Correct way to configure 3-wire SPI in nRF Connect SDK
We are developing a board with an nRF54L15 module that interfaces with a SPI device. We want to use 3-wire spi, so the MISO and MOSI lines are shorted (according to the datasheet of the device), and connected to a SDO port on the MCU. We don't use a SDI port. How to correctly configure 3-wire spi in the pinctrl file?
Should it be like this:
    spi20_default: spi00_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 1, 10)>,
                    <NRF_PSEL(SPIM_MOSI, 1, 9)>,
                    <NRF_PSEL_DISCONNECTED(SPIM_MISO)>;
Or like this:
        group1 {
                    <NRF_PSEL(SPIM_MISO, 1, 9))>;
Or something completely different?
  • Hi Bert,
    If you're not going to use MISO, why can't you just leave it floating? Actually you don't really have to define it either, it's optional.
    regards
    Jared
  • Thanks for your response! We use MISO, but since we only use SPI in half-duplex mode we want to save a pin by connecting the SDO pin to both MISO and MOSI on the SPI client.
    But I can confirm that it works to configure SPIM_MOSI and SPIM_MISO with the same pin, so for me everything is clear now.
  • Sorry for reopening this Thread. We first used P1 pins for this setup, and that worked properly. But we would like to switch to P2 pins on the nrf54l15 for the spi communication.
    We made sure to use the designated pins, but unfortunately we don't get any response from the SPI slave anymore after switching the pins. Spi initialization doesn't give errors. Could it be that a shared MISO and MOSI isn't working on the P2 ports? Maybe because of the high-drive requirement?
    This is our pinctrl config for P2:
        spi00_default: spi00_default {
            group1 {
                psels = <NRF_PSEL(SPIM_MISO, 2, 8)>;
            group2 {
                psels = <NRF_PSEL(SPIM_SCK, 2, 6)>,
                        <NRF_PSEL(SPIM_MOSI, 2, 8)>;
                nordic,drive-mode = <NRF_DRIVE_E0E1>;
        spi00_sleep: spi00_sleep {
            group1 {
                        <NRF_PSEL(SPIM_MOSI, 2, 8)>,
                low-power-enable;
  • Hi there,
    I find a bit strange that this did work on P1 in the first place as the SPI drivers reconfigure the GPIO depending on if it's a MOSI or MISO. If you probe the data pins, do you see any activity from the nRF?
    best regards
    Jared
  • It definitely works on P1 of the nrf54l15 and we also have this configuration (with same pin for MOSI and MISO) working on a nrf52840.
    But if I understand correctly there is no official half-duplex spi support in the nrfx drivers? So we were kind of lucky that it worked?
