compilation error for USB Mass Storage sample with nrf7002dk and ncs 3.0.2
In order to solve another ticket, I need to make mass storage sample to work with a nrf7002dk and nc3.0.2 but I can't manage to make it work. It was working two years ago when I tried with ncs 2.5.0.
In prj.conf, I added :
CONFIG_APP_MSC_STORAGE_FLASH_FATFS=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
(I took example from this ticket : USB Mass Storage Sample using nRF7002-dk - Nordic Q&A - Nordic DevZone - Nordic DevZone )
And setup following build configuration
But it doesn't compile :
In file included from C:/ncs/v3.0.2/zephyr/include/zephyr/storage/flash_map.h:330,
                 from C:/Dev/zephyr_sandbox/mass/src/main.c:21:
C:/Dev/zephyr_sandbox/mass/src/main.c: In function 'setup_flash':
C:/ncs/v3.0.2/nrf/include/flash_map_pm.h:47:22: error: 'PM_storage_partition_ID' undeclared (first use in this function)
   47 | #define PM_ID(label) PM_##label##_ID
Any idea ?
Thank you for your help
  • Hi, thank you for your answer.
    If you installed the toolchain using nrfutil or VS Code, then the VS Code extension should use this toolchain, including the python version bundled with the toolchain.
    I installed all toolchains with VS Code.
    nrfutil sdk-manager toolchain launch --ncs-version=v3.0.2 --shell
    Give "ModuleNotFoundError: No module named 'constants'" even if I install constants with pip.
    Best regards
    Do you get errors if you open an nRF Connect terminal in VS Code and flash using the west flash command in this terminal?
    Marte
    when opening an nRFConnect terminal and using the flash command as follow :
    I have the same error :
    PS C:\Dev\zephyr_sandbox\mass\build\mass> west flash -d c:\Dev\zephyr_sandbox\mass\build --domain mass --dev-id 1050717037
    -- west flash: rebuilding
    [0/3] Performing build step for 'mass'
    ninja: no work to do.
    [3/3] Completed 'mass'
    -- west flash: using runner nrfutil
    -- runners.nrfutil: reset after flashing requested
    -- runners.nrfutil: Flashing file: C:\Dev\zephyr_sandbox\mass\build\mass\zephyr\zephyr.hex
      File "<frozen runpy>", line 198, in _run_module_as_main
      File "<frozen runpy>", line 88, in _run_code
      File "C:\Users\AppData\Local\Programs\Python\Python312\Scripts\nrfutil.exe\__main__.py", line 4, in <module>
      File "C:\Users\AppData\Local\Programs\Python\Python312\Lib\site-packages\nordicsemi\__main__.py", line 50, in <module>
        from nordicsemi.dfu.bl_dfu_sett import BLDFUSettings
      File "C:\Users\AppData\Local\Programs\Python\Python312\Lib\site-packages\nordicsemi\dfu\bl_dfu_sett.py", line 52, in <module>
        from nordicsemi.dfu.package import Package
      File "C:\Users\AppData\Local\Programs\Python\Python312\Lib\site-packages\nordicsemi\dfu\package.py", line 54, in <module>
        from nordicsemi.dfu.init_packet_pb import *
      File "C:\Users\AppData\Local\Programs\Python\Python312\Lib\site-packages\nordicsemi\dfu\init_packet_pb.py", line 38, in <module>
        from . import dfu_cc_pb2 as pb
      File "C:\Users\AppData\Local\Programs\Python\Python312\Lib\site-packages\nordicsemi\dfu\dfu_cc_pb2.py", line 32, in <module>
        _descriptor.EnumValueDescriptor(
      File "C:\ncs\toolchains\0b393f9e1b\opt\bin\Lib\site-packages\google\protobuf\descriptor.py", line 920, in __new__
        _message.Message._CheckCalledFromGeneratedFile()
    TypeError: Descriptors cannot be created directly.
    If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.19.0.
    If you cannot immediately regenerate your protos, some other possible workarounds are:
     1. Downgrade the protobuf package to 3.20.x or lower.
     2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slower).
    More information: https://developers.google.com/protocol-buffers/docs/news/2022-05-06#python-updates
    -- runners.nrfutil: Board with serial number 1050717037 flashed successfully.
    Best regards
    Can you try uninstalling the nRF Connect SDK and toolchain, and then reinstalling it?
    Marte
