How to change the parity bit on UART on NRF54L15?
prj.conf includes:
CONFIG_SERIAL=y
CONFIG_UART_20_NRF_PARITY_BIT=y
DT overlay includes:
&uart20 {
parity = "even";
Also tried:
const struct uart_config uart_cfg = {
.baudrate = 115200,
.parity = UART_CFG_PARITY_EVEN,
.stop_bits = UART_CFG_STOP_BITS_1,
.data_bits = UART_CFG_DATA_BITS_8,
.flow_ctrl = UART_CFG_FLOW_CTRL_NONE
Then..
while(!device_is_ready(uart_dev));
int err = uart_configure(uart_dev, &uart_cfg);
while(err == -ENOSYS);
..but err = -134 (-ENOSUP?)
Using Polling:
//Test 1
//Check for UART traffic
unsigned char uartRxBuff[20];
uartRxBuff[0] = 0;
int n = uart_poll_in(uart_dev, &uartRxBuff[0]);
if(uartRxBuff[0] != 0)
//if(uartRxBuff[0] == 0x79)
uartRxBuff[0] = 0x9f;
uart_poll_out(uart_dev, uartRxBuff[0]);
With Even parity on the other UART device it receives: 0x1f, if I send 0x1f in above code the other device receives 0x9f! Same deal with data received by NRF54L15 - the MSBit is flipped. If I switch the other device to parity=NONE (test FW - the actual FW is fixed at EVEN parity) the data comes thru correctly.
I was also unable to change the default UART20 RX/TX pins with the overlay - maybe it's the same problem?? It seems the overlay is ignored regarding UART20.
Is changing parity supported? Is there some conflict with TF-M or logging? How to change parity? The 'other' device uses EVEN parity and it cannot be changed.
Thanks!
