How does one run zephyr/tests/drivers/spi/spi_controller_peripheral on two nRF54LM20-DKs?
As the subject states.
I would like to run the tests at zephyr/tests/drivers/spi/spi_controller_peripheral as intended in testcase.yml. I can verify that I have the correct pins setup, as seen in the SPI traces below.
I've tried using the following:
$> ./scripts/twister --generate-hardware-map map.yml #Creates a map.yml with the two nRF54LM20-DKs currently connected
$> ./scripts/twister --device-testing --hardware-map map.yml -T tests/drivers/spi/spi_controller_peripheral/
But this doesn't run, or flash anything. It appears to skip all tests instead.
I can use the following on both boards to run one of the tests (using the 8MHz overlay), and I can see some good output on the SPI lines with a logic analyzer
$> west build -b nrf54lm20dk/nrf54lm20a/cpuapp . -T drivers.spi.spi_8MHz
$> west flash
But I can't see any test results from ztest. Furthermore, it seems to only run test_basic(), which perhaps fails? Because it only does this once.
Is it possible to run all tests on these two boards? What's the command to do that?
