pm_static.yml file caused boot failure
~~~~~~~~~~Environment ~~~~~~~~~~
nrf54L15 + NCS 3.1.1 + VSCode + Win11
~~~~~~~Reproduction Steps~~~~~~~~~
1. without pm_statics.yml, with following configs (see attachment), merged.hex from prestine built can run on device successfully with DFU feature.
2. then I copied partitions.yml from build output, placed it into same folder of prj.conf, then changed its name to pm_static.yml
nothing else was changed.
in this case, prestine build still will pass, but merged.hex flashed into device will not boot system (no UART output can't be observed,)
~~~~~~~~Question ~~~~~~~~~
any fix need to be done, in order to use the auto generated partitions.yml?
~~~~~~~ Attachment ~~~~~~~~~~
 1️.prj.conf
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
CONFIG_MCUMGR_GRP_ZBASIC_STORAGE_ERASE=n
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_GATT_CACHING=n
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_EVT_RX_COUNT=12
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=6
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=12
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
CONFIG_NRFX_SAADC=y
CONFIG_NRFX_GPPI=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_ISR_STACK_SIZE=4096
CONFIG_BT_RX_STACK_SIZE=4096
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_MODE_DEFERRED=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
CONFIG_LOG_BUFFER_SIZE=4096
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=8192
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_FPU=y
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_SPI=y
CONFIG_GPIO=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_LOG_PRINTK=n
CONFIG_CMSIS_DSP=y
CONFIG_CMSIS_DSP_BASICMATH=y
CONFIG_CMSIS_DSP_STATISTICS=y
CONFIG_CMSIS_DSP_TRANSFORM=y
CONFIG_CMSIS_DSP_FILTERING=y
CONFIG_CMSIS_DSP_COMPLEXMATH=y
CONFIG_DSP=y
CONFIG_THREAD_NAME=y
CONFIG_REBOOT=y
CONFIG_RETENTION=y
CONFIG_RETAINED_MEM=y
CONFIG_CRC=y
2️.boards/wedb54_extra.conf
```conf
CONFIG_BT_DEVICE_NAME="MY_BLE_DEVICE"
CONFIG_NRFX_TIMER20=y
CONFIG_NRFX_TIMER22=y
CONFIG_NRFX_SPIM21=y
3.boards/wedb54.overlay
```dts
&uart20 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart20_default>;
    pinctrl-1 = <&uart20_sleep>;
&spi00 {
    status = "okay";
    pinctrl-0 = <&ks_spi_default>;
    pinctrl-1 = <&ks_spi_sleep>;
    cs-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>;
    ks_spi: ks@0 {
        compatible = "vnd,spi-device";
        reg = <0>;
        spi-max-frequency = <4000000>;
        label = "ks_spi";
&pinctrl {
    uart20_default: uart20_default {
        group1 {
            psels = <NRF_PSEL(UART_RX, 2, 0)>;
            bias-pull-up;
        group2 {
            psels = <NRF_PSEL(UART_TX, 2, 2)>;
    uart20_sleep: uart20_sleep {
        group1 {
            psels = <NRF_PSEL(UART_RX, 2, 0)>,
            low-power-enable;
    ks_spi_default: ks_spi_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 2, 6)>,
                    <NRF_PSEL(SPIM_MOSI, 2, 8)>,
                    <NRF_PSEL(SPIM_MISO, 2, 9)>;
    ks_spi_sleep: ks_spi_sleep {
        group1 {
            low-power-enable;
    aliases {
        pwr-on-off = &pwr_on_off_led;
        det-key = &det_button;
        bled = &bled;
    ks_rst_pin: ks-rst-pin {
        compatible = "nordic,gpio-pins";
        gpios = <&gpio0 0 GPIO_ACTIVE_HIGH>;
        status = "okay";
    ks_en_pin: ks-en-pin {
        gpios = <&gpio0 1 GPIO_ACTIVE_HIGH>;
        status = "okay";
    ks_ldf_pin: ks-ldf-pin {
        gpios = <&gpio2 10 GPIO_ACTIVE_HIGH>;
        status = "okay";
    pwr_on_off_pin: pwr-on-off-pin {
        compatible = "gpio-leds";
        status = "okay";
        pwr_on_off_led: pwr_on_off_led_0 {
            gpios = <&gpio0 2 GPIO_ACTIVE_HIGH>;
            label = "Power Control";
    det_key_pin: det-key-pin {
        compatible = "gpio-keys";
        status = "okay";
        det_button: det_button_0 {
            gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
            label = "Detection Key";
    bled_pin: bled-pin {
        status = "okay";
        bled: bled_0 {
            gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
            label = "Blue LED";
    sram@2003F000 {
        compatible = "zephyr,memory-region", "mmio-sram";
        reg = <0x2003F000 DT_SIZE_K(4)>;
        zephyr,memory-region = "RetainedMem";
        status = "okay";
        retainedmem {
            compatible = "zephyr,retained-ram";
            status = "okay";
            #address-cells = <1>;
            #size-cells = <1>;
            retention_log0: retention@0 {
                compatible = "zephyr,retention";
                status = "okay";
                reg = <0x0 0x1000>;
    chosen {
        zephyr,log-retention = &retention_log0;
4.sysbuild\mcuboot.conf
CONFIG_LOG=n
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_SERIAL=n
CONFIG_GPIO_LOG_LEVEL_OFF=y
CONFIG_BOOT_MAX_IMG_SECTORS=256
5.sysbuild\mcuboot.overlay
&uart30 {
    status = "disabled";
&uart20 {
&uart00 {
&adc {
    status = "okay";
6.sysbuild.conf
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="c:/dev_signing_key.pem"
SB_CONFIG_BOOT_ENCRYPTION=y
SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="c:/dev_encryption_key.pem"
7.CMakePresets.json
    "version": 2,
    "cmakeMinimumRequired": {
        "major": 3,
        "minor": 20
    "configurePresets": [
            "name": "build_54",
            "displayName": "Build for nRF54l15 DK nRF54l15 Application",
            "generator": "Ninja",
            "binaryDir": "${sourceDir}/build_54",
            "cacheVariables": {
                "BOARD": "nrf54l15dk/nrf54l15/cpuapp",
                "EXTRA_CONF_FILE": "boards/wedb54_extra.conf",
                "CONF_FILE": "prj.conf",
                "DTC_OVERLAY_FILE": "boards/wedb54.overlay"
8.auto generated partitions.yml
EMPTY_0:
  address: 0xd800
  end_address: 0xe000
  placement:
    after:
    - mcuboot
  region: flash_primary
EMPTY_1:
  address: 0x164000
  end_address: 0x165000
  placement:
    after:
    - mcuboot_secondary
app:
  address: 0xe800
  end_address: 0xb9000
bootconf:
  address: 0xffd080
  end_address: 0xffd084
  region: bootconf
mcuboot:
  address: 0x0
  end_address: 0xd800
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xe000
  end_address: 0xe800
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xe000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0xe800
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0xb9000
  end_address: 0x164000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
    align_next: 0x1000
  share_size:
  - mcuboot_primary
otp:
  address: 0xffd500
  end_address: 0xffd9fc
  region: otp
sram_primary:
  address: 0x20000000
  end_address: 0x2002f000
  region: sram_primary
  • Does the build log give any warnings or usefull info? Does it contain the line where it says that it found the 'pm_static.yml' file?
  • Thanks for your advice!  I reboot vscode before trying to reproduce this problem, but this issue can't be reproduced anymore.
    p.s. here are logs for two cases both worked well.
    ~~~~~~~~~~~~~~~~~~~ build log without pm_static.yml~~~~~~~~~~~~~~~~~~~~~~~~~~~
    -- Including signing script: C:/ncs/v3.1.1/nrf/cmake/sysbuild/image_signing.cmake
    -- Development build - obfuscation disabled
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/workspace/prjFW/build_54/prjFW
    CMake Warning at C:/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manageCMake Warning at C:/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:119 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      C:/ncs/v3.1.1/nrf/cmake/sysbuild/partition_manager.cmake:636 (partition_manager)
      C:/ncs/v3.1.1/nrf/sysbuild/CMakeLists.txt:825 (include)
      cmake/modules/sysbuild_extensions.cmake:598 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:598 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
      C:/ncs/v3.1.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    ~~~~~~~~~~~~~~~~~~~~ build log with pm_static.yml~~~~~~~~~~~~~~~~~~~~~~~~
    -- Configuring done
    -- Generating done
    -- Found partition manager static configuration : C:/workspace/prjFW/pm_static.yml
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    -- Configuring done
    -- Generating done
