QSPI flash hangs after BLE bonding on nRF54L15 (sQSPI / LittleFS)
We are experiencing an issue with the QSPI driver on nRF54L15 where external flash access stops working after a BLE bonding procedure.
The system works correctly until bonding occurs. After a mobile device bonds with the board, any access to external flash via QSPI becomes unusable and the calling thread hangs indefinitely.
During investigation we temporarily added a guard/timeout around the _ASB(...) macro inside the driver. With this modification the driver sometimes returns:
flash_mspi_nor: perform_xfer: transceive() failed: -116
However, without this modification the system hangs indefinitely.
Hardware
  • Board: nRF54L15-DK
  • External flash: MX25R6435F
  • Interface: QSPI (quad mode)
The flash wiring matches the reference design used on the development kit.
Software
  • nRF Connect SDK project built from command line
  • File system: LittleFS over sQSPI flash
  • Application features:
    • BLE advertising
    • BLE connections
    • BLE bonding
    • shell commands for NVM access
Steps to Reproduce
  1. Start BLE advertising
  1. Connect from a mobile device.
  2. Perform bonding.
  3. Execute any command that accesses external flash.
Observed Behavior
External flash works correctly in the following situations:
  • before BLE advertising
  • while advertising (most of the time)
  • while a mobile device is connected but not bonded
After bonding, access to external flash becomes unusable.
When a command attempts to access flash (e.g. nvm ls), the thread performing the operation hangs indefinitely.
When a temporary timeout was added around _ASB(...), the operation sometimes fails with:
But without this modification the system deadlocks.
Expected Behavior
External flash access over QSPI should continue working normally regardless of BLE bonding state.
Bonding a BLE device should not affect the operation of the external flash driver.
Workaround
Switching the external flash interface from QSPI to hardware SPI (single line) avoids the issue.
With SPI the flash works correctly even after BLE bonding.
However, this significantly reduces flash throughput compared to QSPI.
Additional Observations
While debugging with a debugger attached, the blocked execution appeared to be stuck inside the _ASB(...) macro. This observation is not fully confirmed, but it appeared consistently when inspecting the hanging thread.
Things Already Tested
We tried the following without resolving the issue:
Disable auto runtime PM for sQSPI
Lowering the operational frequency down to 1MBit
Disable Deep Power Down for MX25R6435F
(removed the following from dts):
has-dpd
t-enter-dpd
t-exit-dpd
reset timings
The issue still occurs.
If possible, could you please help investigate why BLE bonding affects QSPI flash access on nRF54L15?
Device Tree, part related to sqspi configuration:
&sqspi {
	mx25r64: mx25r6435f@0 {
		compatible = "mxicy,mx25r", "jedec,mspi-nor";
		status = "okay";
		reg = <0>;
		jedec-id = [c2 28 17];
		quad-enable-requirements = "S1B6";
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <DT_SIZE_M(64)>; /* 8 MB (64 Mbit) */
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
		t-reset-pulse = <10000>;
		t-reset-recovery = <35000>;
		mspi-max-frequency = <DT_FREQ_M(80)>;
		mspi-io-mode = "MSPI_IO_MODE_QUAD_1_4_4";
		mspi-data-rate = "MSPI_DATA_RATE_SINGLE";
		mspi-hardware-ce-num = <1>;
		mspi-cpp-mode = "MSPI_CPP_MODE_0";
		mspi-endian = "MSPI_BIG_ENDIAN";
		mspi-ce-polarity = "MSPI_CE_ACTIVE_LOW";
		transfer-timeout = <100>;
