QSPI Flash Failure on nRF5340 When CPU Runs at 128 MHz
Hi nordic team
I am working with the Nordic nRF5340 SoC using Zephyr RTOS.
Hardware
External QSPI flash:
  • MX25R6435F
QSPI configuration (DeviceTree):
&qspi {
    status = "okay";
    pinctrl-0 = <&qspi_default>;
    pinctrl-1 = <&qspi_sleep>;
    mx25r64: mx25r6435f@0 {
        compatible = "nordic,qspi-nor";
        reg = <0>;
        sck-frequency = <32000000>;
        readoc = "read4io";
        jedec-id = [ c2 20 1a  ];
        /delete-property/ sfdp-bfp;
        size = <536870912>;
        address-size-32;
        enter-4byte-addr = <0x01>;
        has-dpd;
        t-enter-dpd = <10000>;
        t-exit-dpd = <35000>;
        status = "okay";
        partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            /* 0x00000000 - 0x007FFFFF : 8MB raw I2S / reserved */
            raw_rec_part: partition@0 {
                label = "raw_rec";
                reg = <0x00000000 0x00800000>;
            /* 0x00800000 - 0x03FFFFFF: 56MB FATFS */
            fatfs_part: partition@800000 {
                label = "fatfs";
                reg = <0x00800000 0x03800000>;
 the QSPI SCK clock = 32 MHz.
The application core CPU frequency = 128 MHz.
I am configuring the CPU to run at 128 MHz uisng the below api
void set_cpu_128mhz(void)
    // Direct register access to set the clock divider to 1 (128MHz)
    // 0 = 128MHz, 1 = 64MHz
    NRF_CLOCK_S->HFCLKCTRL = 0;
    // Update the system variable so timing functions (like your us conversion) are accurate
    SystemCoreClockUpdate();
    printf("SystemCoreClock: %u MHz\n", (unsigned int)(SystemCoreClock / 1000000));
Issue observed :
When the CPU runs at 128 MHz:
  • Flash read operations fail
  • Flash write operations fail
why QSPI flash read/write fails when the CPU runs at 128 MHz while the QSPI SCK is configured at 32 MHz?
Any insights on this issue would be helpful.
