cellular iot fundamentals- lesson4 / exercise 1 (build failed)
i'm learning l4/e1 and i'm trying to buid the process after finishing step 10 but the build didn't goes through successfully. i got this errors
my SDK & toolchain version is 3.2.1. i'm using nrf9160dk rev2. please can anyone tell me the solution for this error.
thanks
  • ohh i see thanks, now it works perfectly but i can't see the lesson's output like this one
     *** Booting nRF Connect SDK ***
    [00:00:00.407,379] <inf> Lesson4_Exercise2: Initializing modem library
    [00:00:00.773,895] <inf> Lesson4_Exercise2: Connecting to LTE network
    [00:00:02.101,654] <inf> Lesson4_Exercise2: RRC mode: Connected
    [00:00:03.817,840] <inf> Lesson4_Exercise2: Network registration status: Connected - roaming [00:00:03.817,932] <inf> Lesson4_Exercise2: Connected to LTE network
    [00:00:06.305,725] <inf> Lesson4_Exercise2: Connected to MQTT broker
    [00:00:06.305,755] <inf> Lesson4_Exercise2: Hostname: mqtt.nordicsemi.academy
    [00:00:06.305,786] <inf> Lesson4_Exercise2: Client ID: nrf-355025930008030
    [00:00:06.305,786] <inf> Lesson4_Exercise2: Port: 8883
    [00:00:06.305,816] <inf> Lesson4_Exercise2: TLS: Yes
    [00:00:06.305,847] <inf> Lesson4_Exercise2: Subscribing to devacademy/subscribe/topic [00:00:06.421,722] <inf> Lesson4_Exercise2: Subscribed to devacademy/subscribe/topic with QoS 0 [00:00:09.013,061] <inf> Lesson4_Exercise2: RRC mode: Idle
    i only can see this screenshot output.
  • Hi Vivek,
    I believe that what you are seeing is what comes after the logs that you want to see. The Serial port doesn't wait for you to connect, if nothing is connected to the port, it will just get forgotten.
    So if you keep the serial connection connected and reset the board by pressing the reset button, you should be able to see the logs you want to see.
    Another thing that you can see, is the time code in front of the logs. These are the up-time of the chip at the moment of the log. In the example you can see that it all happens in the first 10 seconds, but in your case you are already past 20 minutes.
    I hope I was able to help you!
    Simon D-M
  • hi,
    i got the output that i want. yes, you're right i can see that in the first 10 seconds.
    i really appreciate you to help me and solve the issue that i had.
    thanks
    vivek
