Partition manager and FOTA
I have a nrf52833 with MCUBoot and BLE, I am using NCS v3.0.1.
I need also a custom NVS partition to store user data, so i create a data_partition for this purpose.
Now to the fun part, i am having trouble with the partition manager when i'm using FOTA. My project works fine but when i wanted to add FOTA, i got an flash error everytime i try an update. After digging a bit, i understand that is a write error in the smcuboot_secondary partition.
The mcuboot_secondary partition start at address 0x41800 and don't respect the 0x1000 page size of the nrf52833 which explain why i couldn't update (cf pm_static.yml.working)
app:
  address: 0x7200
  end_address: 0x41800
  region: flash_primary
data_storage:
  address: 0x7c000
  end_address: 0x7e000
  placement:
    align:
      start: 0x1000
mcuboot:
  address: 0x0
  end_address: 0x7000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x7000
  end_address: 0x7200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x7000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x7200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x41800
  end_address: 0x7c000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0x7e000
  end_address: 0x80000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20020000
  region: sram_primary
I edit the file to place it at 0x41000 and decrease the image size (cf pm_static.yml.not_working)
EMPTY_0:
  address: 0x7b000
app:
  address: 0x7200
  end_address: 0x41000
data_storage:
  address: 0x7c000
mcuboot:
  address: 0x0
  end_address: 0x7000
mcuboot_pad:
  address: 0x7000
  end_address: 0x7200
mcuboot_primary:
  address: 0x7000
  orig_span: &id001
  - app
  - mcuboot_pad
  span: *id001
  address: 0x7200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x41000
  end_address: 0x7b000
settings_storage:
  address: 0x7e000
sram_primary:
  address: 0x20000000
But it don't boot anymore, i can't get anything on RTT or serial or anything that make me believe the bootloader successfully start the image.
Do you know what is happening ?
Nathan
  • Hello Nathan,
    Just to confirm, this start address was set automatically in your build, and not by you? I'm also surprised it didn't adhere to the flash page aligment requirement.
    Please try the following:
    - delete the build folder
    - make a backup of your pm static file, then create a new one that only defines the settings_storage and data_storage partition. This allows the PM to dynamically create the rest.
    - Try DFU again.
    Vidar
  • Hi Vidar,
    I did let the partition manager do it's job and then copy the content of partitions.yml to my pm_static.yml
    Following your instructions, i only define settings_storage and data_storage in my pm_static.yml like this :
    settings_storage:
      placement:
        before:
        - end
    data_storage:
      placement:
        before:
        - settings_storage
    And i got this build error :
    (.venv) C:\Workspace\001_CAPTAIN_BLINK\blinker\blinker.git>west build -p -b board_blinker app --sysbuild
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/Workspace/.venv/Scripts/python.exe (found suitable version "3.13.7", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/.cache
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: board_blinker, qualifiers: nrf52833
    Parsing C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/_sysbuild/empty.conf'
    Merged configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/sysbuild.conf'
    Configuration saved to 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/zephyr/.config'
    Kconfig header saved to 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/Workspace/001_CAPTAIN_BLINK/blinker/bootloader/mcuboot/boot/zephyr
    -- CMake version: 4.1.0
    -- Zephyr version: 4.0.99 (C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr)
    -- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
    -- Found host-tools: zephyr 0.17.0 (C:/Users/natha/zephyr-sdk-0.17.0)
    -- Found toolchain: zephyr 0.17.0 (C:/Users/natha/zephyr-sdk-0.17.0)
    -- Found Dtc: C:/Users/natha/AppData/Local/Microsoft/WinGet/Packages/oss-winget.dtc_Microsoft.Winget.Source_8wekyb3d8bbwe/usr/bin/dtc.exe (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/boards/captain/board_blinker_nrf52833.dts
    -- Found devicetree overlay: C:/Workspace/001_CAPTAIN_BLINK/blinker/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/dts.cmake
    CMake Warning at C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/cmake/modules/dts.cmake:428 (message):
      dtc raised one or more warnings:
      C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/zephyr.dts:56.25-61.5:
      Warning (unique_unit_address_if_enabled): /soc/clock@40000000: duplicate
      unit-address (also used in node /soc/power@40000000)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/zephyr.dts:361.21-365.5:
      Warning (unique_unit_address_if_enabled): /soc/acl@4001e000: duplicate
      unit-address (also used in node /soc/flash-controller@4001e000)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:18 (find_package)
    warning: Deprecated symbol DEPRECATED_UART_NRFX_UARTE_LEGACY_SHIM is enabled.
    Parsing C:/Workspace/001_CAPTAIN_BLINK/blinker/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/boards/captain/board_blinker_nrf52833_defconfig'
    Merged configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/sysbuild/mcuboot.conf'
    Merged configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/users/natha/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/Users/natha/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Warning at C:/Workspace/001_CAPTAIN_BLINK/blinker/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
            --- WARNING: To maintain the integrity of secure boot, ---
            --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
    MCUBoot bootloader key file: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/../keys/private_key.pem
    -- Configuring done (9.2s)
    -- Generating done (0.6s)
    -- Build files have been written to: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot
       * Running CMake for app *
    -- Application: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app
    -- Generated zephyr.dts: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/dts.cmake
      C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/zephyr.dts:55.25-60.5:
      C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/zephyr.dts:360.21-364.5:
      CMakeLists.txt:8 (find_package)
    warning: Experimental symbol UART_BT is enabled.
    Parsing C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/Kconfig
    Merged configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/prj.conf'
    Merged configuration 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/.config'
    Kconfig header saved to 'C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Including signing script: C:/Workspace/001_CAPTAIN_BLINK/blinker/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done (9.8s)
    -- Generating done (0.9s)
    -- Build files have been written to: C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app
    -- Found partition manager static configuration : C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/pm_static.yml
    Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
      File "C:\Workspace\001_CAPTAIN_BLINK\blinker\nrf\scripts\partition_manager.py", line 1054, in <module>
        main()
      File "C:\Workspace\001_CAPTAIN_BLINK\blinker\nrf\scripts\partition_manager.py", line 1034, in main
        solution.update(solve_region(pm_config, region, region_config,
                                     static_config, regions))
      File "C:\Workspace\001_CAPTAIN_BLINK\blinker\nrf\scripts\partition_manager.py", line 977, in solve_region
        get_region_config(partitions, region_config, static_partitions, system_reqs=pm_config)
      File "C:\Workspace\001_CAPTAIN_BLINK\blinker\nrf\scripts\partition_manager.py", line 764, in get_region_config
        solve_complex_region(pm_config, start, size, placement_strategy, region_name, device, static_conf, dp, system_reqs)
      File "C:\Workspace\001_CAPTAIN_BLINK\blinker\nrf\scripts\partition_manager.py", line 861, in solve_complex_region
        get_dynamic_area_start_and_size(static_conf, start, size, dp)
      File "C:\Workspace\001_CAPTAIN_BLINK\blinker\nrf\scripts\partition_manager.py", line 708, in get_dynamic_area_start_and_size
        starts = {last_address} | {config['address']
    KeyError: 'address'
    CMake Error at C:/Workspace/001_CAPTAIN_BLINK/blinker/nrf/cmake/sysbuild/partition_manager.cmake:181 (message):
      Partition Manager failed, aborting.  Command:
      C:/Workspace/.venv/Scripts/python.exe;C:/Workspace/001_CAPTAIN_BLINK/blinker/nrf/scripts/partition_manager.py;--input-files;C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/modules/nrf/subsys/partition_manager/pm.yml.settings;C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/mcuboot/zephyr/include/generated/pm.yml;C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/app/zephyr/include/generated/pm.yml;--regions;sram_primary;flash_primary;--output-partitions;C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/partitions.yml;--output-regions;C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/build/regions.yml;--static-config;C:/Workspace/001_CAPTAIN_BLINK/blinker/blinker.git/app/pm_static.yml;--sram_primary-size;0x20000;--sram_primary-base-address;0x20000000;--sram_primary-placement-strategy;complex;--sram_primary-dynamic-partition;sram_primary;--flash_primary-size;0x80000;--flash_primary-base-address;0x0;--flash_primary-placement-strategy;complex;--flash_primary-device;flash_controller;--flash_primary-default-driver-kconfig;CONFIG_SOC_FLASH_NRF
      C:/Workspace/001_CAPTAIN_BLINK/blinker/nrf/cmake/sysbuild/partition_manager.cmake:620 (partition_manager)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/nrf/sysbuild/CMakeLists.txt:779 (include)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/Workspace/001_CAPTAIN_BLINK/blinker/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    FATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' -DWEST_PYTHON=C:/Workspace/.venv/Scripts/python.exe '-BC:\Workspace\001_CAPTAIN_BLINK\blinker\blinker.git\build' -GNinja -DBOARD=board_blinker '-SC:\Workspace\001_CAPTAIN_BLINK\blinker\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\Workspace\001_CAPTAIN_BLINK\blinker\blinker.git\app'
  • Since these are static partitions you must specify the 'address' for each partition.
  • pm_static.yml
    data_storage:
      address: 0x7c000
    settings_storage:
      address: 0x7e000
    partitions.yml from build
    EMPTY_0:
      address: 0x7b000
      placement:
        after:
        - mcuboot_secondary
    app:
      address: 0x7200
    data_storage:
      address: 0x7c000
    mcuboot:
      address: 0x0
      end_address: 0x7000
      placement:
        align:
          end: 0x1000
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x7000
      end_address: 0x7200
      placement:
        align:
          start: 0x1000
        before:
    mcuboot_primary:
      address: 0x7000
      orig_span: &id001
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id001
      address: 0x7200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x41000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
        align_next: 0x1000
      share_size:
      - mcuboot_primary
    settings_storage:
      address: 0x7e000
    sram_primary:
      address: 0x20000000
    Look correct but same issue the firmware don't seem to start.
  • I don't see anything wrong with the memory layout now. Do you have logging over UART available on this board? If not, can you try to attach the debugger to see where it the bootloader it hangs?
