Adafruit Feather nRF52840 UART config incorrect
I have an Adafruit Feather nRF52840 which I'm trying to use to transmit data over a UART serial connection to a Raspberry Pi. The Raspberry Pi is running a Python test script (details below) which configures its serial port per the MIDI specification which says:
"The hardware MIDI interface operates at 31.25 (+/- 1%) Kbaud, asynchronous, with a start bit, 8 data bits (D0 to D7), and a stop bit. This makes a total of 10 bits for a period of 320 microseconds per serial byte. The start bit is a logical 0 (current on) and the stop bit is a logical 1 (current off)".
My Zephyr code configures the nRF52840 in the same way. I then send 8 bytes with known values. The Raspberry Pi script prints what it receives to the console.
The Pi is printing 5 times more bytes than are being transmitted and the byte values bear no resemblance to those that were transmitted. I believe this is indicative of a mismatch between the UART configs on the transmitting nRF52840 and the Pi.
Here's the Raspberry Pi receiver script:
import serial
ser = serial.Serial('/dev/ttyAMA0', baudrate=31250)
while True:
  data = ord(ser.read(1))
  print("Decimal: "+str(data)+"\t\tBinary: "+format(data,'008b')+"\t\tHex: 0x"+format(data,'02x'))
Note that I validated the Python script by connecting a commercial MIDI keyboard directly to the Pi and pressing a key (note=F3). The results were as expected and are presented here:
MIDI Keyboard sending NOTE ON then NOTE OFF to the Receiver (key played, F3)
Decimal: 144            Binary: 10010000                Hex: 0x90
Decimal: 65             Binary: 01000001                Hex: 0x41
Decimal: 52             Binary: 00110100                Hex: 0x34
Decimal: 128            Binary: 10000000                Hex: 0x80
Decimal: 59             Binary: 00111011                Hex: 0x3b
NOTE ON  is 1001nnnn 0kkkkkkk 0vvvvvvv where n is the channel, k is the note number and v is the velocity value.
NOTE OFF is 1000nnnn 0kkkkkkk 0vvvvvvv where n is the channel, k is the note number and v is the velocity value.
So the data received:
10010000    01000001    00110100 - NOTE ON  (channel 1), note=F3, velocity=52
10000000    01000001    00111011 - NOTE OFF (channel 1), note=F3, velocity=59
Results are as expected. Python script validated.
Here's my Zephyr code:
// C code
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <math.h>
/* Get UART1 device */
static const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
// 1200, 2400, 4800, 9600, 19200, 31250, 57600, 115200
#define BAUDRATE 31250
    printk("uart_tx_text V1.3 - baudrate=%d\n",BAUDRATE);
    if (!device_is_ready(uart)) {
            printk("ERROR: uart1 is not ready\n");
            return -1;
    printk("UART1 is ready\n");
	/* UART configuration */
	const struct uart_config uart_cfg = {
		.baudrate = BAUDRATE,
		.parity = UART_CFG_PARITY_NONE,
		.stop_bits = UART_CFG_STOP_BITS_1,
		.data_bits = UART_CFG_DATA_BITS_8,
		.flow_ctrl = UART_CFG_FLOW_CTRL_NONE
    int ret = uart_configure(uart, &uart_cfg);
    if (ret < 0) {
            printk("ERROR configuring UART: %d",ret);
            return ret;
    printk("UART1 has been configured - start receiver now\n");
    k_msleep(10000);
    int p=0;
    for (p=1; p<9;p++) {
        uint8_t val=(pow(2,p)-1);
        uart_poll_out(uart, val);
        printk("TX Decimal: %d Hex: %02x\n",val, val);
    return 0;
// DTS overlay
 * Copyright (c) 2025
&uart1 {
	status = "okay";
	current-speed = <31250>;
	pinctrl-0 = <&uart1_default>;
	pinctrl-1 = <&uart1_sleep>;
&pinctrl {
	uart1_default: uart1_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 10)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 1, 9)>;
			bias-pull-up;
	uart1_sleep: uart1_sleep {
		group1 {
			psels = <NRF_PSEL(UART_TX, 1, 10)>,
			low-power-enable;
// prj.conf
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=512
And here are my test results:
// output from the Adafruit Feather nRF52840
00> *** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
00> *** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
00> uart_tx_text V1.3 - baudrate=31250
00> UART1 is ready
00> UART1 has been configured - start receiver now
00> TX Decimal: 1 Hex: 01
00> TX Decimal: 3 Hex: 03
00> TX Decimal: 7 Hex: 07
00> TX Decimal: 15 Hex: 0f
00> TX Decimal: 31 Hex: 1f
00> TX Decimal: 63 Hex: 3f
00> TX Decimal: 127 Hex: 7f
00> TX Decimal: 255 Hex: ff
// Output from the Raspberry Pi receiver script
Receiver:
Decimal: 129            Binary: 10000001                Hex: 0x81
Decimal: 78             Binary: 01001110                Hex: 0x4e
Decimal: 198            Binary: 11000110                Hex: 0xc6
Decimal: 39             Binary: 00100111                Hex: 0x27
Decimal: 237            Binary: 11101101                Hex: 0xed
Decimal: 136            Binary: 10001000                Hex: 0x88
Decimal: 139            Binary: 10001011                Hex: 0x8b
Decimal: 200            Binary: 11001000                Hex: 0xc8
Decimal: 220            Binary: 11011100                Hex: 0xdc
Decimal: 107            Binary: 01101011                Hex: 0x6b
Decimal: 239            Binary: 11101111                Hex: 0xef
Decimal: 11             Binary: 00001011                Hex: 0x0b
Decimal: 224            Binary: 11100000                Hex: 0xe0
Decimal: 196            Binary: 11000100                Hex: 0xc4
Decimal: 207            Binary: 11001111                Hex: 0xcf
Decimal: 113            Binary: 01110001                Hex: 0x71
Decimal: 3              Binary: 00000011                Hex: 0x03
Decimal: 232            Binary: 11101000                Hex: 0xe8
Decimal: 228            Binary: 11100100                Hex: 0xe4
Decimal: 255            Binary: 11111111                Hex: 0xff
My UART config params look correct in my Zephyr C code and I am not getting an error when I call uart_configure. And yet the evidence would suggest that the configuration is not being set as requested. The transmitting nRF52840 and receiving Pi are presumably not using the same parameters which is why the Pi reports nonsense results.
Note that this Pi has been used for MIDI applications many times before and is therefore a reliable, known quantity. My validation test also verifies that the problem is not at the receiver end of the communication.
Could someone please help with this? Is this a Zephyr bug? Or is it my code?
Thanks in anticipation
  • Hi
    uart_poll_out is part of the Zephyr UART API and its function signature (from uart.h) is as follows:
    static inline void uart_poll_out(const struct device * dev, unsigned char out_char)
    I don't see a correlation between the extra logged values and the values received but maybe you can?
    // Transmitted
    uart_tx_text V1.13 - baudrate=31250
    UART is ready
    UART has been configured
    TX Decimal: 144 Hex: 90  21c1
    TX Decimal: 48 Hex: 30  1eed
    TX Decimal: 100 Hex: 64  21c1
    TX Decimal: 128 Hex: 80  21c1
    // Received
    Decimal: 216            Binary: 11011000                Hex: 0xd8
    Decimal: 210            Binary: 11010010                Hex: 0xd2
    Your theory is an interesting one and presumably if that was the case (UART turned off early), this would constitute a Zephyr bug?
    I'm looking forward to receiving my logic analyser!
  • Possibly a bug; usually sending 3 bytes over UART would send 3 concatenated bytes as a packet which is much more efficient. The 'scope you have would be fine to check the pattern; set to Trig NORM and negative Edge then transmit a single byte such that all bits are clearly displayed on the 'scope so we can decode the sent data. If having trouble avoiding noise set to SINGLE. Trig threshold should be set at 50% of signal level.
    Edit: Also note that the code you tried to enable the 32MHz crystal for use with the UART is incorrect as it refers to the 32kHz crystal, ie this code you posted is not what you need:
    // Note this sets 32kHz crystal, not 32MHz crystal
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n
    CONFIG_CLOCK_CONTROL_NRF=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    Need something like this:
    clock_control_on(clock_dev, CLOCK_CONTROL_NRF_SUBSYS_HF);
  • Thank you. I'm going to be busy the next few days so it might be a while before I get to refocus on this and the logic analyser should arrive in the meantime.
    I've been looking for a UART protocol specification and so far have only found PDFs from manufacturers such as TI. Is there a formal specification I should be consulting?
    I'll report back as soon as I can.
  • I'm now sending decimal 85 (binary 01010101) six times and receiving Decimal: 203 Binary: 11001011 six times. This seems to be consistent which in some ways is reassuring.
    I couldn't get the clock_control to work. I have the following in prj.conf:
    CONFIG_CLOCK_CONTROL=y
    and the following in my overlay file:
    &clocks {
        /* node '/clocks/hfxo' defined in zephyr\dts\arm\nordic\nrf52840.dtsi:35 */
        hfxo: hfxo {
           	status = "okay";
            compatible = "nordic,nrf52-hfxo"; /* in zephyr\dts\arm\nordic\nrf52840.dtsi:36 */
            clock-frequency = <64000000>;
            startup-time-us = <1400>;
            #clock-cells = <0>;
    but get parse error: undefined node label 'clocks' during building.
  • Point a hair-drier at the nRF5480 to warm it up and the received data at the Pi will be different if you are using the internal RC HFCLK; the internal clock is highly temperature dependent. Also does the 'scope show 4 equi-spaced low pulses? 4 includes the start bit.
    Edit: As an aside, if you get the correct temperature (heat or cool) the data should become correct .. if the HFCLK really is the issue
    Susheel would you kindly post the code to correctly enable the crystal HFCLK?
