How to perform an OTA update on the nRF5340 using a PC
Currently, I know that OTA updates for the nRF5340 can be performed using Device Manager and the nRF Connect mobile application. However, if using a PC, is it possible to achieve the same functionality via the command line?
Thanks!!
Mike
  • Hi Mike,
    Is it a Windows PC? There has not been BLE support for this OS in the past, but it looks like that may have changed with the introduction of the smpmgr tool added here: https://github.com/zephyrproject-rtos/zephyr/issues/70871
    - https://github.com/intercreate/smpmgr/releases
    Vidar
  • Hi Vidar,
    Yes, that’s correct. I am trying to run this on a Windows PC.
    I have already installed the smpmgr tool (version 0.17.0) on my Windows PC and attempted to perform FOTA on my nRF5340 device.
    However, I encountered the following issue. The error logs are shown below.
    C:\Users\user>smpmgr --ble E8:B8:C3:0E:CC:23 image upload C:\Users\user\Desktop\Mike\p1_v1.1.2_32M_12pF_dfu_application.zip
    [08:48:32] ERROR    Inspection of FW image failed - image_management:187                         image_management.py:187
                        ╭─────────────────── Traceback (most recent call last) ────────────────────╮
                        │ C:\Users\user\AppData\Local\Programs\Python\Python312\Lib\site-pack │
                        │ ages\smpmgr\image_management.py:184 in upload                            │
                        │   181 │   """Upload a FW image."""                                       │
                        │   182 │        │
                        │   183 │   try:                                                           │
                        │ ❱ 184 │   │   image_info = ImageInfo.load_file(str(file))                │
                        │   185 │   │   logger.info(str(image_info))                               │
                        │   186 │   except Exception:                                              │
                        │   187 │   │   logger.exception("Inspection of FW image failed")          │
                        │ ages\smpclient\mcuboot.py:326 in load_file                               │
                        │   323 │   │   │   │   raise MCUBootImageError(f"hex2bin() ret: {ret}")   │
                        │   324 │   │                                                              │
                        │   325 │   │   f.seek(0)  # move to the start of the image                │
                        │ ❱ 326 │   │   image_header = ImageHeader.load_from(f)                    │
                        │   327 │   │                                                              │
                        │   328 │   │   tlv_offset = image_header.hdr_size + image_header.img_size │
                        │   329        │
                        │ ages\smpclient\mcuboot.py:223 in load_from                               │
                        │   220 │   @staticmethod                                                  │
                        │   221 │   def load_from(file: BytesIO | BufferedReader) -> 'ImageHeader' │
                        │   222 │   │   """Load an `ImageHeader` from an open file."""             │
                        │ ❱ 223 │   │   return ImageHeader.loads(file.read(IMAGE_HEADER_STRUCT.siz │
                        │   224 │        │
                        │   225 │   @staticmethod                                                  │
                        │   226 │   def load_file(path: str) -> 'ImageHeader':                     │
                        │ ages\smpclient\mcuboot.py:205 in loads                                   │
                        │   202 │   │   │   flags,                                                 │
                        │   203 │   │   │   *ver,                                                  │
                        │   204 │   │   ) = IMAGE_HEADER_STRUCT.unpack(data)                       │
                        │ ❱ 205 │   │   return ImageHeader(                                        │
                        │   206 │   │   │   magic=magic,                                           │
                        │   207 │   │   │   load_addr=load_addr,                                   │
                        │   208 │   │   │   hdr_size=hdr_size,                                     │
                        │ ages\pydantic\_internal\_dataclasses.py:121 in __init__                  │
                        │   118 │   def __init__(__dataclass_self__: PydanticDataclass, *args: Any │
                        │       None:                                                              │
                        │   119 │   │   __tracebackhide__ = True                                   │
                        │   120 │   │   s = __dataclass_self__                                     │
                        │ ❱ 121 │   │   s.__pydantic_validator__.validate_python(ArgsKwargs(args,  │
                        │       self_instance=s)                                                   │
                        │   122 │        │
                        │   123 │   __init__.__qualname__ = f'{cls.__qualname__}.__init__'         │
                        │   124        │
                        │ ages\smpclient\mcuboot.py:218 in __post_init__                           │
                        │   215 │   def __post_init__(self) -> None:                               │
                        │   216 │   │   """Do initial validation of the header."""                 │
                        │   217 │   │   if self.magic != IMAGE_MAGIC:                              │
                        │ ❱ 218 │   │   │   raise MCUBootImageError(f"Magic is {hex(self.magic)},  │
                        │       {hex(IMAGE_MAGIC)}")                                               │
                        │   219 │        │
                        MCUBootImageError: Magic is 0x4034b50, expected 0x96f3b83d
    C:\Users\user>
    I am not sure whether I am using the smpmgr tool correctly.
    Thanks!!
    Mike
  • Hi Mike,
    The packaging of the DFU FW image(s) in a .zip (dfu_application.zip) is a nRF connect specific feature that only works with our DFU tools (in our mobile apps). This scripts expect to receive the binary inside the zip.
    Vidar
  • Hi Vidar,
    Are you referring to directly using the zephyr.bin from the example project, or do we need to use additional tools to build the .bin file?
    Thanks!!
    Mike
  • Hi Mike,
    Just extract the dfu_application.zip file and used the bin contained in the folder. Or you can look for zephyr.signed.bin (zephyr.bin is the unsigned application) in build/<app name>/zephyr
