NRF5340 Network Core USB DFU with dfu-util
We are using NRF5340 and interface with a host system via USB. As the USB stack supports the DFU device class, we plan to use that for firmware updates, and use dfu-util on the host side. We want to implement the update in the bootloader to remove the requirement for external flash for the second firmware slot.
Is this supported at all?
I have seen a similar issue, but that discusses the possibility of simultaneous update and does not show how the network image can be downloaded: devzone.nordicsemi.com/.../use-dfu-util-to-perform-multi-image-dfu-from-application
Downloading works well with the application image, using the following command line:
dfu-util -d 1915:b171 -e
dfu-util -d 1915:b172 -D app_image.bin
However, I have not succeeded in updating the network core by issuing the following command:
dfu-util -d 1915:b172 -D net_image.bin
The configuration we use:
sysbuild.conf
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_MCUBOOT_MODE_SINGLE_APP=y
# Make the net core image updatable and signed
SB_CONFIG_SECURE_BOOT_NETCORE=y
SB_CONFIG_NETCORE_APP_UPDATE=y
prj.conf for MCUBOOT
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_SINGLE_APPLICATION_SLOT=y
CONFIG_FLASH=y
CONFIG_BOOT_USB_DFU_WAIT=y
CONFIG_BOOT_USB_DFU_WAIT_DELAY_MS=60000
CONFIG_USB_DFU_WILL_DETACH=y
CONFIG_USB_DFU_ENABLE_UPLOAD=n
CONFIG_USB_DFU_REBOOT=n
CONFIG_BOOT_USB_DFU_NO_APPLICATION=y
# PID and VID are the same as in application
CONFIG_USB_DEVICE_PID=0xb171
CONFIG_USB_DEVICE_VID=0x1915
# PID in DFU mode is one higher than during normal operation
CONFIG_USB_DEVICE_DFU_PID=0Xb172
pm_static.yml
app:
  address: 0x20200
  region: flash_primary
mcuboot:
  address: 0x0
mcuboot_pad:
  address: 0x20000
mcuboot_primary:
  address: 0x20000
  orig_span: &id001
  - mcuboot_pad
  - app
  span: *id001
mcuboot_primary_app:
  address: 0x20200
  orig_span: &id002
  - app
  span: *id002
settings_storage:
  address: 0xf0000
mcuboot_primary_1:
  address: 0x0
  device: flash_ctrl
  region: ram_flash
