How to automate the entrance in bootloader mode on nRF52840 USB dongle?
Dear DEVZONE,
We are working on Nordic nRF58480 USB dongle for Thread activities.
We are using one testbench on which we need to automate with Python scripts reprogramming of the USB dongle with a new firmware.
To this end, we need to reflash the USB dongle; but nRF52480 requires a pression on a small button to enter into bootloader mode, and this is incompatible with automation.
We may find an HW fix to solve this limitation but we are rather wondering whether you have another solution you could propose?
We found a DFU trigger library (USB) thread but we did not succeed in exploiting it.
nRF5 SDK v17.0.2: DFU Trigger Library (USB)
Similarly, we found this document specifying the Device Firmware Upgrade over USB.
DFU_1.1.doc
Could you please support or advise us?
Warm regards
Cedric
  • Hi Tom,
    This will make it much more difficult to do anything here as your application most likely doesn't have any feature to toggle the correct GPIO to reset.
    Can you give us some more information about your set up ? How many dongle are you running ?
    The most obvious option is to connect Jlink to the dongle and reflash the bootloader to a new one. We can add a delay for DFU there and then you just need to do a power reset for the dongle to enter DFU mode. The Jlink is only needed once per dongle.
    Do you have the option to automatically turn off and on the USB dongle power ?
  • Hey,
    I'm using 40 dongles, and I don't have the option to turn the USB dongle power off and on.
    I feel like using my own bootloader would take too much time, so we thought of another approach: using more dongles, each prepared with the app versions I want. I will plug them depending on the configuration needed for my tests.
    Thanks for your answers.
  • Hi Tom,
    I agree. Simply use different dongles for different application would be the better solution. It's much more simple that trying to get a different bootloader and/or modify the test application.
