- nRF connection Desktop v5.2.0
- Toolchain Manager v1.6.0
- Visual studio cade v2.9.2
- Windows 11 pro Platform
Hi Marte,
As you advised, we made the same changes in the script, but when we tried to flash, it failed with an error. Please find the attached logs for your reference.
FAILED: CMakeFiles/app.dir/src/main.c.obj
C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=213024 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=\"nrf-psa-crypto-user-config.h\" -DNRF52_ERRATA_215_ENABLE_WORKAROUND=0 -DNRF5340_XXAA_APPLICATION -DNRF53_ERRATA_159_ENABLE_WORKAROUND=0 -DNRF53_ERRATA_43_ENABLE_WORKAROUND=0 -DNRF70_ANT_GAIN_2G=0 -DNRF70_ANT_GAIN_5G_BAND1=0 -DNRF70_ANT_GAIN_5G_BAND2=0 -DNRF70_ANT_GAIN_5G_BAND3=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_DSSS=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_2G_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_DSSS=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_2G_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HT=0 -DNRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HE=0 -DNRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HT=0 -DNRF70_DATA_TX -DNRF70_LOG_VERBOSE -DNRF70_MAX_TX_PENDING_QLEN=18 -DNRF70_MAX_TX_TOKENS=10 -DNRF70_PCB_LOSS_2G=0 -DNRF70_PCB_LOSS_5G_BAND1=0 -DNRF70_PCB_LOSS_5G_BAND2=0 -DNRF70_PCB_LOSS_5G_BAND3=0 -DNRF70_REG_DOMAIN=00 -DNRF70_RPU_PS_IDLE_TIMEOUT_MS=10 -DNRF70_RX_MAX_DATA_SIZE=1600 -DNRF70_RX_NUM_BUFS=48 -DNRF70_STA_MODE -DNRF70_SYSTEM_MODE -DNRF70_TCP_IP_CHECKSUM_OFFLOAD -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_WIFI_AP_DEAD_DETECT_TIMEOUT=20 -DNRF_WIFI_IFACE_MTU=1500 -DNRF_WIFI_LOW_POWER -DNRF_WIFI_MGMT_BUFF_OFFLOAD -DNRF_WIFI_PS_INT_PS=y -DNRF_WIFI_RPU_RECOVERY -DNRF_WIFI_RPU_RECOVERY_PS_ACTIVE_TIMEOUT_MS=50000 -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.9.2/zephyr/subsys/net/ip -IC:/ncs/v2.9.2/nrf/samples/wifi/twt/modules/traffic_gen/inc -IC:/ncs/v2.9.2/nrf/samples/wifi/twt/build/twt/zephyr/include/generated/zephyr -IC:/ncs/v2.9.2/zephyr/include -IC:/ncs/v2.9.2/nrf/samples/wifi/twt/build/twt/zephyr/include/generated -IC:/ncs/v2.9.2/zephyr/soc/nordic -IC:/ncs/v2.9.2/zephyr/include/zephyr/posix -IC:/ncs/v2.9.2/zephyr/soc/nordic/nrf53/. -IC:/ncs/v2.9.2/zephyr/soc/nordic/common/. -IC:/ncs/v2.9.2/zephyr/subsys/net/l2 -IC:/ncs/v2.9.2/zephyr/drivers/wifi/nrf_wifi/inc -IC:/ncs/v2.9.2/nrf/include -IC:/ncs/v2.9.2/nrf/samples/wifi/twt/build/twt/zephyr/misc/generated -IC:/ncs/v2.9.2/modules/lib/hostap/port/mbedtls -IC:/ncs/v2.9.2/nrf/tests/include -IC:/ncs/v2.9.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.9.2/zephyr/modules/cmsis/. -IC:/ncs/v2.9.2/modules/hal/nordic/nrfx -IC:/ncs/v2.9.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.9.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.9.2/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.9.2/zephyr/modules/hostap/src -IC:/ncs/v2.9.2/modules/lib/hostap -IC:/ncs/v2.9.2/modules/lib/hostap/wpa_supplicant -IC:/ncs/v2.9.2/modules/lib/hostap/src -IC:/ncs/v2.9.2/modules/lib/hostap/src/common -IC:/ncs/v2.9.2/modules/lib/hostap/src/eap_common -IC:/ncs/v2.9.2/modules/lib/hostap/src/eap_server -IC:/ncs/v2.9.2/modules/lib/hostap/src/radius -IC:/ncs/v2.9.2/modules/lib/hostap/src/crypto -IC:/ncs/v2.9.2/modules/lib/hostap/src/ap -IC:/ncs/v2.9.2/modules/lib/hostap/src/drivers -IC:/ncs/v2.9.2/modules/lib/hostap/src/rsn_supp -IC:/ncs/v2.9.2/nrf/samples/wifi/twt/build/twt/generated/library_nrf_security_psa -IC:/ncs/v2.9.2/nrf/subsys/nrf_security/include -IC:/ncs/v2.9.2/nrf/subsys/nrf_security/src/threading/include -IC:/ncs/v2.9.2/nrf/subsys/nrf_security/src/utils -IC:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto/oberon/drivers -IC:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto/include -IC:/ncs/v2.9.2/modules/crypto/oberon-psa-crypto/library -IC:/ncs/v2.9.2/modules/crypto/mbedtls/library -IC:/ncs/v2.9.2/modules/crypto/mbedtls/include -IC:/ncs/v2.9.2/modules/crypto/mbedtls/include/library -IC:/ncs/v2.9.2/nrfxlib/crypto/nrf_oberon/include -IC:/ncs/v2.9.2/nrfxlib/crypto/nrf_oberon/include/mbedtls -IC:/ncs/v2.9.2/zephyr/modules/nrf_wifi/os -IC:/ncs/v2.9.2/zephyr/modules/nrf_wifi/os/../bus -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/utils/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/os_if/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/bus_if/bus/qspi/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/bus_if/bal/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/fw_if/umac_if/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/fw_load/mips/fw/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/hw_if/hal/inc -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/hw_if/hal/inc/fw -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/fw_if/umac_if/inc/fw -IC:/ncs/v2.9.2/modules/lib/nrf_wifi/fw_if/umac_if/inc/default -isystem C:/ncs/v2.9.2/zephyr/lib/libc/common/include -isystem C:/ncs/v2.9.2/nrfxlib/crypto/nrf_cc312_platform/include -Os -DNDEBUG -fno-strict-aliasing -Os -imacros C:/ncs/v2.9.2/nrf/samples/wifi/twt/build/twt/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.9.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.9.2/nrf/samples/wifi/twt=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.9.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.9.2=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c C:/ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c
C:/ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c: In function 'main':
C:/ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c:426:25: warning: implicit declaration of function 'traffic_gen_init'; did you mean 'traffic_gen_stop'? [-Wimplicit-function-declaration]
426 | traffic_gen_init(&tg_config);
| traffic_gen_stop
C:/ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c:428:29: error: void value not ignored as it ought to be
428 | ret = traffic_gen_start(&tg_config);
C:/ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c:434:31: warning: implicit declaration of function 'traffic_gen_wait_for_report' [-Wimplicit-function-declaration]
434 | ret = traffic_gen_wait_for_report(&tg_config);
C:/ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c:439:25: warning: implicit declaration of function 'traffic_gen_get_report'; did you mean 'traffic_gen_start'? [-Wimplicit-function-declaration]
439 | traffic_gen_get_report(&tg_config);
| traffic_gen_start
[244/457] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/tcp.c.obj
FAILED: _sysbuild/sysbuild/images/twt-prefix/src/twt-stamp/twt-build C:/ncs/v2.9.2/nrf/samples/wifi/twt/build/_sysbuild/sysbuild/images/twt-prefix/src/twt-stamp/twt-build
cmd.exe /C "cd /D C:\ncs\v2.9.2\nrf\samples\wifi\twt\build\twt && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe --build ."
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/ncs/v2.9.2/nrf/samples/wifi/twt/build
Thanks & Regards,
Naveen P
Hi Mate,
As per your advice, we made the same changes in the script, and the flash build completed successfully. However, we are still not seeing the expected logs. After enabling TWT power save, the client only sends PS-Poll frames.
The following command was used:
https://drive.google.com/file/d/1H2-U1TbJMtUYYoJxIF3my1jbIpdYBWpn/view?usp=sharing
Thanks & Regards,
Naveen P
Hi Marte,
Please respond. We are waiting for your reply.
Hi Merta,
Any updates on this?
Hi Merta,
I tried with another AP as well, but we are still facing the same issue I mentioned earlier.
uart:~$ wifi status
Status: successful
State: COMPLETED
Interface Mode: STATION
Link Mode: WIFI 6 (802.11ax/HE)
SSID: TWT
BSSID: 00:33:58:6B:81:82
Band: 2.4GHz
Channel: 1
Security: WPA2-PSK
MFP: Optional
RSSI: -40
Beacon Interval: 100
DTIM: 1
TWT: Supported
Current PHY rate : 1000
uart:~$ wifi twt setup 0 0 1 0 0 0 1 1 10000 1000000 100
TWT operation TWT setup with dg: 1, flow_id: 0 requested
TWT response: TWT accept
== TWT negotiated parameters ==
TWT Dialog token: 1
TWT flow ID: 1
TWT negotiation type: TWT individual negotiation
TWT responder: true
TWT implicit: true
TWT announce: true
TWT trigger: false
TWT wake interval: 9984 us
TWT interval: 1000000 us
Thanks & Regards,
Naveen P
