Lte link controller losing network coverage
I have several field devices using the LTE Link Controller library with nRF Connect SDK v2.5.1. Most of them work fine — they are programed to connect every hour. However, I’ve noticed 2 devices that were previously connecting fine suddenly lost connection because they were moved in an area with poor network coverage.
When these devices moved back into an area with good coverage, they never reconnected automatically. After performing a power cycle, they immediately reconnected and started working normally again.
Unfortunately, the only thing I was able to recover was a partial log which show the modem trying this every hour:
[27:01:28.516,723] <inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_STAT)
[27:01:28.533,050] <err> modem_info_params: Link data not obtained: 5 -22
[27:01:28.533,081] <err> modem_module: modem_info_params_get, error: -22
[27:01:28.533,172] <inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_NOT_READY
I have two questions about the LTE Link Controller behavior:
  1. Once lte_lc_connect_async() is called, does it need to be called again after a connection loss, or does the library automatically retry?
  2. The CONFIG_LTE_NETWORK_TIMEOUT parameter is set to 600. From my understanding, it only applies during the initial lte_lc_connect_async() call. What happens after a connection loss — how many retries are attempted, and does the library eventually stop retrying at some point?
Thanks in advance for your help!
    When those 2 devices were moved to an area with poor connectivity, were they able to connect there automatically without problems but experienced problems when moved back to an area with good coverage?
    Do you use PSM or eDRX in your application?
    Which modem firmware version do you use?
    Is there possibility that you obtain and send complete log?
    Dejan
  • Hi dejans,
    They both lost connection. They both stop connecting completely and never reconnected again. I got to them and moved them back to a good coverage. They were not able to reconnect and I had to power cycle, which made them connect right away.
    I use default asset tracker settings :
    ## Power saving timers.
    ### 320 hours PSM.
    CONFIG_LTE_PSM_REQ=y
    CONFIG_LTE_PROPRIETARY_PSM_REQ=y
    CONFIG_LTE_PSM_REQ_RPTAU="10000001"
    ### 20 seconds active time.
    CONFIG_LTE_PSM_REQ_RAT="00001010"
    2.0.2
    Sorry I don't have more data cause I was not able to recaver logs on the field. When I moved them to a good coverage zone, I recorded the lines I sent already, before powere cycle them.
    For now I am just looking to understand the LTE link library. Can you help answer my 2 questions?
    Thanks
    lte_lc_connect_async() documentation specifies the following:
    "This function sets the modem to online mode using lte_lc_normal. The client does not need to do anything to re-connect if the connection is lost but the modem will handle it automatically."
    You can also look at this thread.
    Dejan
  • Thanks for the reply.
    Is there a reason why you asked about PSM or eDRX ?
    There was no special reason apart from getting more information about your application and more complete overall picture.
    Dejan
  • Related
