SLM Shell issue on nRF52840dk and nRF9151DK SLM
I am trying to communicate with Serial LTE Modem application running on nRF9151DK through SLM Shell sample running on nRF52840DK.
I am using nrf connect in vscode, and have followed the instructions in:
https://docs.nordicsemi.com/bundle/ncs-3.0.2/page/nrf/applications/serial_lte_modem/doc/slm_description.html#requirements
I have couple of issues on both sides:
- On the slm-shell, when sending a simple "at" command, I receive TX Abort, I tried increasing the timeout, got same result:
*** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
*** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
[00:00:00.320,373] <inf> app: SLM Shell starts on nrf52840dk
[00:00:00.320,434] <inf> mdm_slm: UART baud: 115200 d/p/s-bits: 3/0/1 HWFC: 1
uart:~$ > slm at
slm at
[00:01:23.960,601] <wrn> mdm_slm: UART_TX_ABORTED, dropped: 4 bytes
uart:~$ [00:01:33.860,687] <err> mdm_slm: timeout
- On the modem side, I am using J-link RTT Viewer, but cannot capture any logs after the initial connection:
[00:00:00.252,655] <err> spi_nor: Device id 90 ca 33 does not match config c8 65 19
[00:00:00.253,662] <inf> at_cmd_custom: Custom AT commands enabled with 64 entries.
[00:00:00.254,119] <dbg> slm: main: RR: 0x00000001
[00:00:00.260,833] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.261,169] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.261,505] <inf> fs_nvs: data wra: 0, 0
[00:00:00.528,778] <inf> slm: lib_modem init: 0
[00:00:00.529,144] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:00:00.529,510] <inf> slm: Serial LTE Modem
[00:00:00.529,846] <inf> slm_uart_handler: UART baud: 115200 d/p/s-bits: 3/0/1 HWFC: 1
[00:00:00.623,565] <inf> nrf_cloud_info: Device ID: 50344354-3837-4ec6-800e-22144f7d9b35
[00:00:00.629,241] <inf> nrf_cloud_info: IMEI: 359404230026529
[00:00:00.721,588] <inf> nrf_cloud_info: UUID: 50344354-3837-4ec6-800e-22144f7d9b35
[00:00:00.727,569] <inf> nrf_cloud_info: Modem FW: mfw_nrf91x1_2.0.2
[00:00:00.727,966] <inf> nrf_cloud_info: Protocol: MQTT
[00:00:00.728,302] <inf> nrf_cloud_info: Download protocol: HTTPS
[00:00:00.728,668] <inf> nrf_cloud_info: Sec tag: 16842753
[00:00:00.729,034] <inf> nrf_cloud_info: Host name: mqtt.nrfcloud.com
[00:00:00.729,553] <dbg> slm_at_host: slm_at_send_indicate: TX
52 65 61 64 79 0d 0a |Ready..
[00:00:00.730,621] <inf> slm_at_host: at_host init done
Can you please advise how to resolve these issues?
Thanks
  • Hello Øyvind,
    Thank you for providing the build configurations.
    I have double-checked all connections, also recreated new applications for both, but still stuck.
    - SLM_shell TX aborts:
    - As for SLM, I am not receiving the Ready message after toggling the power pin:
    It seems J-link RTT is somehow disconnected, can't figure out the reason.
    Roya
  • Hello Øyvind,
    I re-installed the SDK, toolchain, and SEGGER, running more tests. The SLM-shell seems to work as expected, please see the logs below:
    However, no changes on the RTT viewer, same results as my last post. I tried both J-Link v8.88 and v8.76.
    - I was wondering if I can use uart backend instead of RTT, but I am confused which uart peripheral is used for this option, if it is uart0, how TX/RX on pins 11 and 12 are sent to console?
    Can you please clarify it?
    Roya
  • Hi Roya,
    Thanks for the information. Looks like this has solved the issue with UART between the devices at least.
    This is strange. One thing that our developers point to is to test with the newest Serial Modem application. This is the newest official application we´ll be using going forward: Serial Modem application for nRF91-based devices. Could you give that a try? The Serial LTE Modem is now deprecated in v3.2.0 in nRF Connect SDK.
    Have a look at this documentation on Logging. It should be possible to use UART instead of RTT.
    Øyvind
