Hi Nordic folks,
I'm trying to get the nrf54L15 in a Fanstel BM15M to go into the system OFF state and be woken up later by a timer. All the documentation I've seen says there's an internal LRFC that can be used, and that an external crystal is not required. After a couple of days of attempting many solutions and tests, I have not been able to get it to do so.
Context
Custom board based on BM15M module (nRF54L15). No external 32.768 kHz crystal. NCS v3.0.2, nRF54L15 (HALTIUM family).
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y→ Zephyr GRTC driver selectsCLKCFG.CLKSEL=LFLPRCCONFIG_POWEROFF=y,CONFIG_NRF_GRTC_START_SYSCOUNTER=y
What We Tried
Used z_nrf_grtc_wakeup_prepare(N) followed immediately by sys_poweroff(). No Zephyr timer calls between the two — all inter-call delays use k_busy_wait only.
Register State Immediately Before sys_poweroff()
Read back via direct register access (NRF_GRTC->MODE and NRF_GRTC->CLKCFG) and reported via backlight blink codes. Confirmed:
- MODE.AUTOEN = 0 (SYSCOUNTER always-on ✓)
- MODE.SYSCOUNTEREN = 1 (SYSCOUNTER running ✓)
- CLKCFG.CLKSEL = 2 (LFLPRC ✓)
z_nrf_grtc_wakeup_prepare() returned 0 (success). CC compare set to T+15 seconds, with sufficient k_busy_wait latching time after wakeup_prepare.
Observed Behavior
J-Link was disconnected (battery power only → real System OFF, not simulated WFE loop). Device enters System OFF. After 15 seconds: no cold reset. Device remains in System OFF. RESET_CLOCK bit never appears in RESETREAS.
Previous Hypotheses Eliminated
- CCEN=1 required for wake: Enabled CCEN on all 12 channels before poweroff → no change
- J-Link causing simulated System OFF: Disconnected J-Link and repeated → still no wake
- AUTOEN not 0: Register readback confirmed AUTOEN=0
- CLKSEL wrong: Register readback confirmed CLKSEL=LFLPRC=2
Root Cause Hypothesis
LFLPRC does not actually run in System OFF on nRF54L15, despite:
nrf_grtc_timer.cexplicitly settingCLKCFG.CLKSEL=LFLPRCwhenK32SRC_RC=y- LFLPRC being described as a low-power oscillator intended for System OFF
Supporting evidence: The Nordic system_off sample targets nRF54L15dk (nrf54l15dk/nrf54l15/cpuapp). A prior build of that sample on this machine shows CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y — the nRF54L15 DK uses an external LFXO crystal, not LFLPRC. The sample GRTC wake test is only validated on boards with a crystal.
Questions for Nordic
Does LFLPRC actually keep running during nRF54L15 System OFF? Can GRTC generate a System OFF wake event when
CLKCFG.CLKSEL=LFLPRC? -
Is there an additional initialization step required to keep LFLPRC alive across System OFF — e.g., a specific NRFS request, SYSCTRL domain retention register, or GRTC
active_requestthat must be made beforesys_poweroff()? -
Is
NRF_GRTC_CLKSEL_LFLPRC(value 2) intended to work for System OFF wake, or only for WFI sleep? The Zephyrnrf_grtc_timer.cdriver sets this whenK32SRC_RC=y, andz_nrf_grtc_wakeup_prepare()relies on it — if LFLPRC doesn't run in System OFF, this API silently does nothing on no-crystal boards. -
The Nordic DevZone references LFXO as the only System OFF GRTC clock source (devzone.nordicsemi.com/f/nordic-q-a/117845/grtc-feature-of-nrf54l15). Is this correct for nRF54L15, or is LFLPRC a valid alternative?
Build Configuration (Relevant Kconfig)
CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
CONFIG_NRF_GRTC_TIMER_AUTO_KEEP_ALIVE=y
CONFIG_NRF_GRTC_TIMER_CLOCK_MANAGEMENT=y
CONFIG_POWEROFF=y
Next Steps (Pending Nordic Clarification)
- If LFLPRC cannot be used: add LFXO (XL1/XL2 pins) on V7 board revision
- If initialization step is missing: apply fix and re-test
- Current workaround:
k_sleep()(WFI) for timer-based CTP polling (~987µA vs ~184µA System OFF)
All the documentation I've read said an external crystal is not required, and so I'm trying to nail this down before I do another PCB revision.
Steve
