Grant nRF5340 NET core EasyDMA access to APP core SRAM0, or APP core read access to NET core SRAM1
Hardware: nRF5340 DK
nRF Connect SDK: v2.6.1
Description:
I am working on a project where there is a need to transfer a large amount of data from NET to APP core. We would like to bypass the hci_ipc service for some reason.
I was following a similar way provided in nrf_dm sample:
  1. reduce the 64KB reserved shared-memory region &sram0_shared used by IPC from (0x20070000~0x20080000 size: 64KB for rpmsg_nrf53_sram) to (0x20070000~0x2007c000 size: 48KB)
  2. add another section (0x2007c000~0x20080000 size: 16KB) for our proprietary use, so that both cores have write and read access to the 16KB shared-ram region.
And it did work.
Now I want the NET core to be able to set EasyDMA to a buffer in that shared-ram region, but it turns out NET EasyDMA can only point to its own SRAM1 (0x21000000~0x21010000 size: 64KB).
Questions:
1. Is there a way to make NET core EasyDMA point to the shared region 0x2007c000~0x20080000 on SRAM0?
2. Is there a way to grant APP core access to SRAM1 (0x21000000~0x21010000)? I am planning to have a 16KB section reserved in NET core SRAM1 as shared-sram between two cores. Granting APP core read access to SRAM1 is good enough, and it would be perfect if with write access available as well.
