CMake configure failed for Zephyr project: blinky
I'm following the steps in exercise 1 of the nRF Connect SDK Fundamentals and getting configuration failures.  From what I can tell it looks like Zephyr is failing to build
   * Running CMake for blinky *
-- Application: C:/blinky
-- CMake version: 3.21.0
-- Found Python3: C:/ncs/toolchains/66cdf9b75e/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: C:/ncs/v3.2.1/zephyr/.cache
-- Zephyr version: 4.2.99 (C:/ncs/v3.2.1/zephyr)
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: nrf52840dk, qualifiers: nrf52840
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/66cdf9b75e/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/66cdf9b75e/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/66cdf9b75e/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v3.2.1/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840.dts
-- Generated zephyr.dts: C:/blinky/build/blinky/zephyr/zephyr.dts
-- Generated pickled edt: C:/blinky/build/blinky/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/blinky/build/blinky/zephyr/include/generated/zephyr/devicetree_generated.h
Parsing C:/ncs/v3.2.1/zephyr/Kconfig
Loaded configuration 'C:/ncs/v3.2.1/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840_defconfig'
Merged configuration 'C:/blinky/prj.conf'
Merged configuration 'C:/blinky/build/blinky/zephyr/misc/generated/extra_kconfig_options.conf'
Merged configuration 'C:/blinky/build/blinky/zephyr/.config.sysbuild'
Configuration saved to 'C:/blinky/build/blinky/zephyr/.config'
Kconfig header saved to 'C:/blinky/build/blinky/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/66cdf9b75e/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/66cdf9b75e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Error at C:/ncs/v3.2.1/zephyr/cmake/modules/extensions.cmake:2627 (message):
  Assertion failed: The toolchain is unable to build a dummy C file.  Move
  C:/ncs/v3.2.1/zephyr/.cache, re-run and look at CMakeError.log
  C:/ncs/v3.2.1/zephyr/cmake/modules/kernel.cmake:150 (assert)
  C:/ncs/v3.2.1/zephyr/cmake/modules/zephyr_default.cmake:140 (include)
  C:/ncs/v3.2.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  C:/ncs/v3.2.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:4 (find_package)
See also "C:/blinky/build/blinky/CMakeFiles/CMakeOutput.log".
See also "C:/blinky/build/blinky/CMakeFiles/CMakeError.log".
CMake Error at cmake/modules/sysbuild_extensions.cmake:530 (message):
  cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
  cmake/modules/sysbuild_default.cmake:21 (include)
  C:/ncs/v3.2.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/ncs/v3.2.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "C:/blinky/build/CMakeFiles/CMakeOutput.log".
←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\66cdf9b75e\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/66cdf9b75e/opt/bin/python.exe '-Bc:\blinky\build' -GNinja -DBOARD=nrf52
840dk/nrf52840 -DCONFIG_DEBUG_THREAD_INFO=y -DCONF_FILE=prj.conf '-SC:\ncs\v3.2.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\blinky'
←[0m
 *  The terminal process terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
I searched and found one other question that looked similar, but it seems to be related to when nRF connect did not bundle the toolchains?
devzone.nordicsemi.com/.../276027
My configuration
nRF52840DK
Windows 11
NCS v3.2.1
Building with VSCode and nRF Connect extension pack
  • This seems like an NCS SDK issue.  I switched to v3.2.0 and it worked fine.
    This is strange, it should also work on the v3.2.1.
    Can you please share the whole output from the terminal when it was not working ?
    Simon D-M
  • Executing task: nRF Connect: Generate config nrf52840dk/nrf52840 for c:\blinky
    Building blinky
    west build --build-dir c:/blinky/build_1 c:/blinky --pristine --board nrf52840dk/nrf52840 -- -DCONFIG_DEBUG_THREAD_INFO=y
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    Parsing C:/ncs/v3.2.1/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/blinky/build_1/_sysbuild/empty.conf'
    Merged configuration 'C:/blinky/build_1/_sysbuild/empty.conf'
    Configuration saved to 'C:/blinky/build_1/zephyr/.config'
    Kconfig header saved to 'C:/blinky/build_1/_sysbuild/autoconf.h'
    -- Generated zephyr.dts: C:/blinky/build_1/blinky/zephyr/zephyr.dts
    -- Generated pickled edt: C:/blinky/build_1/blinky/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/blinky/build_1/blinky/zephyr/include/generated/zephyr/devicetree_generated.h
    Merged configuration 'C:/blinky/build_1/blinky/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration 'C:/blinky/build_1/blinky/zephyr/.config.sysbuild'
    Configuration saved to 'C:/blinky/build_1/blinky/zephyr/.config'
    Kconfig header saved to 'C:/blinky/build_1/blinky/zephyr/include/generated/zephyr/autoconf.h'
    See also "C:/blinky/build_1/blinky/CMakeFiles/CMakeOutput.log".
    See also "C:/blinky/build_1/blinky/CMakeFiles/CMakeError.log".
    See also "C:/blinky/build_1/CMakeFiles/CMakeOutput.log".
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\66cdf9b75e\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/66cdf9b75e/opt/bin/python.exe '-Bc:\blinky\build_1' -GNinja -DBOARD=nrf
    52840dk/nrf52840 -DCONFIG_DEBUG_THREAD_INFO=y '-SC:\ncs\v3.2.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\blinky'
    ←[0m
    Can you try to remove (or rename) the file "C:/ncs/v3.2.1/zephyr/.cache" and also remove the all the "build" folder in the application?
    Then try to do a pristine build.
    If it still doesn't work, can you please send me "CMakeOutput.log" located in "build/CMakeFiles"
    Simon D-M
  • Deleting the C:/ncs/v3.2.1/zephyr/.cache file seems to have fixed the issue.  Is there somewhere that describes why that is necessary for future reference?
    Honestly, I don't really know what happened in details, but it failed somewhere and cached it. So by removing the cached information, it forced it to retry from scratch.
    There was this message in your error logs. I still asked you the full logs to see the build command sent to check if there was an issue there, but it was all fine.
    Happy that I was able to help you,
    Simon D-M
    Simon D-M
