIG_DIR}/keys/mcuboot_priv.pem"
SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="${APPLICATION_CONFIG_DIR}/keys/mcuboot_priv.pem"
SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="${APPLICATION_CONFIG_DIR}/keys/mcuboot_priv.pem"
nrf5340dk_nrf5340_cpuapp.conf for mcuboot
# Configure MCUboot features
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_MCUBOOT_DOWNGRADE_PREVENTION=y
CONFIG_BOOT_ECDSA_TINYCRYPT=y
# Enable flash simulator
CONFIG_PCD_APP=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
# CONFIG_NORDIC_QSPI_NOR=y
# CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
# CONFIG_BOOT_IMAGE_ACCESS_HOOK_NRF5340=y
CONFIG_MULTITHREADING=y
nrf5340dk_nrf5340_cpuapp.overlay
  aliases {
		mcuboot-button0 = &button3;
		mcuboot-led0 = &led3;
    chosen {
        zephyr,uart-mcumgr = &usbd;
        zephyr,console = &uart0;    };
&zephyr_udc0 {
		cdc_acm_uart0: cdc_acm_uart0 {
		compatible = "zephyr,cdc-acm-uart";
        sram@2007FFFF {
                compatible = "zephyr,memory-region", "mmio-sram";
                reg = <0x2007FFFF 0x1>;
                zephyr,memory-region = "RetainedMem";
                status = "okay";
                retainedmem {
                        compatible = "zephyr,retained-ram";
                        status = "okay";
                        #address-cells = <1>;
                        #size-cells = <1>;
                        retention0: retention@0 {
                                compatible = "zephyr,retention";
                                status = "okay";
                                reg = <0x0 0x1>;
        chosen {
                zephyr,boot-mode = &retention0;
/* Reduce SRAM0 usage by 1 byte to account for non-init area */
&sram0 {
        reg = <0x20000000 0x7FFFF>;
prj.conf for mcuboot:
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x20000
CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
CONFIG_BOOT_ENCRYPT_IMAGE=n
CONFIG_BOOT_UPGRADE_ONLY=y
CONFIG_BOOT_BOOTSTRAP=n
CONFIG_UART_CONSOLE=y
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_CDC_ACM=y
CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
CONFIG_BOOT_SERIAL_PIN_RESET=n
CONFIG_BOOT_SERIAL_NO_APPLICATION=y
CONFIG_MCUBOOT_INDICATION_LED=y
# Use Retention system
CONFIG_RETENTION=y
CONFIG_BOOT_SERIAL_BOOT_MODE=y
### mbedTLS has its own heap
# CONFIG_HEAP_MEM_POOL_SIZE is not set
### We never want Zephyr's copy of tinycrypt.  If tinycrypt is needed,
### MCUboot has its own copy in tree.
# CONFIG_TINYCRYPT is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
# CONFIG_TINYCRYPT_SHA256 is not set
CONFIG_FLASH=y
CONFIG_FPROTECT=y
### Various Zephyr boards enable features that we don't want.
# CONFIG_BT is not set
# CONFIG_BT_CTLR is not set
# CONFIG_I2C is not set
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
### Ensure Zephyr logging changes don't use more resources
CONFIG_LOG_DEFAULT_LEVEL=0
### Use info log level by default
CONFIG_MCUBOOT_LOG_LEVEL_INF=y
### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
CONFIG_CBPRINTF_NANO=y
### Use the minimal C library to reduce flash usage
CONFIG_MINIMAL_LIBC=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
# NCS boot banner
CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="MCUboot"
# CONFIG_MCUMGR=y
# CONFIG_NET_BUF=y
# # CONFIG_ZCBOR=y
# CONFIG_CRC=y
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
# CONFIG_MCUMGR_GRP_IMG=y
# CONFIG_MCUMGR_GRP_OS=y
# CONFIG_SIZE_OPTIMIZATIONS=y
CONFIG_BOOT_SERIAL_IMG_GRP_HASH=y
# CONFIG_ENABLE_MGMT_PERUSER=y
# CONFIG_BOOT_MGMT_CUSTOM_STORAGE_ERASE=y
CONFIG_BOOT_SERIAL_IMG_GRP_IMAGE_STATE=y
CONFIG_BOOT_SERIAL_IMG_GRP_SLOT_INFO=y
CONFIG_PCD_APP=y
The above settings seem to be fine otherwise, but create three partitions in total, mcuboot_primary, mcuboot_secondary, and mcuboot_secondary_1. That last one I need to remove.
There is no use for the secondary_1 partition anyway; mcumgr updates the images one by one.
BR, Madis
    Thank you for the hint. It is an elegant solution. Now I have only two partitions and can update both of the cores using the second flash partition.
    There is still something that needs improvement, and I need to address it somehow.
    Currently, both images are written directly to the target slot after I upload the image using mcumgr, which is ok.
    But the problem is that if I write netcore image without using "-n 3" to indicate that the image is supposed to be for the netcore, the image gets written to the application image memory directly, mcuboot_primary.
    So there is no "swap/test" functionality in the bootloader. And that can potentially brick the product; if it is possible to brick it, it will happen sooner or later.
    So, is it possible to use configuration to force the mcuboot to verify the image before writing it to the final target partition, netcore or appcore main flash partition 1?
    The verification seems to be fine for netcore, if I upload zephyr.signed.encrypted.bin image using -n 3, the b0n reports that it was unable to find a valid fw.
    In short: updating netcore with the wrong image gets rejected. But updating application core with netcore image is possible, image is directly written without any test/swap or something similar. And this is something I need to fix.
    I tried playing with "CONFIG_MCUMGR=y" and its dependencies, but the build fails because of nrf53 hooks get multiple definitions.
    BR, Madis
  • In serial recovery mode (dfu within the bootloader), you have the option to upload the image directly to the primary slot which removes the possibility to do any pre-validation. But you can always enter serial recovery mode again an reupload the correct image.
    Vidar
  • Thank you for your comments.
    If the bootloader is configured to stay in recovery mode only when there is no application, or via the retention system, the bootloader will boot the image from the primary partition if one is there. Although if the image is wrong and was originally intended for the network core.
    Now the application crashes, naturally, and the same process repeats. So there is no way to enter the bootloader, and the device is bricked. As there is no application running capable of entering the bootloader, and bootloader thinks that there is a valid image and boots it. This can happen.
    If I use mcumgr image upload -n2, the application image is written to the secondary partition and swapped upon reboot, if requested by "test" or "confirm",
    If I then write netcore image with -n2, the image is correctly identified to be for the netcore and updated to there. Although there are few things:-) But bricking the device is not foreseen.
    Using -n3 for netcore is the correct one, and writing the image works perfectly. Wrong image gets rejected etc.
    So, the bootloader is capable of doing a swapping kind of update for the application image. The only thing I need is to disable the direct write to the primary partition.
    Can you hint some configuration options for that, if possible?
    BR, Madis
    Ideally there should be a fallback method to enter serial mode if the updated app is not functional. For example, you can enable BOOT_SERIAL_WAIT_FOR_DFU to make the bootloader always enter serial recovery mode for a specified duration on startup.
    I do not see any existing Kconfig config settings for serial recovery mode that can be applied to achieve this, so it seems like thus would require you to patch the mcuboot code.
