Commands to set RF test
Dear Nordic,
I got some AT commands here <https://docs.nordicsemi.com/bundle/ref_at_commands_nrf91x1/page/REF/at_commands/production_test/xrftest_tx_set.html> to know that AT%XRFTEST=<test>,<operation>[,<param0>,<param1>,<param2>], this set command controls the RF transmitter. This command is to let the Dev Kit transmit the RF signal, and the signal is modulation signal, right? may I know if there is some other commands which can let the Dev Kit transmit out Continuous Sine Wave signal and receive CSW signal?
Thank you so much!
Hansen Wei
[email protected]
    The signal sent by this command in the normal modem firmware is a Carrier Wave signal (link). I don't think there should be any modulation while transmitting with that command.
    %XRFTEST in the normal modem firmware has very few parameters because it was made as an easy-to-use command. If you need more parameters you can always use the PTI modem firmware which has a more complete %XRFTEST command with a lot more parameters.
    I hope I was able to help you.
    Simon D-M
