nRF Sniffer for BLE not detecting nRF boards in Wireshark (nrfutil 8.1.1, Sniffer FW 4.1.1)
Description
I was following the tutorial from DevAcademy regarding the setup of the nRF Sniffer for Bluetooth LE:
DevAcademy: nRF Sniffer for Bluetooth LE
However, the boards (tested on nRF52840 DK and nRF52 DK) flashed with the corresponding BLE sniffer firmware were not detected in Wireshark (with the nRF Sniffer plugin configured), neither on Windows nor under WSL.
Environment
  • Wireshark version: 4.6.0 (v4.6.0-0-gcdfb6721e77c)
  • nrfutil version:
    nrfutil.exe --version
    nrfutil 8.1.1 (b6089d0 2025-08-21)
    commit-hash: b6089d08a9cfdb292f8ab8d21e0908ded814cd11
    commit-date: 2025-08-21
    host: x86_64-pc-windows-msvc
    build-timestamp: 2025-08-21T14:12:43.593658000Z
    classification: nrf-external
  • Firmware used: (from $NRFUTIL_HOME/share/nrfutil-ble-sniffer/firmware, version 4.1.1)
    • sniffer_nrf52840dk_nrf52840_4.1.1.hex (nRF52840 DK)
    • sniffer_nrf52dk_nrf52832_4.1.1.hex (nRF52 DK)
Bootstrap was completed using:
nrfutil ble-sniffer bootstrap
(run as Administrator).
Observed Behavior
The nRF Sniffer for Bluetooth LE plugin is correctly detected by Wireshark and visible under
Help → About Wireshark → Plugins (as shown in the attached screenshots):
nrfutil-ble-sniffer-hci-shim.exe   0.16.2   External Capture
nrfutil-ble-sniffer-shim.exe       0.16.2   External Capture
Additionally, the Interface Toolbar → nRF Sniffer for Bluetooth LE option is available under the View menu.
Despite the plugin being properly detected, no sniffer intefaces/devices appear under the Capture tab in Wireshark.
Debug Logs
For debug purposes I've started Wireshark from a command prompt with:
"C:\Program Files\Wireshark\Wireshark.exe" --log-level debug --log-file -
After performing Capture → Refresh Interfaces, the log shows that extcap discovery completes and the nRF Sniffer shims are loaded:
** (wireshark:6480) 11:52:48.812153 [Extcap INFO] -- extcap: completed discovery of 3 tools in 248.346ms
** (wireshark:6480) 11:52:48.812892 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-hci-shim.exe
** (wireshark:6480) 11:52:48.813524 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-shim.exe
However, the sniffer devices do not appear in the Wireshark interface list.
Full log:
C:\Users\natal>"C:\Program Files\Wireshark\Wireshark.exe" --log-level debug --log-file -
C:\Users\natal>
 ** (wireshark:6480) 11:52:45.122476 [Plugins INFO] -- Registered plugin: usbdump.dll (C:\Program Files\Wireshark\plugins\4.6\wiretap\usbdump.dll)
 ** (wireshark:6480) 11:52:45.155480 [Plugins INFO] -- Registered plugin: ethercat.dll (C:\Program Files\Wireshark\plugins\4.6\epan\ethercat.dll)
 ** (wireshark:6480) 11:52:45.156498 [Plugins INFO] -- Registered plugin: gryphon.dll (C:\Program Files\Wireshark\plugins\4.6\epan\gryphon.dll)
 ** (wireshark:6480) 11:52:45.157371 [Plugins INFO] -- Registered plugin: ipaddr.dll (C:\Program Files\Wireshark\plugins\4.6\epan\ipaddr.dll)
 ** (wireshark:6480) 11:52:45.158250 [Plugins INFO] -- Registered plugin: irda.dll (C:\Program Files\Wireshark\plugins\4.6\epan\irda.dll)
 ** (wireshark:6480) 11:52:45.159639 [Plugins INFO] -- Registered plugin: mate.dll (C:\Program Files\Wireshark\plugins\4.6\epan\mate.dll)
 ** (wireshark:6480) 11:52:45.160592 [Plugins INFO] -- Registered plugin: opcua.dll (C:\Program Files\Wireshark\plugins\4.6\epan\opcua.dll)
 ** (wireshark:6480) 11:52:45.161467 [Plugins INFO] -- Registered plugin: profinet.dll (C:\Program Files\Wireshark\plugins\4.6\epan\profinet.dll)
 ** (wireshark:6480) 11:52:45.162308 [Plugins INFO] -- Registered plugin: stats_tree.dll (C:\Program Files\Wireshark\plugins\4.6\epan\stats_tree.dll)
 ** (wireshark:6480) 11:52:45.163117 [Plugins INFO] -- Registered plugin: transum.dll (C:\Program Files\Wireshark\plugins\4.6\epan\transum.dll)
 ** (wireshark:6480) 11:52:45.164180 [Plugins INFO] -- Registered plugin: unistim.dll (C:\Program Files\Wireshark\plugins\4.6\epan\unistim.dll)
 ** (wireshark:6480) 11:52:45.165387 [Plugins INFO] -- Registered plugin: wimax.dll (C:\Program Files\Wireshark\plugins\4.6\epan\wimax.dll)
 ** (wireshark:6480) 11:52:45.166428 [Plugins INFO] -- Registered plugin: wimaxasncp.dll (C:\Program Files\Wireshark\plugins\4.6\epan\wimaxasncp.dll)
 ** (wireshark:6480) 11:52:45.167533 [Plugins INFO] -- Registered plugin: wimaxmacphy.dll (C:\Program Files\Wireshark\plugins\4.6\epan\wimaxmacphy.dll)
 ** (wireshark:6480) 11:52:45.252433 [Epan INFO] -- Failed to add Oid: mts-transfer-protocol-1984 applicationProtocol.1
 ** (wireshark:6480) 11:52:45.253428 [Epan INFO] -- Failed to add Oid: mta-transfer-protocol applicationProtocol.12
 ** (wireshark:6480) 11:52:45.264330 [Plugins INFO] -- Registered plugin: g711.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g711.dll)
 ** (wireshark:6480) 11:52:45.266037 [Plugins INFO] -- Registered plugin: g722.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g722.dll)
 ** (wireshark:6480) 11:52:45.267383 [Plugins INFO] -- Registered plugin: g726.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g726.dll)
 ** (wireshark:6480) 11:52:45.268736 [Plugins INFO] -- Registered plugin: g729.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g729.dll)
 ** (wireshark:6480) 11:52:45.270725 [Plugins INFO] -- Registered plugin: ilbc.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\ilbc.dll)
 ** (wireshark:6480) 11:52:45.272228 [Plugins INFO] -- Registered plugin: l16mono.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\l16mono.dll)
 ** (wireshark:6480) 11:52:45.273783 [Plugins INFO] -- Registered plugin: opus_dec.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\opus_dec.dll)
 ** (wireshark:6480) 11:52:45.275146 [Plugins INFO] -- Registered plugin: sbc.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\sbc.dll)
 ** (wireshark:6480) 11:52:45.287626 [Epan INFO] -- OID resolution not enabled
 ** (wireshark:6480) 11:52:45.631393 [Extcap INFO] -- extcap: completed discovery of 3 tools in 340.398ms
 ** (wireshark:6480) 11:52:45.632307 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-hci-shim.exe
 ** (wireshark:6480) 11:52:45.632979 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-shim.exe
 ** (wireshark:6480) 11:52:45.638058 [Extcap INFO] -- Loading interface list for C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:45.638536 [Extcap INFO] -- Interface found etwdump
 ** (wireshark:6480) 11:52:45.639106 [Extcap INFO] --   Interface [etwdump] "Event Tracing for Windows (ETW) reader"
 ** (wireshark:6480) 11:52:45.781743 [Extcap INFO] -- Extcap pipe C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:45.783074 [Extcap INFO] --   DLT 290 name="etwdump" display="DLT_ETW"
 ** (wireshark:6480) 11:52:45.801604 [DFilter INFO] -- Compiled display filter: tcp.analysis.flags && !tcp.analysis.window_update && !tcp.analysis.keep_alive && !tcp.analysis.keep_alive_ack
 ** (wireshark:6480) 11:52:45.802240 [DFilter INFO] -- Compiled display filter: hsrp.state != 8 && hsrp.state != 16
 ** (wireshark:6480) 11:52:45.802735 [DFilter INFO] -- Compiled display filter: stp.type == 0x80
 ** (wireshark:6480) 11:52:45.803203 [DFilter INFO] -- Compiled display filter: ospf.msg != 1
 ** (wireshark:6480) 11:52:45.803934 [DFilter INFO] -- Compiled display filter: icmp.type in { 3..5, 11 } || icmpv6.type in { 1..4 }
 ** (wireshark:6480) 11:52:45.804617 [DFilter INFO] -- Compiled display filter: arp
 ** (wireshark:6480) 11:52:45.805106 [DFilter INFO] -- Compiled display filter: icmp || icmpv6
 ** (wireshark:6480) 11:52:45.805540 [DFilter INFO] -- Compiled display filter: tcp.flags.reset eq 1
 ** (wireshark:6480) 11:52:45.806044 [DFilter INFO] -- Compiled display filter: sctp.chunk_type eq ABORT
 ** (wireshark:6480) 11:52:45.806632 [DFilter INFO] -- Compiled display filter: (ip.dst != 224.0.0.0/4 && ip.ttl < 5 && !(pim || ospf || eigrp || bgp || tcp.port==179)) || (ip.dst == 224.0.0.0/24 && ip.dst != 224.0.0.251 && ip.ttl != 1 && !(vrrp || carp || eigrp || rip || glbp))
 ** (wireshark:6480) 11:52:45.807070 [DFilter INFO] -- Compiled display filter: (ipv6.dst != ff00::/8 && ipv6.hlim < 5 && !( ospf|| bgp || tcp.port==179)) || (ipv6.dst==ff00::/8 && ipv6.hlim not in {1, 64, 255})
 ** (wireshark:6480) 11:52:45.807543 [DFilter INFO] -- Compiled display filter: eth.fcs.status=="Bad" || ip.checksum.status=="Bad" || tcp.checksum.status=="Bad" || udp.checksum.status=="Bad" || sctp.checksum.status=="Bad" || mstp.checksum.status=="Bad" || cdp.checksum.status=="Bad" || edp.checksum.status=="Bad" || wlan.fcs.status=="Bad" || stt.checksum.status=="Bad"
 ** (wireshark:6480) 11:52:45.807995 [DFilter INFO] -- Compiled display filter: smb || nbss || nbns || netbios
 ** (wireshark:6480) 11:52:45.808404 [DFilter INFO] -- Compiled display filter: http || tcp.port == 80 || http2
 ** (wireshark:6480) 11:52:45.808807 [DFilter INFO] -- Compiled display filter: dcerpc
 ** (wireshark:6480) 11:52:45.809281 [DFilter INFO] -- Compiled display filter: hsrp || eigrp || ospf || bgp || cdp || vrrp || carp || gvrp || igmp || ismp
 ** (wireshark:6480) 11:52:45.809809 [DFilter INFO] -- Compiled display filter: tcp.flags & 0x02 || tcp.flags.fin == 1
 ** (wireshark:6480) 11:52:45.810443 [DFilter INFO] -- Compiled display filter: tcp
 ** (wireshark:6480) 11:52:45.811012 [DFilter INFO] -- Compiled display filter: udp
 ** (wireshark:6480) 11:52:45.811631 [DFilter INFO] -- Compiled display filter: eth[0] & 1
 ** (wireshark:6480) 11:52:45.812544 [DFilter INFO] -- Compiled display filter: systemd_journal || sysdig
 ** (wireshark:6480) 11:52:45.815710 [DFilter INFO] -- Compiled display filter: tcp.analysis.flags && !tcp.analysis.window_update && !tcp.analysis.keep_alive && !tcp.analysis.keep_alive_ack
 ** (wireshark:6480) 11:52:45.816457 [DFilter INFO] -- Compiled display filter: hsrp.state != 8 && hsrp.state != 16
 ** (wireshark:6480) 11:52:45.816921 [DFilter INFO] -- Compiled display filter: stp.type == 0x80
 ** (wireshark:6480) 11:52:45.817401 [DFilter INFO] -- Compiled display filter: ospf.msg != 1
 ** (wireshark:6480) 11:52:45.817884 [DFilter INFO] -- Compiled display filter: icmp.type in { 3..5, 11 } || icmpv6.type in { 1..4 }
 ** (wireshark:6480) 11:52:45.818525 [DFilter INFO] -- Compiled display filter: arp
 ** (wireshark:6480) 11:52:45.818942 [DFilter INFO] -- Compiled display filter: icmp || icmpv6
 ** (wireshark:6480) 11:52:45.819388 [DFilter INFO] -- Compiled display filter: tcp.flags.reset eq 1
 ** (wireshark:6480) 11:52:45.819807 [DFilter INFO] -- Compiled display filter: sctp.chunk_type eq ABORT
 ** (wireshark:6480) 11:52:45.820258 [DFilter INFO] -- Compiled display filter: (ip.dst != 224.0.0.0/4 && ip.ttl < 5 && !(pim || ospf || eigrp || bgp || tcp.port==179)) || (ip.dst == 224.0.0.0/24 && ip.dst != 224.0.0.251 && ip.ttl != 1 && !(vrrp || carp || eigrp || rip || glbp))
 ** (wireshark:6480) 11:52:45.820687 [DFilter INFO] -- Compiled display filter: (ipv6.dst != ff00::/8 && ipv6.hlim < 5 && !( ospf|| bgp || tcp.port==179)) || (ipv6.dst==ff00::/8 && ipv6.hlim not in {1, 64, 255})
 ** (wireshark:6480) 11:52:45.821126 [DFilter INFO] -- Compiled display filter: eth.fcs.status=="Bad" || ip.checksum.status=="Bad" || tcp.checksum.status=="Bad" || udp.checksum.status=="Bad" || sctp.checksum.status=="Bad" || mstp.checksum.status=="Bad" || cdp.checksum.status=="Bad" || edp.checksum.status=="Bad" || wlan.fcs.status=="Bad" || stt.checksum.status=="Bad"
 ** (wireshark:6480) 11:52:45.821655 [DFilter INFO] -- Compiled display filter: smb || nbss || nbns || netbios
 ** (wireshark:6480) 11:52:45.822083 [DFilter INFO] -- Compiled display filter: http || tcp.port == 80 || http2
 ** (wireshark:6480) 11:52:45.822589 [DFilter INFO] -- Compiled display filter: dcerpc
 ** (wireshark:6480) 11:52:45.823013 [DFilter INFO] -- Compiled display filter: hsrp || eigrp || ospf || bgp || cdp || vrrp || carp || gvrp || igmp || ismp
 ** (wireshark:6480) 11:52:45.823479 [DFilter INFO] -- Compiled display filter: tcp.flags & 0x02 || tcp.flags.fin == 1
 ** (wireshark:6480) 11:52:45.823913 [DFilter INFO] -- Compiled display filter: tcp
 ** (wireshark:6480) 11:52:45.824382 [DFilter INFO] -- Compiled display filter: udp
 ** (wireshark:6480) 11:52:45.824872 [DFilter INFO] -- Compiled display filter: eth[0] & 1
 ** (wireshark:6480) 11:52:45.825445 [DFilter INFO] -- Compiled display filter: systemd_journal || sysdig
 ** (wireshark:6480) 11:52:45.861713 [Main INFO] -- Wireshark is up and ready to go, elapsed time 0.922s
 ** (wireshark:6480) 11:52:48.818605 [Extcap INFO] -- Loading interface list for C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:48.819385 [Extcap INFO] -- Interface found etwdump
 ** (wireshark:6480) 11:52:48.819954 [Extcap INFO] --   Interface [etwdump] "Event Tracing for Windows (ETW) reader"
 ** (wireshark:6480) 11:52:48.874269 [Extcap INFO] -- Extcap pipe C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:48.874808 [Extcap INFO] --   DLT 290 name="etwdump" display="DLT_ETW"
Additional Testing
When I've manually run the extcap tools directly, both fail with the following error:
>"C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-shim.exe" --extcap-interfaces
thread 'main' panicked at src\main.rs:1860:68:
called `Option::unwrap()` on a `None` value
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Error: Subprocess C:\Users\natal\.nrfutil\bin\nrfutil-ble-sniffer.exe failed with unexpected exit code Some(101)
>"C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-hci-shim.exe" --extcap-interfaces
Additional Verification
Devices’ serial ports are correctly detected in other software.
Using nRF Connect for Desktop – Serial Terminal, both boards (nRF52 DK and nRF52840 DK) appear and connect successfully via their serial ports.
Communication works without issues, and data can be read from the devices as expected (see attached screenshots).
Summary of the Issue
Even though the nRF Sniffer for BLE plugin is correctly installed, detected, and initialized within Wireshark (as confirmed by plugin listings and logs), the sniffer interfaces do not appear in the Capture list.
The extcap executables (nrfutil-ble-sniffer-shim.exe and nrfutil-ble-sniffer-hci-shim.exe) both fail to enumerate devices and terminate with exit code 101 caused by an unhandled Option::unwrap() error.
  • Hi
    Correct, as I stated below, if you are using a DK with the nRF USB connector available, you should use the nRF USB connector instead of the virtual COM port on the IMCU. This is because the VCOM can't match the higher BLE throughput that the nRF USB port can.
    This is also noted in the documentation as a note here: https://docs.nordicsemi.com/bundle/nrfutil/page/nrfutil-ble-sniffer/guides/running_sniffer.html
    Is that the issue for everyone that has reported this issue?
    Simon
  • Hi
    Yes I can confirm this also worked for me. I was following DevAcademy: https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/lessons/lesson-6-bluetooth-le-sniffer/topic/nrf-sniffer-for-bluetooth-le/
    Here it is stated "Due to a recent update of the nRF52833 DK version 3 and nRF52840 DK version 3, the new Interface IC on the DK is not fully compatible with the nRF Sniffer software. If you have an nRF52840DK v3, you will need to use the nRF USB port instead of the Interface IC USB port."
    Since I have nrf52840dk v2.0.2 I assumed the JTAG USB would work. You should test which boards are affected and update the information so other people avoid this issue.
  • Sorry, but big disagree,
    >If you are using a DK with the nRF Universal Serial Bus (USB) connector available, it is recommended to use the nRF USB connector instead of the virtual COM port of the onboard interface MCU. This is because the virtual COM port cannot match the higher Bluetooth LE throughput of the nRF USB connector.
    False. It is not should or recommended. It is required with current software and this board.
    The link you posted has a note, ok, but it also has a picture that is wrong for normal use as shown.
    On top of this, you need the JLINK USB to program, then to switch to the NRF USB to use.
    This is not optionally / should / recommended because of bandwidth. This is because it flat out doesn't work as explained.
    I know the bandwidth issue. I've seen it drop packets or maybe report as malformed when the bandwidth gets high on a connection. This isn't that. Wireshark can't find the interface because it has been removed from tunneling to the JLINK USB it seems.
    >I have reported this issue internally now
    This needs a better and more clear note in the documentation. This image is entirely wrong now.
  • RIght, that note for v3 is incorrect. Applies to v1 and v2 with the latest sniffer firmware.
  • Hi
    I have issued an internal ticket to rephrase the note and look into this issue on our end. The idea is that both the IMCU and nRF USB port should be usable, but that the nRF USB post is recommended. However, the current version of the nRF Sniffer firmware is having some issues and we are looking to fix this.
    I agree that the note needs clarification while this is an issue though. As for the image, it would be correct for I.E. the nRF52832 which only has the IMCU USB port. But having one image for the different DKs is a good idea. Thank you for your thorough feedback.
    Simon
