nRF Sniffer for BLE not detecting nRF boards in Wireshark (nrfutil 8.1.1, Sniffer FW 4.1.1)
Description
I was following the tutorial from DevAcademy regarding the setup of the nRF Sniffer for Bluetooth LE:
DevAcademy: nRF Sniffer for Bluetooth LE
However, the boards (tested on nRF52840 DK and nRF52 DK) flashed with the corresponding BLE sniffer firmware were not detected in Wireshark (with the nRF Sniffer plugin configured), neither on Windows nor under WSL.
Environment
  • Wireshark version: 4.6.0 (v4.6.0-0-gcdfb6721e77c)
  • nrfutil version:
    nrfutil.exe --version
    nrfutil 8.1.1 (b6089d0 2025-08-21)
    commit-hash: b6089d08a9cfdb292f8ab8d21e0908ded814cd11
    commit-date: 2025-08-21
    host: x86_64-pc-windows-msvc
    build-timestamp: 2025-08-21T14:12:43.593658000Z
    classification: nrf-external
  • Firmware used: (from $NRFUTIL_HOME/share/nrfutil-ble-sniffer/firmware, version 4.1.1)
    • sniffer_nrf52840dk_nrf52840_4.1.1.hex (nRF52840 DK)
    • sniffer_nrf52dk_nrf52832_4.1.1.hex (nRF52 DK)
Bootstrap was completed using:
nrfutil ble-sniffer bootstrap
(run as Administrator).
Observed Behavior
The nRF Sniffer for Bluetooth LE plugin is correctly detected by Wireshark and visible under
Help → About Wireshark → Plugins (as shown in the attached screenshots):
nrfutil-ble-sniffer-hci-shim.exe   0.16.2   External Capture
nrfutil-ble-sniffer-shim.exe       0.16.2   External Capture
Additionally, the Interface Toolbar → nRF Sniffer for Bluetooth LE option is available under the View menu.
Despite the plugin being properly detected, no sniffer intefaces/devices appear under the Capture tab in Wireshark.
Debug Logs
For debug purposes I've started Wireshark from a command prompt with:
"C:\Program Files\Wireshark\Wireshark.exe" --log-level debug --log-file -
After performing Capture → Refresh Interfaces, the log shows that extcap discovery completes and the nRF Sniffer shims are loaded:
** (wireshark:6480) 11:52:48.812153 [Extcap INFO] -- extcap: completed discovery of 3 tools in 248.346ms
** (wireshark:6480) 11:52:48.812892 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-hci-shim.exe
** (wireshark:6480) 11:52:48.813524 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-shim.exe
However, the sniffer devices do not appear in the Wireshark interface list.
Full log:
C:\Users\natal>"C:\Program Files\Wireshark\Wireshark.exe" --log-level debug --log-file -
C:\Users\natal>
 ** (wireshark:6480) 11:52:45.122476 [Plugins INFO] -- Registered plugin: usbdump.dll (C:\Program Files\Wireshark\plugins\4.6\wiretap\usbdump.dll)
 ** (wireshark:6480) 11:52:45.155480 [Plugins INFO] -- Registered plugin: ethercat.dll (C:\Program Files\Wireshark\plugins\4.6\epan\ethercat.dll)
 ** (wireshark:6480) 11:52:45.156498 [Plugins INFO] -- Registered plugin: gryphon.dll (C:\Program Files\Wireshark\plugins\4.6\epan\gryphon.dll)
 ** (wireshark:6480) 11:52:45.157371 [Plugins INFO] -- Registered plugin: ipaddr.dll (C:\Program Files\Wireshark\plugins\4.6\epan\ipaddr.dll)
 ** (wireshark:6480) 11:52:45.158250 [Plugins INFO] -- Registered plugin: irda.dll (C:\Program Files\Wireshark\plugins\4.6\epan\irda.dll)
 ** (wireshark:6480) 11:52:45.159639 [Plugins INFO] -- Registered plugin: mate.dll (C:\Program Files\Wireshark\plugins\4.6\epan\mate.dll)
 ** (wireshark:6480) 11:52:45.160592 [Plugins INFO] -- Registered plugin: opcua.dll (C:\Program Files\Wireshark\plugins\4.6\epan\opcua.dll)
 ** (wireshark:6480) 11:52:45.161467 [Plugins INFO] -- Registered plugin: profinet.dll (C:\Program Files\Wireshark\plugins\4.6\epan\profinet.dll)
 ** (wireshark:6480) 11:52:45.162308 [Plugins INFO] -- Registered plugin: stats_tree.dll (C:\Program Files\Wireshark\plugins\4.6\epan\stats_tree.dll)
 ** (wireshark:6480) 11:52:45.163117 [Plugins INFO] -- Registered plugin: transum.dll (C:\Program Files\Wireshark\plugins\4.6\epan\transum.dll)
 ** (wireshark:6480) 11:52:45.164180 [Plugins INFO] -- Registered plugin: unistim.dll (C:\Program Files\Wireshark\plugins\4.6\epan\unistim.dll)
 ** (wireshark:6480) 11:52:45.165387 [Plugins INFO] -- Registered plugin: wimax.dll (C:\Program Files\Wireshark\plugins\4.6\epan\wimax.dll)
 ** (wireshark:6480) 11:52:45.166428 [Plugins INFO] -- Registered plugin: wimaxasncp.dll (C:\Program Files\Wireshark\plugins\4.6\epan\wimaxasncp.dll)
 ** (wireshark:6480) 11:52:45.167533 [Plugins INFO] -- Registered plugin: wimaxmacphy.dll (C:\Program Files\Wireshark\plugins\4.6\epan\wimaxmacphy.dll)
 ** (wireshark:6480) 11:52:45.252433 [Epan INFO] -- Failed to add Oid: mts-transfer-protocol-1984 applicationProtocol.1
 ** (wireshark:6480) 11:52:45.253428 [Epan INFO] -- Failed to add Oid: mta-transfer-protocol applicationProtocol.12
 ** (wireshark:6480) 11:52:45.264330 [Plugins INFO] -- Registered plugin: g711.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g711.dll)
 ** (wireshark:6480) 11:52:45.266037 [Plugins INFO] -- Registered plugin: g722.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g722.dll)
 ** (wireshark:6480) 11:52:45.267383 [Plugins INFO] -- Registered plugin: g726.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g726.dll)
 ** (wireshark:6480) 11:52:45.268736 [Plugins INFO] -- Registered plugin: g729.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\g729.dll)
 ** (wireshark:6480) 11:52:45.270725 [Plugins INFO] -- Registered plugin: ilbc.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\ilbc.dll)
 ** (wireshark:6480) 11:52:45.272228 [Plugins INFO] -- Registered plugin: l16mono.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\l16mono.dll)
 ** (wireshark:6480) 11:52:45.273783 [Plugins INFO] -- Registered plugin: opus_dec.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\opus_dec.dll)
 ** (wireshark:6480) 11:52:45.275146 [Plugins INFO] -- Registered plugin: sbc.dll (C:\Program Files\Wireshark\plugins\4.6\codecs\sbc.dll)
 ** (wireshark:6480) 11:52:45.287626 [Epan INFO] -- OID resolution not enabled
 ** (wireshark:6480) 11:52:45.631393 [Extcap INFO] -- extcap: completed discovery of 3 tools in 340.398ms
 ** (wireshark:6480) 11:52:45.632307 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-hci-shim.exe
 ** (wireshark:6480) 11:52:45.632979 [Extcap INFO] -- Loading interface list for C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-shim.exe
 ** (wireshark:6480) 11:52:45.638058 [Extcap INFO] -- Loading interface list for C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:45.638536 [Extcap INFO] -- Interface found etwdump
 ** (wireshark:6480) 11:52:45.639106 [Extcap INFO] --   Interface [etwdump] "Event Tracing for Windows (ETW) reader"
 ** (wireshark:6480) 11:52:45.781743 [Extcap INFO] -- Extcap pipe C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:45.783074 [Extcap INFO] --   DLT 290 name="etwdump" display="DLT_ETW"
 ** (wireshark:6480) 11:52:45.801604 [DFilter INFO] -- Compiled display filter: tcp.analysis.flags && !tcp.analysis.window_update && !tcp.analysis.keep_alive && !tcp.analysis.keep_alive_ack
 ** (wireshark:6480) 11:52:45.802240 [DFilter INFO] -- Compiled display filter: hsrp.state != 8 && hsrp.state != 16
 ** (wireshark:6480) 11:52:45.802735 [DFilter INFO] -- Compiled display filter: stp.type == 0x80
 ** (wireshark:6480) 11:52:45.803203 [DFilter INFO] -- Compiled display filter: ospf.msg != 1
 ** (wireshark:6480) 11:52:45.803934 [DFilter INFO] -- Compiled display filter: icmp.type in { 3..5, 11 } || icmpv6.type in { 1..4 }
 ** (wireshark:6480) 11:52:45.804617 [DFilter INFO] -- Compiled display filter: arp
 ** (wireshark:6480) 11:52:45.805106 [DFilter INFO] -- Compiled display filter: icmp || icmpv6
 ** (wireshark:6480) 11:52:45.805540 [DFilter INFO] -- Compiled display filter: tcp.flags.reset eq 1
 ** (wireshark:6480) 11:52:45.806044 [DFilter INFO] -- Compiled display filter: sctp.chunk_type eq ABORT
 ** (wireshark:6480) 11:52:45.806632 [DFilter INFO] -- Compiled display filter: (ip.dst != 224.0.0.0/4 && ip.ttl < 5 && !(pim || ospf || eigrp || bgp || tcp.port==179)) || (ip.dst == 224.0.0.0/24 && ip.dst != 224.0.0.251 && ip.ttl != 1 && !(vrrp || carp || eigrp || rip || glbp))
 ** (wireshark:6480) 11:52:45.807070 [DFilter INFO] -- Compiled display filter: (ipv6.dst != ff00::/8 && ipv6.hlim < 5 && !( ospf|| bgp || tcp.port==179)) || (ipv6.dst==ff00::/8 && ipv6.hlim not in {1, 64, 255})
 ** (wireshark:6480) 11:52:45.807543 [DFilter INFO] -- Compiled display filter: eth.fcs.status=="Bad" || ip.checksum.status=="Bad" || tcp.checksum.status=="Bad" || udp.checksum.status=="Bad" || sctp.checksum.status=="Bad" || mstp.checksum.status=="Bad" || cdp.checksum.status=="Bad" || edp.checksum.status=="Bad" || wlan.fcs.status=="Bad" || stt.checksum.status=="Bad"
 ** (wireshark:6480) 11:52:45.807995 [DFilter INFO] -- Compiled display filter: smb || nbss || nbns || netbios
 ** (wireshark:6480) 11:52:45.808404 [DFilter INFO] -- Compiled display filter: http || tcp.port == 80 || http2
 ** (wireshark:6480) 11:52:45.808807 [DFilter INFO] -- Compiled display filter: dcerpc
 ** (wireshark:6480) 11:52:45.809281 [DFilter INFO] -- Compiled display filter: hsrp || eigrp || ospf || bgp || cdp || vrrp || carp || gvrp || igmp || ismp
 ** (wireshark:6480) 11:52:45.809809 [DFilter INFO] -- Compiled display filter: tcp.flags & 0x02 || tcp.flags.fin == 1
 ** (wireshark:6480) 11:52:45.810443 [DFilter INFO] -- Compiled display filter: tcp
 ** (wireshark:6480) 11:52:45.811012 [DFilter INFO] -- Compiled display filter: udp
 ** (wireshark:6480) 11:52:45.811631 [DFilter INFO] -- Compiled display filter: eth[0] & 1
 ** (wireshark:6480) 11:52:45.812544 [DFilter INFO] -- Compiled display filter: systemd_journal || sysdig
 ** (wireshark:6480) 11:52:45.815710 [DFilter INFO] -- Compiled display filter: tcp.analysis.flags && !tcp.analysis.window_update && !tcp.analysis.keep_alive && !tcp.analysis.keep_alive_ack
 ** (wireshark:6480) 11:52:45.816457 [DFilter INFO] -- Compiled display filter: hsrp.state != 8 && hsrp.state != 16
 ** (wireshark:6480) 11:52:45.816921 [DFilter INFO] -- Compiled display filter: stp.type == 0x80
 ** (wireshark:6480) 11:52:45.817401 [DFilter INFO] -- Compiled display filter: ospf.msg != 1
 ** (wireshark:6480) 11:52:45.817884 [DFilter INFO] -- Compiled display filter: icmp.type in { 3..5, 11 } || icmpv6.type in { 1..4 }
 ** (wireshark:6480) 11:52:45.818525 [DFilter INFO] -- Compiled display filter: arp
 ** (wireshark:6480) 11:52:45.818942 [DFilter INFO] -- Compiled display filter: icmp || icmpv6
 ** (wireshark:6480) 11:52:45.819388 [DFilter INFO] -- Compiled display filter: tcp.flags.reset eq 1
 ** (wireshark:6480) 11:52:45.819807 [DFilter INFO] -- Compiled display filter: sctp.chunk_type eq ABORT
 ** (wireshark:6480) 11:52:45.820258 [DFilter INFO] -- Compiled display filter: (ip.dst != 224.0.0.0/4 && ip.ttl < 5 && !(pim || ospf || eigrp || bgp || tcp.port==179)) || (ip.dst == 224.0.0.0/24 && ip.dst != 224.0.0.251 && ip.ttl != 1 && !(vrrp || carp || eigrp || rip || glbp))
 ** (wireshark:6480) 11:52:45.820687 [DFilter INFO] -- Compiled display filter: (ipv6.dst != ff00::/8 && ipv6.hlim < 5 && !( ospf|| bgp || tcp.port==179)) || (ipv6.dst==ff00::/8 && ipv6.hlim not in {1, 64, 255})
 ** (wireshark:6480) 11:52:45.821126 [DFilter INFO] -- Compiled display filter: eth.fcs.status=="Bad" || ip.checksum.status=="Bad" || tcp.checksum.status=="Bad" || udp.checksum.status=="Bad" || sctp.checksum.status=="Bad" || mstp.checksum.status=="Bad" || cdp.checksum.status=="Bad" || edp.checksum.status=="Bad" || wlan.fcs.status=="Bad" || stt.checksum.status=="Bad"
 ** (wireshark:6480) 11:52:45.821655 [DFilter INFO] -- Compiled display filter: smb || nbss || nbns || netbios
 ** (wireshark:6480) 11:52:45.822083 [DFilter INFO] -- Compiled display filter: http || tcp.port == 80 || http2
 ** (wireshark:6480) 11:52:45.822589 [DFilter INFO] -- Compiled display filter: dcerpc
 ** (wireshark:6480) 11:52:45.823013 [DFilter INFO] -- Compiled display filter: hsrp || eigrp || ospf || bgp || cdp || vrrp || carp || gvrp || igmp || ismp
 ** (wireshark:6480) 11:52:45.823479 [DFilter INFO] -- Compiled display filter: tcp.flags & 0x02 || tcp.flags.fin == 1
 ** (wireshark:6480) 11:52:45.823913 [DFilter INFO] -- Compiled display filter: tcp
 ** (wireshark:6480) 11:52:45.824382 [DFilter INFO] -- Compiled display filter: udp
 ** (wireshark:6480) 11:52:45.824872 [DFilter INFO] -- Compiled display filter: eth[0] & 1
 ** (wireshark:6480) 11:52:45.825445 [DFilter INFO] -- Compiled display filter: systemd_journal || sysdig
 ** (wireshark:6480) 11:52:45.861713 [Main INFO] -- Wireshark is up and ready to go, elapsed time 0.922s
 ** (wireshark:6480) 11:52:48.818605 [Extcap INFO] -- Loading interface list for C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:48.819385 [Extcap INFO] -- Interface found etwdump
 ** (wireshark:6480) 11:52:48.819954 [Extcap INFO] --   Interface [etwdump] "Event Tracing for Windows (ETW) reader"
 ** (wireshark:6480) 11:52:48.874269 [Extcap INFO] -- Extcap pipe C:\Program Files\Wireshark\extcap\etwdump.exe
 ** (wireshark:6480) 11:52:48.874808 [Extcap INFO] --   DLT 290 name="etwdump" display="DLT_ETW"
Additional Testing
When I've manually run the extcap tools directly, both fail with the following error:
>"C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-shim.exe" --extcap-interfaces
thread 'main' panicked at src\main.rs:1860:68:
called `Option::unwrap()` on a `None` value
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Error: Subprocess C:\Users\natal\.nrfutil\bin\nrfutil-ble-sniffer.exe failed with unexpected exit code Some(101)
>"C:\Users\natal\AppData\Roaming\Wireshark\extcap\nrfutil-ble-sniffer-hci-shim.exe" --extcap-interfaces
Additional Verification
Devices’ serial ports are correctly detected in other software.
Using nRF Connect for Desktop – Serial Terminal, both boards (nRF52 DK and nRF52840 DK) appear and connect successfully via their serial ports.
Communication works without issues, and data can be read from the devices as expected (see attached screenshots).
Summary of the Issue
Even though the nRF Sniffer for BLE plugin is correctly installed, detected, and initialized within Wireshark (as confirmed by plugin listings and logs), the sniffer interfaces do not appear in the Capture list.
The extcap executables (nrfutil-ble-sniffer-shim.exe and nrfutil-ble-sniffer-hci-shim.exe) both fail to enumerate devices and terminate with exit code 101 caused by an unhandled Option::unwrap() error.
  • Hi, has there been any progress on identifying the root issue? I'm using the NRF52832 development kit, and I'm experiencing the same problem.
  • Unfortunately we have not progressed on the root cause of this I'm afraid. Can you share what revision of DK, and how to reproduce this on an nRF52832 DK? As we've not seen this on the nRF52832 DKs.
    Simon
  • Hello Simonr,
    Here are the build details:
    host: aarch64-apple-darwin
    build-timestamp: 2025-08-21T14:12:53.940115000Z
    nrfutil-ble-sniffer 0.16.2 (5c12a5a 2025-04-15)
    commit-hash: 5c12a5a40d8ae2d3408385e40289728509e30d47
    commit-date: 2025-04-15
    build-timestamp: 2025-04-15T13:28:32.124021999Z
    1050354230
    Product J-Link
    Board version PCA10040
    Ports /dev/tty.usbmodem0010503542301, vcom: 0
    /dev/tty.usbmodem0010503542303, vcom: 1
    Traits devkit, jlink, seggerUsb, serialPorts, usb
    Supported devices found: 1
    And when executing the shim directly:
    /Users/eliharris/.local/lib/wireshark/extcap/nrfutil-ble-sniffer-shim --extcap-interfaces
    thread 'main' panicked at src/main.rs:1860:68:
    Error: Subprocess /Users/eliharris/.nrfutil/bin/nrfutil-ble-sniffer failed with unexpected exit code Some(101)
    However, running:
    ./nrfutil ble-sniffer sniff --port /dev/tty.usbmodem0010503542301
    Does produce a pcap file.
    I will try and reproduce on a VM with a fresh install.
  • Hi again everyone
    I wanted to let you know we have identified the issue, and we will try to have the release out with a fix this or next week. I'll update the ticket when I get the message from the developers.
    The issue was that the sniffer's search for devices was too narrow, and we have now expanded the search to accept all nRF52 series DK PIDs. Thank you all for your reports.
    Simon
  • Closing remarks: The ble-sniffer v0.17.1 is officially released, and this expands the device search done by the ble-sniffer and should fix this issue. Closing this ticket now.
    Simon
