QSPI flash hangs after BLE bonding on nRF54L15 (sQSPI / LittleFS)
We are experiencing an issue with the QSPI driver on nRF54L15 where external flash access stops working after a BLE bonding procedure.
The system works correctly until bonding occurs. After a mobile device bonds with the board, any access to external flash via QSPI becomes unusable and the calling thread hangs indefinitely.
During investigation we temporarily added a guard/timeout around the _ASB(...) macro inside the driver. With this modification the driver sometimes returns:
flash_mspi_nor: perform_xfer: transceive() failed: -116
However, without this modification the system hangs indefinitely.
Hardware
  • Board: nRF54L15-DK
  • External flash: MX25R6435F
  • Interface: QSPI (quad mode)
The flash wiring matches the reference design used on the development kit.
Software
  • nRF Connect SDK project built from command line
  • File system: LittleFS over sQSPI flash
  • Application features:
    • BLE advertising
    • BLE connections
    • BLE bonding
    • shell commands for NVM access
Steps to Reproduce
  1. Start BLE advertising
  1. Connect from a mobile device.
  2. Perform bonding.
  3. Execute any command that accesses external flash.
Observed Behavior
External flash works correctly in the following situations:
  • before BLE advertising
  • while advertising (most of the time)
  • while a mobile device is connected but not bonded
After bonding, access to external flash becomes unusable.
When a command attempts to access flash (e.g. nvm ls), the thread performing the operation hangs indefinitely.
When a temporary timeout was added around _ASB(...), the operation sometimes fails with:
But without this modification the system deadlocks.
Expected Behavior
External flash access over QSPI should continue working normally regardless of BLE bonding state.
Bonding a BLE device should not affect the operation of the external flash driver.
Workaround
Switching the external flash interface from QSPI to hardware SPI (single line) avoids the issue.
With SPI the flash works correctly even after BLE bonding.
However, this significantly reduces flash throughput compared to QSPI.
Additional Observations
While debugging with a debugger attached, the blocked execution appeared to be stuck inside the _ASB(...) macro. This observation is not fully confirmed, but it appeared consistently when inspecting the hanging thread.
Things Already Tested
We tried the following without resolving the issue:
Disable auto runtime PM for sQSPI
Lowering the operational frequency down to 1MBit
Disable Deep Power Down for MX25R6435F
(removed the following from dts):
has-dpd
t-enter-dpd
t-exit-dpd
reset timings
The issue still occurs.
If possible, could you please help investigate why BLE bonding affects QSPI flash access on nRF54L15?
Device Tree, part related to sqspi configuration:
&sqspi {
	mx25r64: mx25r6435f@0 {
		compatible = "mxicy,mx25r", "jedec,mspi-nor";
		status = "okay";
		reg = <0>;
		jedec-id = [c2 28 17];
		quad-enable-requirements = "S1B6";
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <DT_SIZE_M(64)>; /* 8 MB (64 Mbit) */
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
		t-reset-pulse = <10000>;
		t-reset-recovery = <35000>;
		mspi-max-frequency = <DT_FREQ_M(80)>;
		mspi-io-mode = "MSPI_IO_MODE_QUAD_1_4_4";
		mspi-data-rate = "MSPI_DATA_RATE_SINGLE";
		mspi-hardware-ce-num = <1>;
		mspi-cpp-mode = "MSPI_CPP_MODE_0";
		mspi-endian = "MSPI_BIG_ENDIAN";
		mspi-ce-polarity = "MSPI_CE_ACTIVE_LOW";
		transfer-timeout = <100>;
    Thanks for the detailed report. Before I attempt to investigate this further, could you please confirm if the bonding data (settings_storage) is located in the internal or external memory?
    Thank you,
    Vidar
    In an internal storage, as could be seen from generated `partitions.yml` below.
    app:
      address: 0x0
      end_address: 0x17b000
      region: flash_primary
    bootconf:
      address: 0xffd080
      end_address: 0xffd084
      region: bootconf
    external_flash:
      address: 0x0
      device: MX25R64
      end_address: 0x800000
      region: external_flash
    littlefs_storage:
      address: 0x0
      device: MX25R64
    otp:
      address: 0xffd500
      end_address: 0xffd9fc
      region: otp
    settings_storage:
      address: 0x17b000
      end_address: 0x17d000
      placement:
        after:
        - app
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x2003c000
      region: sram_primary
    I hope it helps. let me know if you need any additional information, please
    The only relation I could think of between the bonding procedure and littlefs was if both were trying to store something to the same flash device and there was some potential issue with concurrency handling. Would you be able to provide a minimal project here or in a private ticket that would allow me to reproduce this issue here on a nRF54L15 DK?
    Vidar
    EDIT: Please also let me know what SDK version you are using. Perhaps the issue you are seeing may have been fixed in a later version?
  • Don't know if related but we also see sQSPI hangs, although on the LM20 rather than L15. See
    devzone.nordicsemi.com/.../nrf54lm20-sqspi-lock-ups
  • We're also having problems with external flash not working after BT bonding. The external flash is using the FLPR soft peripheral. We can access the flash OK, but BT bonding is unable to save the keys.
    *** Using Zephyr OS v4.1.99-ff8f0c579eeb *** [00:00:02.271,158] ble: ble addr: 27:43:C5:46:40:E1 [00:00:02.271,360] main: BT mac addr: 27:43:C5:46:40:E1 [00:00:02.271,603] littlefs_storage: little_fs_test: Test r/w files on littlefs [00:00:02.285,021] littlefs_storage: fs_statvfs, mount: /lfs1: block sz: 16; frag sz: 65536; blocks: 64; free blks: 59 [00:00:02.285,357] littlefs_storage: storage free space: 944 [00:00:02.285,616] littlefs_storage: little_fs_test: lfs_fs_stat, blocks: 0; size: 91389; vers: 131073; max name 0 [00:00:02.440,956] imu: IMU thread started [00:00:05.270,921] nus: streaming data task start.. [00:10:01.129,651] main: clock time: 01/01/1970 00:10:01 [00:10:01.541,810] flash_mspi_nor: perform_xfer: transceive() failed: -116 [00:10:01.542,072] flash_mspi_nor: Read xfer failed: -116 [00:10:01.542,327] fs: file open error (-5) [00:10:01.542,567] ble: BT connected [00:10:01.659,059] ble: Security changed: 14:14:7D:95:6F:46 (public) level 4 [00:10:02.318,750] ble: MTU exchanged: 247 [00:10:02.319,263] bt_l2cap: Ignoring data for unknown channel ID 0x003a [00:10:02.320,476] littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:1386: Corrupted dir pair at {0x1, 0x0} [00:10:02.320,804] fs: file open error (-14) [00:10:03.549,018] nus: NUS notify - Enabled [00:10:03.609,015] nus: nus_data_rcvd: nus data received, command 0x1, len 5
