I've recently received a custom board I've designed and am programming with the nRF52DK, following the procedure in L3 E1 of the SDK intermediate course. I've flashed the Zephyr Beacon example successfully to the board and have tried analysing with the nRF connect app on my phone. I'm unable to see my device with the phone but can see when using the development kit. I've uploaded screenshots of the schematic and design, along with the terminal output from visual studio.
Executing task: nRF Connect: Build [incremental]: beacon_2/build
Building beacon_2
west build --build-dir c:/Users/S3872174/Workstation/beacon_2/build c:/Users/S3872174/Workstation/beacon_2
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/Users/S3872174/Workstation/beacon_2
-- CMake version: 3.21.0
-- Cache files will be written to: C:/Users/S3872174/Workstation/zephyr/.cache
-- Zephyr version: 3.5.99 (C:/Users/S3872174/Workstation/zephyr)
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: BTNRF52832
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/66cdf9b75e/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/66cdf9b75e/opt/zephyr-sdk)
-- Found BOARD.dts: C:/Users/S3872174/Workstation/CustomBoards/boards/arm/BTNRF52832/BTNRF52832.dts
-- Generated zephyr.dts: C:/Users/S3872174/Workstation/beacon_2/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Users/S3872174/Workstation/beacon_2/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Users/S3872174/Workstation/beacon_2/build/zephyr/dts.cmake
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
Parsing C:/Users/S3872174/Workstation/zephyr/Kconfig
Loaded configuration 'C:/Users/S3872174/Workstation/CustomBoards/boards/arm/BTNRF52832/BTNRF52832_defconfig'
Merged configuration 'C:/Users/S3872174/Workstation/beacon_2/prj.conf'
Merged configuration 'C:/Users/S3872174/Workstation/beacon_2/build/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/S3872174/Workstation/beacon_2/build/zephyr/.config'
Kconfig header saved to 'C:/Users/S3872174/Workstation/beacon_2/build/zephyr/include/generated/autoconf.h'
CMake Warning at C:/Users/S3872174/Workstation/zephyr/CMakeLists.txt:862 (message):
No SOURCES given to Zephyr library: drivers__console
Excluding target from build.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/S3872174/Workstation/beacon_2/build
[167/167] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 84312 B 512 KB 16.08%
RAM: 21424 B 64 KB 32.69%
IDT_LIST: 0 GB 32 KB 0.00%
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Flash: beacon_2/build
Flashing build to nRF52 DK
west flash -d c:\Users\S3872174\Workstation\beacon_2\build --dev-id 1050325190
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: c:\Users\S3872174\Workstation\beacon_2\build\zephyr\zephyr.hex
[ ###### ] 0.000s | Erase file - Check image
[ ##### ] 0.000s | Check image validity - Initialize device info
[ ########## ] 0.000s | Check image validity - Check region 0 settings
[ ############### ] 0.000s | Check image validity - block 1 of 2
[ #################### ] 0.014s | Check image validity - Finished
[ ############# ] 0.000s | Erase file - Erasing
[ ########## ] 0.000s | Erasing non-volatile memory - block 1 of 1
[ #################### ] 0.000s | Erasing non-volatile memory - Erase successful
[ #################### ] 0.868s | Erase file - Done erasing
[ ###### ] 0.000s | Program file - Checking image
[ ############### ] 0.357s | Check image validity - block 1 of 2
[ #################### ] 0.005s | Check image validity - Finished
[ ############# ] 0.000s | Program file - Programming
[ ########## ] 0.000s | Programming image - block 1 of 1
[ #################### ] 0.000s | Programming image - Write successful
[ #################### ] 1.533s | Program file - Done programming
[ ###### ] 0.000s | Verify file - Check image
[ ############### ] 0.908s | Check image validity - block 1 of 2
[ #################### ] 0.009s | Check image validity - Finished
[ ############# ] 0.000s | Verify file - Verifying
[ ########## ] 0.000s | Verifying image - block 1 of 1
[ #################### ] 0.000s | Verifying image - Verify successful
[ #################### ] 0.571s | Verify file - Done verifying
Enabling pin reset.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 1050325190 flashed successfully.
- with Custom Board powered
- without Custom Board
