I'm trying to program a custom board with a Raytac nRF52832 module using the nRF52 DK's onboard J-Link via the P20 debug out port. The J-Link only detects the onboard nRF52832, not my external module.
I've checked the following:
My custom board is powered with a solid 3V.
The module's DEC4 pin shows 1.234V, so its internal regulator is working.
All P20 connections (GND, SWDCLK, SWDIO, RESET) are wired correctly per the DK user guide.
The P20 VTG pin is correctly connected to my board's 3V supply.
The P19 debug out port is completely empty.
To verify my board, I connected an ST-Link v2 with OpenOCD, and it successfully detected the chip. The log shows:
- Since the ST-Link works, is there a special
nrfjprogornrfutilcommand other then "recover" needed to force the DK's J-Link to use the P20 port? I tried vs code board recover and nrf tool recovering but it did not help. - If I give up on the DK, will a J-Link EDU Mini work correctly with a 3V (not 3.3V) target board? I will buy j-link edu if it will work.
- Can I recover chip with using ST-link?
