QSPI flash hangs after BLE bonding on nRF54L15 (sQSPI / LittleFS)
We are experiencing an issue with the QSPI driver on nRF54L15 where external flash access stops working after a BLE bonding procedure.
The system works correctly until bonding occurs. After a mobile device bonds with the board, any access to external flash via QSPI becomes unusable and the calling thread hangs indefinitely.
During investigation we temporarily added a guard/timeout around the _ASB(...) macro inside the driver. With this modification the driver sometimes returns:
flash_mspi_nor: perform_xfer: transceive() failed: -116
However, without this modification the system hangs indefinitely.
Hardware
  • Board: nRF54L15-DK
  • External flash: MX25R6435F
  • Interface: QSPI (quad mode)
The flash wiring matches the reference design used on the development kit.
Software
  • nRF Connect SDK project built from command line
  • File system: LittleFS over sQSPI flash
  • Application features:
    • BLE advertising
    • BLE connections
    • BLE bonding
    • shell commands for NVM access
Steps to Reproduce
  1. Start BLE advertising
  1. Connect from a mobile device.
  2. Perform bonding.
  3. Execute any command that accesses external flash.
Observed Behavior
External flash works correctly in the following situations:
  • before BLE advertising
  • while advertising (most of the time)
  • while a mobile device is connected but not bonded
After bonding, access to external flash becomes unusable.
When a command attempts to access flash (e.g. nvm ls), the thread performing the operation hangs indefinitely.
When a temporary timeout was added around _ASB(...), the operation sometimes fails with:
But without this modification the system deadlocks.
Expected Behavior
External flash access over QSPI should continue working normally regardless of BLE bonding state.
Bonding a BLE device should not affect the operation of the external flash driver.
Workaround
Switching the external flash interface from QSPI to hardware SPI (single line) avoids the issue.
With SPI the flash works correctly even after BLE bonding.
However, this significantly reduces flash throughput compared to QSPI.
Additional Observations
While debugging with a debugger attached, the blocked execution appeared to be stuck inside the _ASB(...) macro. This observation is not fully confirmed, but it appeared consistently when inspecting the hanging thread.
Things Already Tested
We tried the following without resolving the issue:
Disable auto runtime PM for sQSPI
Lowering the operational frequency down to 1MBit
Disable Deep Power Down for MX25R6435F
(removed the following from dts):
has-dpd
t-enter-dpd
t-exit-dpd
reset timings
The issue still occurs.
If possible, could you please help investigate why BLE bonding affects QSPI flash access on nRF54L15?
Device Tree, part related to sqspi configuration:
&sqspi {
	mx25r64: mx25r6435f@0 {
		compatible = "mxicy,mx25r", "jedec,mspi-nor";
		status = "okay";
		reg = <0>;
		jedec-id = [c2 28 17];
		quad-enable-requirements = "S1B6";
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <DT_SIZE_M(64)>; /* 8 MB (64 Mbit) */
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
		t-reset-pulse = <10000>;
		t-reset-recovery = <35000>;
		mspi-max-frequency = <DT_FREQ_M(80)>;
		mspi-io-mode = "MSPI_IO_MODE_QUAD_1_4_4";
		mspi-data-rate = "MSPI_DATA_RATE_SINGLE";
		mspi-hardware-ce-num = <1>;
		mspi-cpp-mode = "MSPI_CPP_MODE_0";
		mspi-endian = "MSPI_BIG_ENDIAN";
		mspi-ce-polarity = "MSPI_CE_ACTIVE_LOW";
		transfer-timeout = <100>;
    I have tried to reproduce this with SDK v3.3.0 and a nRF54l15 DK target, but without any luck. I am including the test sample I used if you want to try with the same project.
    ble_lbs_sqspi.zip
    Note: this test sample was created with the help of Cursor and I have not gone through and reviewed everything.
    Vidar
  • Hello, Vidar!
    I have worked with this bug and was able to find the possible reason. External flash access hang was observed after the BLE bonding procedure with Device Runtime Power Management enabled:
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    The hang disappeared after I disabled CONFIG_PM_DEVICE_RUNTIME and external flash worked well before the first reset. After device reset, on any external flash operation I am getting:
    [00:00:03.699,786] <err> flash_mspi_nor: perform_xfer: transceive() failed: -116
    [00:00:03.699,812] <err> flash_mspi_nor: Read xfer failed: -116
    [00:00:03.699,843] <err> nvm_storage: nvm_storage: opendir failed /nvm, rc=-5
    I was able to reproduce this issue in a sample project, however, the behavior is slightly different: I am constantly getting:
    after BLE bonding and device reset. I suppose this issue is strongly connected with original one, since it can be fixed by disabling Device Runtime Power Management and removing BLE advertising.
    I believe that the issue is caused by BLE/MPSL interaction with the FLPR. Please find the sample attached.
    mqspi_ble_bonding_bug.zip
  • Hello!
    Thank you for providing us with a test sample that should allow us to replicate the issue on our side. The fact that it only fails with CONFIG_PM_DEVICE_RUNTIME enabled should be a really helpful clue. I have forwarded it to one of the developers who works on these drivers. He will try to have a look at it soon. I will update this thread as soon as I know more.
    Vidar
  • I also wanted to add I am seeing a similar issue with sQSPI and bonding. sQSPI transfers are consistently aborted when advertising only but only when two things are present:
    CONFIG_BT_CTLR_PRIVACY=y
    And at least 1 bond present on flash (external)
    My hunch is that each MPSL adv interrupt is taking slightly longer with privacy enabled causing sQSPI IRQ to not be serviced in time.
  • Vidar is currently away.
    The team believe they have been able to replicate the issue now, they will continue to understand the root cause and possible fix. I don't have a timeline for this work at the moment, but I will keep you updated.
    Kenneth
