How does TF-M select UART1 pins?
Hello DevZone,
I have a confusing question about TF-M. Need  help from a TF-M expert.
In this document, it says that we must disable uart1 in non-secure application, because TF-M use it as secure peripheral.
My question is: how does TF-M select the pins used by uart1_secure?
My board selection is `nrf9160dk/nrf9160/ns`, which is a non-secure board.
I use AI to read the build progress and all the Ninja things. And it told me that TF-M just read the non-secure `zephyr.dts` and use the pin-ctrl of that.
I think this is not reasonable, because uart1 is disabled in my application. There is no reason for TF-M to use the pin-ctrl from a disabled uart.
More general question: how can I choose a peripheral as secure or non-secure in NCS? Should I configure this in Devicetree or Kconfig?
Jayant
  • Wow, that is more clear for me.
    You mean when I select `nrf9160dk/nrf9160/ns` for my application, the TF-M will use `nrf9160dk/nrf9160` automatically. Because they are in the same board folder.
    But when I choose the ns for my application, it seems that there is no way to set a `.overlay` devicetree file in sysbuild subfolder to modify the pins of TF-M. Is that correct?
    I remember when in NCS v2.2.0, I can set overlay of SPM in "child_image" subfolder.
  • I understand that sysbuild is used for multi-image building.
    But TF-M seems to be special. There is no way in sysbuild to configure the TF-M overlay.
    More preciously, TF-M is more like a part of application, rather than an independent image:
    After many times searching, I finally found that TF-M never use Zephyr serial driver.
    All the answers are in these header files:
    In `device_cfg.h` we have:
    In `RTE_device.h` we have:
    In `tfm_peripherals_config.h`, we have:
    So, that means TF-M can directly read the non-secure Application's final `zephyr.dts`, and read the pin-ctrl of uart1, even if uart1 is disabled.
    And this question:
    The answer is to set CONFIG_NRF_XXXX_SECURE.
    So everything seems to be clear now. And this
    seems not to be correct.
    I will test this tomorrow and get back here.
  • I have confirmed that:
    1. TF-M doesn't have a stand alone sysbuild configuration, it is a part of the Application
    2. TF-M will use application's non-secure uart1 pinctrl, even if uart1 is disabled.
    CONFIG_SERIAL=y
    CONFIG_TFM_LOG_LEVEL_SILENCE=n
    &uart1 {
        status = "disabled";
    &pinctrl{
    	uart1_default: uart1_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 16)>,
    				<NRF_PSEL(UART_RTS, 0, 14)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 0, 17)>,
    				<NRF_PSEL(UART_CTS, 0, 15)>;
    			bias-pull-up;
    	uart1_sleep: uart1_sleep {
    		group1 {
    				<NRF_PSEL(UART_RTS, 0, 14)>,
    			low-power-enable;
    Cheers!
