Control Segger flasher ARM Target Power supply using nRFutil.
Is it possible to enable the Segger Flasher ARM Targer power supply using nRFutil?
We are now using a Segger Relay adapter, but this needs the Flasher's ARM  target supply rail (VTSUPPLY, pin 19) to be enabled.
Normally this can be controlled within J-Flash under "Options->Project Settings->Production-> Target Power Supply", by setting Power source to VTGT.
