ble-lte gateway support for thingy91X
I have been working on a BLE-LTE gateway for Thingy91x for quite some time. To this end, I have tried various options:
- First, using multi-image builds: modifying the Cellular: LTE Sensor Gateway example,
and adapting it to Thingy91x. I tried different BLE part samples: “Bluetooth: Peripheral UART,” “Bluetooth: HCI UART,” “Bluetooth: HCI low power UART,” or "Bluetooth: HCI IPC." The main problem here was nRF5340, which has 2 cores (APP and NET), in contrast to the single-core nRF52840.
Problems I encountered:
  • hci_lpuart – couldn't build the project, missing dependencies for Thingy91x.
  • hci_uart – project built and ran, but I got this error on 5340: bt_hci_core: HCI driver open failed (-1).
  • hci_ipc – tried to use SB_CONFIG_NETCORE_HCI_IPC, but it didn't work: SB_CONFIG_NETCORE_HCI_IPC was assigned the value y, but got the value n. Missing dependencies: SUPPORT_NETCORE_HCI_IPC && <choice NETCORE>.
- Using sysbuild to integrate “Cellular: nRF Cloud MQTT device message” with ready images:
SB_CONFIG_NETCORE_HCI_IPC or SB_CONFIG_NETCORE_RPC_HOST.
Problems: I couldn't make these images work for Thingy91x (platform was not supported). They worked only for nRF53. I also tried creating my own separate apps with sysbuild.cmake ExternalZephyrProject_Add commands for nrf5340/cpunet and nrf5340/cpuapp, but that also failed for me: different Kconfig and dependency problems.
After trying all these options and more, I feel like making this BLE-LTE gateway on this device is impossible. I saw that the "Cellular: LTE Sensor Gateway" sample is deprecated and only valid for nRF9160 DK, with possible adaptation for Thingy91 (https://devzone.nordicsemi.com/f/nordic-q-a/54848/thingy91-lte-ble-gateway-with-modem-info), but what about Thingy91x?
Additionally, today I saw this project: https://github.com/nRFCloud/lte-gateway.. And despite .conf and .overlay for Thingy91x, the README file points only to nRF9160-based boards as required. Can I somehow build an LTE-BLE gateway for Thingy91x from that project?
Summing up, I have a couple of questions:
  1. Is it possible to create an LTE-BLE gateway for Thingy91x, or maybe there are some hardware limitations for that?
  2. If 1 is true, what is the best way to do that?
Thank you for your help.
