WIFI SCAN cannot build by using nrf9160
Hi Team,
I would like to interface the nrf9160 with nrf7001 by using the SPI. While building the WIFI-Scan example by using SDK 3.1.1. Even by using WIFI-shell example these both are the cannot able to build. Please guide me step by step how can we use these example for the nrf9160.
Thanks and Regards,
Jagadish M
    I downgraded the SDK3.1.0 AND toolchain also 3.1.0. but same problem.
    Please find the below logs.
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/Users/HanXcel/scan/build/scan/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\b8b84efebd\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf -L"c:/ncs/toolchains/b8b84e
    febd/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -lc -lgcc && cmd.exe /C "cd /D C:\Users\HanXcel\scan\build\scan\zephyr && C:\ncs\toolchains\b8b84efebd\o
    pt\bin\cmake.exe -E true""
    c:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj): in function `main':
    C:/Users/HanXcel/scan/src/main.c:298: undefined reference to `net_mgmt_NET_REQUEST_ETHERNET_SET_MAC_ADDRESS'
    collect2.exe: error: ld returned 1 exit status
    FAILED: _sysbuild/sysbuild/images/scan-prefix/src/scan-stamp/scan-build C:/Users/HanXcel/scan/build/_sysbuild/sysbuild/images/scan-prefix/src/scan-stamp/scan-build
    cmd.exe /C "cd /D C:\Users\HanXcel\scan\build\scan && C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.exe --build ."
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b8b84efebd\opt\bin\cmake.EXE' --build C:/Users/HanXcel/scan/build
    Thanks and Regards,
    Jagadish M
    No need to downgrade, as there should not be any changes.
    please provide build configuration and full build logs from your device.
    How are you building your project? What is the command you are starting build with?
    -Øyvind
  • can you suggest me the pin connections with nrf9160 interfacing with nrf7002-EK? I'm using the wifi-shell example.
    Please give me an step by step process to connect the nrf9160 with nrf7002. Pin configurations, prj.config, how can we scan the wifi by using the wifi shell example.
    Why i cannot build the wifi-scan example.
    I am not able to provide any steps without knowing what you are doing on your side for it to fail. Please provide answers to my quesitons.
    Øyvind
    Building scan
    west build --build-dir c:/Users/HanXcel/scan/build c:/Users/HanXcel/scan --pristine --board nrf9160dk/nrf9160/ns
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.1.0/zephyr/.cache
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: nrf9160dk, Revision: 0.14.0, qualifiers: nrf9160/ns
    Parsing C:/ncs/v3.1.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/Users/HanXcel/scan/build/_sysbuild/empty.conf'
    Merged configuration 'C:/Users/HanXcel/scan/build/_sysbuild/empty.conf'
    Merged configuration 'c:/Users/HanXcel/scan/sysbuild.conf'
    Configuration saved to 'C:/Users/HanXcel/scan/build/zephyr/.config'
    Kconfig header saved to 'C:/Users/HanXcel/scan/build/_sysbuild/autoconf.h'
    * Running CMake for scan *
    -- Application: C:/Users/HanXcel/scan
    -- CMake version: 3.21.0
    -- Zephyr version: 4.1.99 (C:/ncs/v3.1.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b8b84efebd/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.1.0/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: C:/ncs/v3.1.0/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns_0_14_0.overlay
    -- Generated zephyr.dts: C:/Users/HanXcel/scan/build/scan/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Users/HanXcel/scan/build/scan/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Users/HanXcel/scan/build/scan/zephyr/include/generated/zephyr/devicetree_generated.h
    warning: WIFI_NRF70 (defined at drivers/wifi/nrf_wifi/Kconfig.nrfwifi:11) was assigned the value 'y'
    but got the value 'n'. Check these unsatisfied dependencies: (DT_HAS_NORDIC_NRF7002_SPI_ENABLED ||
    DT_HAS_NORDIC_NRF7002_QSPI_ENABLED || DT_HAS_NORDIC_NRF7001_SPI_ENABLED ||
    DT_HAS_NORDIC_NRF7001_QSPI_ENABLED || DT_HAS_NORDIC_NRF7000_SPI_ENABLED ||
    DT_HAS_NORDIC_NRF7000_QSPI_ENABLED || n) (=n). See
    docs.zephyrproject.org/.../kconfig.html and/or look up WIFI_NRF70 in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: The choice symbol NRF_WIFI_PATCHES_EXT_FLASH_DISABLED (defined at
    C:/ncs/v3.1.0/nrf\subsys\net\lib\nrf70_fw_ext/Kconfig:22) was selected (set =y), but no symbol ended
    up as the choice selection. See
    look up NRF_WIFI_PATCHES_EXT_FLASH_DISABLED in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    warning: The choice symbol NRF70_SCAN_ONLY (defined at drivers/wifi/nrf_wifi/Kconfig.nrfwifi:57) was
    selected (set =y), but no symbol ended up as the choice selection. See
    NRF70_SCAN_ONLY in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Parsing C:/Users/HanXcel/scan/Kconfig
    Loaded configuration 'C:/ncs/v3.1.0/zephyr/boards/nordic/nrf9160dk/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'C:/Users/HanXcel/scan/prj.conf'
    Merged configuration 'C:/Users/HanXcel/scan/build/scan/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Users/HanXcel/scan/build/scan/zephyr/.config'
    Kconfig header saved to 'C:/Users/HanXcel/scan/build/scan/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/b8b84efebd/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING_C: True
    Backup: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING_C: True
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Found gen_kobject_list: C:/ncs/v3.1.0/zephyr/scripts/build/gen_kobject_list.py
    CMake Warning at C:/ncs/v3.1.0/zephyr/CMakeLists.txt:2232 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/HanXcel/scan/build/scan
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    ←[92m-- west build: building application
    [5/10] Performing build step for 'scan'
    [4/275] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.1.99 (C:/ncs/v3.1.0/zephyr), build: ncs-v3.1.0
    [5/275] Generating include/generated/device-api-sections.ld, include/generated/device-api-secti[6/275] Generating include/generated/device-api-sections.ld, include/generated/device-api-secti[7/275] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscal[9/275] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-t[10/275] Generating ../../tfm/CMakeCache.txt
    -- Found Git: C:/ncs/toolchains/b8b84efebd/mingw64/bin/git.exe (found version "2.37.3.windows.1")
    -- Found Python3: C:/ncs/toolchains/b8b84efebd/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/HanXcel/scan/build/scan/tfm
    [15/275] Performing build step for 'tfm'
    [0/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/common/syscalls_stu[2/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/c[3/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/p[4/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns[5/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/c[6/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz_[7/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/c[8/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/c[9/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/c[10/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/[11/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/[12/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platf[15/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/spm/core[16/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/shared/c[17/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/shared/c[18/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/inter[19/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/inter[20/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/tfm_sp_log_raw.[21/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/C_/ncs/v3.1.0/nrf[22/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/inter[24/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[25/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[26/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[27/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[28/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[29/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[30/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[31/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[32/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[33/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__[34/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[35/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[36/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[37/141] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/cr[38/141] Building C object secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/pla[39/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[40/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[41/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_[42/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[43/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[44/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[45/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[46/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[47/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[48/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[49/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcry[50/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CM[51/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon...[52/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CM[53/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CM[54/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CM[55/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CM[56/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CM[57/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_sec[58/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_sec[59/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[60/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[61/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[62/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[63/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[64/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[65/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[66/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[67/141] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_obe...[68/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/modules/hal/nordic/nrfx/d[69/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrf_e[70/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_[71/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nativ[72/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nativ[73/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.di[74/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.di[75/141] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.di[78/141] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/psa_api_veneers_v80m[79/141] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/co[81/141] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/[82/141] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/au[83/141] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/co[84/141] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_t[102/141] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/common/tfm_hal_nv[104/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/modules/hal/nordic/nrfx/[105/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/modules/hal/nordic/nrfx/[106/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/serv[107/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/serv[108/141] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsi[109/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[110/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[111/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[112/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[113/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[114/141] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_spm_logdev_peripher[115/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[116/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[117/141] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v3.1.0/nrf/modules/trusted-firm[126/141] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\drivers\nr[127/141] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\core\nrf_o[128/141] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libnrf_sec[129/141] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libmbedcry[130/141] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_[135/141] Building C object platform/target/nrf91/nrf_common/CMakeFiles/tfm_s_scatter.dir/__/__/__/__[137/141] Linking C executable bin\tfm_s.axf
    Memory region Used Size Region Size %age Used
    FLASH: 32092 B 32 KB 97.94%
    RAM: 10404 B 32 KB 31.75%
    [141/141] Linking C static library secure_fw\libtfm_s_veneers.a
    [17/275] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [18/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/[18/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/[18/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/[18/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/[18/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/[19/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[21/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[22/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/util[25/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[29/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[31/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[32/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[36/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[38/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[41/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[44/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[47/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[52/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecdsa[53/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[55/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[65/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecdsa[67/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[68/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[70/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v3.1.[73/275] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpa[78/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.di[79/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.di[81/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.di[83/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.di[87/275] Building C object modules/nrf/modules/trusted-firmware-m/CMakeFiles/tfm_api_nrf.dir/tfm_boar[109/275] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.o[111/275] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interf[112/275] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interf[113/275] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interf[114/275] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic[120/275] Linking C static library modules\nrf\modules\trusted-firmware-m\lib..__nrf__modules__truste[122/275] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic[165/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[167/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[168/275] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m[169/275] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m[170/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[172/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[174/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[175/275] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m[178/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[179/275] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.d[180/275] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m[183/275] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__corte[186/275] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_cor[187/275] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu[189/275] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.[196/275] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abo[199/275] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/mal[201/275] Building C object zephyr/soc/soc/nrf9160/CMakeFiles/soc__nordic.dir/validate_binding_header[204/275] Building C object zephyr/soc/soc/nrf9160/CMakeFiles/soc__nordic.dir/validate_enabled_instan[206/275] Building C object zephyr/boards/nordic/nrf9160dk/CMakeFiles/boards__nordic__nrf9160dk.dir/n[208/275] Building C object zephyr/subsys/debug/coredump/CMakeFiles/subsys__debug__coredump.dir/cored[211/275] Building C object zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_mgmt.[223/275] Building C object zephyr/subsys/net/l2/offloaded_netdev/CMakeFiles/subsys__net__l2__offload[227/275] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_[229/275] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_psa_crypto[236/275] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.ob[242/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[244/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[245/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[246/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[247/275] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/[252/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[254/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[255/275] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/[270/275] Linking C executable zephyr\zephyr_pre0.elf
    I'm using the vs code nrf connect. In that extension i'm adding the generate build option intially. then if i want to build, I will use build option in nrf connect extension.
    Thanks and Regards,
    Jagadish M.
