Trouble with nrf_802154_transmit_raw after SDK upgrade
I just noticed that there's another issue with my project after upgrading from SDK 2.3.0 to 3.1.1.
I am using the 802.15.4 radio for low level packet communications with nrf_802154_transmit_raw() to send packets. I overrode the weak definitions of nrf_802154_received_raw(), nrf_802154_transmitted_raw(), and nrf_802154_transmit_failed() to handle packet reception and TX completion. See attached radio_interface.c file.
After the upgrade I noticed that every time I transmit, I get a "Transmit failure" message in my log. So my call to nrf_802154_transmit_raw(txdata, NULL) is returning false every time. I confirmed that this was not happening before the SDK upgrade.
I am still getting calls to nrf_802154_transmitted_raw() for every attempted transmit, and I am generally not getting calls to nrf_802154_transmit_failed(). So it seems like maybe my transmits are working even though the transmit call returns a fail.
I just tried sending a reset command to one of my wireless nodes to see if transmit packets are actually working, and it does look like they are - though apparently something went off the rails when that device replied, as I got an "Illegal use of the EPSR" usage failure and my processor rebooted.
Note that this is on a Fanstel module with a FEM, so I'm using MPSL because I believe it's required for FEM control. I attached my prj.conf in case that's helpful.
I tried comparing my project to the only sample I can find that uses the raw interface, but I haven't found the problem yet: \ncs\v3.1.1\nrf\samples\peripheral\802154_phy_test\
Glen
Log snippet showing the usage fault:
U/A to transmit to 837632Transmit failure
Forward
Rx Data
Data from 1067402[01:19:54.213,500] <err> os: ***** USAGE FAULT *****
[01:19:54.219,085] <err> os: Illegal use of the EPSR
[01:19:54.224,945] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000020 r2/a3: 0
x00000001
[01:19:54.233,612] <err> os: r3/a4: 0x00000000 r12/ip: 0x20003640 r14/lr: 0
x0001e455
[01:19:54.242,309] <err> os: xpsr: 0x00000000
[01:19:54.247,528] <err> os: Faulting instruction address (r15/pc): 0x0001e468
[01:19:54.255,432] <err> os: >>> ZEPHYR FATAL ERROR 35: Unknown error on CPU 0
[01:19:54.263,336] <err> os: Current thread: 0x20003870 (main)
[01:19:54.269,836] <err> os: Halting system
à*** Booting nRF Connect SDK v3.1.1-e2a97fe2578a ***
*** Using Zephyr OS v4.1.99-ff8f0c579eeb ***
4111.prj.conf
//  Title   : radio_interface
//  Desc    : Nordic radio 802.15.4 interface functions
//  2022-8-5   Glen     Created
// Documentation on the 802.15.4 driver here:
// https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/nrfxlib/nrf_802154/README.html
// Sample code used for low level radio functions, rx pool, and how to receive
// are in the SDK here: \nRF_Connect\v2.0.0\nrf\samples\peripheral\802154_phy_test\src
//== Includes ================================================================
#include "radio_interface.h"
#include <string.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/byteorder.h>
#include <hal/nrf_radio.h>
#include <string.h>
#include <stdio.h>
#include "radio.h"
#include "iomapping.h"
//== Definitions and Types ===================================================
//#define NO_TRANSMIT_FCC_VERSION                  1
#define RF_FCS_SIZE                                (2u)
#define POWER_OUTPUT_LEVEL_INTO_AMPLIFIER          0      // dBm
#define POWER_INCREASE_AMPLIFIER                   22     // dBm
typedef uint16_t ptt_pkt_len_t;
struct rf_rx_pkt_s {
	uint8_t *rf_buf; /**< pointer to buffer inside radio driver with a received packet */
	uint8_t *data; /**< pointer to payload */
	ptt_pkt_len_t length; /**< size of payload of received packet */
	int8_t rssi; /**< RSSI */
	uint8_t lqi; /**< LQI */
//== Global Variables ========================================================
static volatile bool m_tx_complete = true;
//== Function prototypes =====================================================
// Name  : radio_interface_config
// Desc  : Meant to reset the radio but there isn't an obvious nrf function to
//         that and it might not even make sense for an on-processor radio
// Ins   : none
// Outs  : none
void radio_interface_config(void)
   // Clear the TX in progress flag
// Name  : radio_interface_receive
// Desc  : Start the radio to receive packets
// Ins   : none
// Outs  : none
void radio_interface_receive(void)
  nrf_802154_receive();
// Name  : radio_interface_init
// Desc  : Configure the radio
// Ins   : none
// Outs  : none
int radio_interface_init(void)
  /* nrf radio driver initialization */
   nrf_802154_init();
   uint8_t panId[] = { 0x00, 0x01 };
   nrf_802154_pan_id_set(&panId[0]);
   nrf_802154_channel_set(25);
   nrf_802154_promiscuous_set(false);
   return 0;
// Name  : radio_interface_channel_set
// Desc  : Send the channel to the radio driver
// Ins   : none
// Outs  : none
void radio_interface_channel_set(uint8_t channel)
   nrf_802154_channel_set(channel);
// Name  : nrf_802154_received_raw
// Desc  : Received a packet from the nrf radio. Save off needed data and call
//         rf_process_rx_packets to handle it
// Ins   : none
// Outs  : none
void nrf_802154_received_raw(uint8_t *data, int8_t power, uint8_t lqi)
	struct rf_rx_pkt_s rx_pkt;
	bool pkt_placed = false;
	if (data == NULL)
      return;
   rx_pkt.rf_buf = data;
   rx_pkt.data = &data[1];
   rx_pkt.length = data[0] - RF_FCS_SIZE;
   rx_pkt.lqi = lqi; // It looks like we don't need these ED conversions after all
   pkt_placed = true;
   // Convert the RSSI from dBm to a custom scale
   rx_pkt.rssi = radio_interface_signal_strength_lookup(power);
   radio_interrupt(true, false, rx_pkt.data, rx_pkt.length, rx_pkt.rssi, rx_pkt.lqi, 0);
   nrf_802154_buffer_free_raw(rx_pkt.rf_buf);
// Name  : nrf_802154_transmitted_raw
// Desc  : Override the WEAK defined library "tx done" function so that I can
//         add a call to the radio_interrupt in radio.c for status tracking
//         If ACK was requested for the transmitted frame, this function is
//         called after a proper ACK is received. If ACK was not requested,
//         this function is called just after transmission has ended.
// Ins   : none
// Outs  : none
void nrf_802154_transmitted_raw(uint8_t * p_frame, const nrf_802154_transmit_done_metadata_t * p_metadata)
    (void)p_frame;
    uint8_t * p_ack = p_metadata->data.transmitted.p_ack;
    if (p_ack != NULL)
        nrf_802154_buffer_free_raw(p_ack);
    radio_interrupt(false, true, NULL, 0, 0, 0, 0);   // Call the radio TX complete interrupt, no failure
    //printk("TXDONE m_tx_complete = true\r\n");
// Name  : nrf_802154_transmit_failed
// Desc  : Notifies that a frame was not transmitted due to a busy channel.
// Ins   : p_frame      Pointer to a buffer that contains PHR and PSDU of the frame that was not transmitted
// Ins   : error        Reason of the failure.
// Ins   : p_metadata   Pointer to a metadata structure describing frame passed in @p p_frame.
// Outs  : none
void nrf_802154_transmit_failed(uint8_t * p_frame, nrf_802154_tx_error_t error, const nrf_802154_transmit_done_metadata_t * p_metadata)
   radio_interrupt(false, true, NULL, 0, 0, 0, 1);   // Call the radio TX complete interrupt, with a failure
   //printk("TXFAIL m_tx_complete = true\r\n");
   printk("\r\nrf_802154_transmit_failed\r\n");
// Name  : radio_interface_transmit_packet
// Desc  : Send a packet out
// Ins   : A pointer to the data to send
// Outs  : none
void radio_interface_transmit_packet(uint8_t *txdata)
   bool txstatus;
   // The library is aware of the gain added by the PA, so you have to set the final output
   // power level you want, not just the level you want to go into the amplifier like it used to be
   nrf_802154_tx_power_set(POWER_OUTPUT_LEVEL_INTO_AMPLIFIER + POWER_INCREASE_AMPLIFIER);
   //printk("PRE-TX Set m_tx_complete false, Was %d\r\n", m_tx_complete);
   m_tx_complete = false;  // Set a flag that will be cleared when the transmission is either complete (plus acknowledgment) or it has failed
   txstatus = nrf_802154_transmit_raw(txdata, NULL);
   if (txstatus == false)  // Failure to transmit
      printk("\r\nTransmit failure\r\n");
// Name  : radio_interface_get_tx_busy
// Desc  : Returns 1 if the radio has not yet completed its transmit (including receiving the hardware ACK if requested)
// Ins   : none
// Outs  : 1 for busy, 0 for not busy
uint8_t radio_interface_get_tx_busy(void)
   if (m_tx_complete == false)
      return 1;
      return 0;
  • It looks like at this point most of the errors I'm seeing are a result of better debug prints in my newer code and not due to the SDK upgrade. This seems like a network traffic issue that wasn't caught before.
    To hopefully further reduce errors, I ended up adding two k_work_delayable elements to help control the rate of back to back radio traffic a little. I'm not sure how much they are helping, but it seems like a reasonable thing to do.
    So now when my app code wants to transmit a packet I have it delay 500us before putting the outgoing data in the workqueue to transmit to give a little more turnaround between receives and transmits. Then when I hit either nrf_802154_transmitted_raw or nrf_802154_transmit_failed I schedule a 1ms delay before I clear my "tx complete" flag, which is what the higher level app is waiting on to know when it's OK to transmit again.
    Here are some new test results from my network containing the gateway I'm working on and 3 wireless nodes, one of which is running my older SDK 2.3 code that did not have the workqueue to serialize radio operations or the new delays my current code does.
    In approximately 3h there were a bit over 900 messages and 50 errors.
    • Error 1: NRF_802154_TX_ERROR_BUSY_CHANNEL, qty 3
    • Error 5: NRF_802154_TX_ERROR_NO_ACK, qty 40
    • Error 6: NRF_802154_TX_ERROR_ABORTED, qty 3
    • TX request while busy 3 (This looks like my app trying to send a packet before the last one has finished going out... I thought this would be impossible with my added delays)
    • Failed to start transmit 1 (nrf_802154_transmit_raw() returned false)
    What do you think about the number and quantity of errors I'm getting for this system?
    Glen
  • Hi again Glen, and thanks for the patience on this,
    It is hard to say that there is nothing that can be changed in the code, but the fact that it worked well in a previous NCS version still makes me not immediately think that this is the problem.
    I agree with you there, and with my assumption of what the issue could've come from, it should've helped. And while on the topic, if nrf_802154_received_raw() was just being started from an IRQ (?) it looks like there is still too much happening there.
    Note btw that you need to initialize the work with k_work_init_delayable, you use k_work_init here which is only for non-delayable work. You can see if changing that makes a difference.
    The code you used should otherwise be the same in the two versions right? And does that count for what situations they are tested in? If let's say the NCS 3.1 version is also tested in a situation with more traffic (and would be in particular need of threads working well together) then it might make sense that it just starts breaking now.
    50/900 doesn't sound like a lot, but I wouldn't simply accept it, of course. You had zero errors in the previous NCS version, right?
    MPSL timing requirements being stricter still sound like a potential reason to me.
    The relevant R&D team doesn't have a clear response to this yet.
    Do you remember if your debug-clean-up removed the same type of errors, or if that was a completely different thing?
    Could you show me how you are doing these delays, just to make sure that you are doing as little as possible in an IRQ?
    Elfving
  • Hi Elfving,
    I'm going to mark this issue as closed - I have it working pretty well now and I think the errors I'm having are within the realm of normal.
    One thing I found out about that was very helpful is that Nordic has an 802.15.4 sniffer I was able to program onto one of my nRF52840 devkits - really helped to see the traffic.
    Thanks for the help!
    Glen
