LE audio: Simultaneous Broadcast Sink and Broadcast Source
Is it possible to configure an nRF5340 to be both a Broadcast Sink and a Broadcast Source, but with the condition that only frames received by the Broadcast Sink are sent ("relayed") to the Broadcast Source?
So long as the data stream is compressed, there should be sufficient bandwidth, but can the SD Controller support this configuration?
A simple test with NCS 3.2.0 and SD Controller received and sent data, however the received stream was unstable (100ms or so gaps in data received from Controller after some minutes followed by bursts of invalid frames).
Thank you,
Carl
  • Hello Maria,
    Two example apps were created based on:
    zephyr/samples/bluetooth/bap_broadcast_source
    zephyr/samples/bluetooth/bap_broadcast_sink
    Environment:
    NCS 3.2.0
    nRF7002DK
    bap_broadcast_source was modified to send 1 BIS forever.
    bap_broadcast_sink had two build versions:
    1. Standard Broadcast Sink
    2. Modified Broadcast Sink with Broadcast Source
    For initial testing, the Broadcast Source was minimal.
    Ext Adv and Per Adv were sent, but no BAP stream data was sent from Host to Controller.
    It was expected that SD Controller would send empty frames.
    1 was run for over 1 hour without any issues.
    2 was run for about 12 minutes before failing
    Here is a log snippet for 2. Many frames are lost (every other frame) after the end of log.
    Please let me know if you would like source, binaries or both and how I can best provide them.
    Thank you,
    Carl
    SEGGER J-Link V8.76 - Real time terminal output
    SEGGER J-Link (unknown) V1.0, SN=1050724893
    Process: JLink.exe
    *** Booting nRF Connect SDK v3.2.0-5dcc6bd39b0f ***
    *** Using Zephyr OS v4.2.99-a57ad913cf4e ***
    [00:00:18.613,891] <wrn> bt_hci_core: Num of Controller's ISO packets != ISO bt_conn_tx contexts(3 != 5)
    [00:00:18.619,567] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:18.619,598] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
    [00:00:18.619,628] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 155.44175 Build 2923568579
    [00:00:18.622,619] <inf> bt_hci_core: HCI transport: IPC
    [00:00:18.622,802] <inf> bt_hci_core: Identity: C8:49:91:D2:14:14 (random)
    [00:00:18.622,833] <inf> bt_hci_core: HCI: version 6.2 (0x10) revision 0x2020, manufacturer 0x0059
    [00:00:18.622,863] <inf> bt_hci_core: LMP: version 6.2 (0x10) subver 0x2020
    Bluetooth initialized
    [00:00:18.622,985] <inf> lc3: LC3 initialized
    Reset
    Scanning for broadcast sources
    Waiting for Broadcaster
    addr 2C:E7:07:FB:0B:D4 (random), RSSI: -42
    Found broadcaster with ID 0x123456 and addr 2C:E7:07:FB:0B:D4 (random) and sid 0x00
    broadcaster_broadcast_id = 0x123456
    Attempting to PA sync to the broadcaster with id 0x123456
    Waiting for PA synced
    PA sync 0x2000abb8 synced for broadcast sink with broadcast ID 0x123456
    Broadcast source PA synced, creating Broadcast Sink
    Broadcast Sink created, waiting for BASE
    Received BASE with 1 subgroups from broadcast sink 0x2000b980
    Channel allocation (subgroup level) 0x00000001
    BIS index 0x00000001 allocation = 0x00000001
    Broadcast sink (0x2000b980) is syncable, BIG not encrypted
    BASE received, waiting for syncable
    Waiting for broadcast code
    Waiting for BIS sync request
    Syncing to broadcast with bitfield: 0x00000001, stream_count = 1
    Waiting for stream(s) started
    Stream 0x2000588c connected
    Stream 0x2000588c started with BIG_Handle 0 and BIS_Number 1
    [00:00:30.840,942] <inf> lc3: Initializing the LC3 decoder with 10000 us duration and 16000 Hz frequency
    [00:00:30.841,247] <inf> lc3: Initialized LC3 decoder for 0x2000588c
    Broadcast sink 0x2000b980 started
    Audio Relay initialized
    Broadcast source created and started
    Relay extended advertising started
    Waiting for PA disconnected
    ***Source stream 0x20005534 started
    [00:00:30.850,097] <inf> stream_rx: [1]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 17377 and ts 12244507: Valid 1 | Error 0 | Loss 0 | Dup TS 0 | Dup PSN 0
    [00:00:38.060,241] <inf> stream_rx: [721]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 18097 and ts 19444583: Valid 720 | Error 0 | Loss 1 | Dup TS 0 | Dup PSN 0
    [00:00:40.840,179] <inf> stream_rx: [1000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 18376 and ts 22234615: Valid 999 | Error 0 | Loss 1 | Dup TS 0 | Dup PSN 0
    [00:00:45.260,314] <inf> stream_rx: [1441]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 18817 and ts 26644661: Valid 1439 | Error 0 | Loss 2 | Dup TS 0 | Dup PSN 0
    [00:00:50.840,362] <inf> stream_rx: [2000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 19376 and ts 32234722: Valid 1998 | Error 0 | Loss 2 | Dup TS 0 | Dup PSN 0
    [00:00:52.460,601] <inf> stream_rx: [2161]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 19537 and ts 33844739: Valid 2158 | Error 0 | Loss 3 | Dup TS 0 | Dup PSN 0
    [00:00:59.370,483] <inf> stream_rx: [2852]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20228 and ts 40754813: Valid 2848 | Error 0 | Loss 4 | Dup TS 0 | Dup PSN 0
    [00:00:59.660,491] <inf> stream_rx: [2881]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20257 and ts 41044815: Valid 2876 | Error 0 | Loss 5 | Dup TS 0 | Dup PSN 0
    [00:01:00.840,393] <inf> stream_rx: [3000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 20376 and ts 42234829: Valid 2995 | Error 0 | Loss 5 | Dup TS 0 | Dup PSN 0
    [00:01:06.860,565] <inf> stream_rx: [3601]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20977 and ts 48244894: Valid 3595 | Error 0 | Loss 6 | Dup TS 0 | Dup PSN 0
    [00:01:10.840,515] <inf> stream_rx: [4000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 21376 and ts 52234936: Valid 3994 | Error 0 | Loss 6 | Dup TS 0 | Dup PSN 0
    [00:01:14.060,638] <inf> stream_rx: [4321]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 21697 and ts 55444970: Valid 4314 | Error 0 | Loss 7 | Dup TS 0 | Dup PSN 0
    [00:01:20.840,606] <inf> stream_rx: [5000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 22376 and ts 62235043: Valid 4993 | Error 0 | Loss 7 | Dup TS 0 | Dup PSN 0
    [00:01:21.260,711] <inf> stream_rx: [5041]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22417 and ts 62645047: Valid 5033 | Error 0 | Loss 8 | Dup TS 0 | Dup PSN 0
    [00:01:28.460,784] <inf> stream_rx: [5761]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23137 and ts 69845125: Valid 5752 | Error 0 | Loss 9 | Dup TS 0 | Dup PSN 0
    [00:01:30.840,942] <inf> stream_rx: [6000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 23376 and ts 72235151: Valid 5991 | Error 0 | Loss 9 | Dup TS 0 | Dup PSN 0
    [00:01:35.660,858] <inf> stream_rx: [6481]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23857 and ts 77045203: Valid 6471 | Error 0 | Loss 10 | Dup TS 0 | Dup PSN 0
    [00:01:40.840,820] <inf> stream_rx: [7000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 24376 and ts 82235258: Valid 6990 | Error 0 | Loss 10 | Dup TS 0 | Dup PSN 0
    [00:01:42.860,931] <inf> stream_rx: [7201]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 24577 and ts 84245279: Valid 7190 | Error 0 | Loss 11 | Dup TS 0 | Dup PSN 0
    [00:01:50.061,035] <inf> stream_rx: [7921]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 25297 and ts 91445357: Valid 7909 | Error 0 | Loss 12 | Dup TS 0 | Dup PSN 0
    [00:01:50.840,942] <inf> stream_rx: [8000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 25376 and ts 92235365: Valid 7988 | Error 0 | Loss 12 | Dup TS 0 | Dup PSN 0
    [00:01:57.261,108] <inf> stream_rx: [8641]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 26017 and ts 98645434: Valid 8628 | Error 0 | Loss 13 | Dup TS 0 | Dup PSN 0
    [00:02:00.841,033] <inf> stream_rx: [9000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 26376 and ts 102235473: Valid 8987 | Error 0 | Loss 13 | Dup TS 0 | Dup PSN 0
    [00:02:04.461,181] <inf> stream_rx: [9361]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 26737 and ts 105845512: Valid 9347 | Error 0 | Loss 14 | Dup TS 0 | Dup PSN 0
    [00:02:10.841,125] <inf> stream_rx: [10000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 27376 and ts 112235580: Valid 9986 | Error 0 | Loss 14 | Dup TS 0 | Dup PSN 0
    [00:02:11.661,254] <inf> stream_rx: [10081]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 27457 and ts 113045588: Valid 10066 | Error 0 | Loss 15 | Dup TS 0 | Dup PSN 0
    [00:02:18.861,328] <inf> stream_rx: [10801]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 28177 and ts 120245666: Valid 10785 | Error 0 | Loss 16 | Dup TS 0 | Dup PSN 0
    [00:02:20.841,247] <inf> stream_rx: [11000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 28376 and ts 122235688: Valid 10984 | Error 0 | Loss 16 | Dup TS 0 | Dup PSN 0
    [00:02:26.061,401] <inf> stream_rx: [11521]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 28897 and ts 127445743: Valid 11504 | Error 0 | Loss 17 | Dup TS 0 | Dup PSN 0
    [00:02:30.841,369] <inf> stream_rx: [12000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 29376 and ts 132235795: Valid 11983 | Error 0 | Loss 17 | Dup TS 0 | Dup PSN 0
    [00:02:40.841,674] <inf> stream_rx: [13000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 30376 and ts 142235902: Valid 12983 | Error 0 | Loss 17 | Dup TS 0 | Dup PSN 0
    [00:02:42.391,571] <inf> stream_rx: [13154]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 30530 and ts 143775918: Valid 13136 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:02:50.841,583] <inf> stream_rx: [14000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 31376 and ts 152236009: Valid 13982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:03:00.841,705] <inf> stream_rx: [15000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 32376 and ts 162236115: Valid 14982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:03:10.841,796] <inf> stream_rx: [16000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 33376 and ts 172236223: Valid 15982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:03:20.841,918] <inf> stream_rx: [17000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 34376 and ts 182236330: Valid 16982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:03:30.842,010] <inf> stream_rx: [18000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 35376 and ts 192236438: Valid 17982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:03:40.842,132] <inf> stream_rx: [19000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 36376 and ts 202236545: Valid 18982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:03:50.842,224] <inf> stream_rx: [20000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 37376 and ts 212236653: Valid 19982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:04:00.842,346] <inf> stream_rx: [21000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 38376 and ts 222236759: Valid 20982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:04:10.842,437] <inf> stream_rx: [22000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 39376 and ts 232236867: Valid 21982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:04:20.842,559] <inf> stream_rx: [23000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 40376 and ts 242236974: Valid 22982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:04:30.842,651] <inf> stream_rx: [24000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 41376 and ts 252237081: Valid 23982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:04:40.842,773] <inf> stream_rx: [25000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 42376 and ts 262237189: Valid 24982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:04:50.842,864] <inf> stream_rx: [26000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 43376 and ts 272237296: Valid 25982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:05:00.842,987] <inf> stream_rx: [27000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 44376 and ts 282237403: Valid 26982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:05:10.843,078] <inf> stream_rx: [28000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 45376 and ts 292237510: Valid 27982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:05:20.843,200] <inf> stream_rx: [29000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 46376 and ts 302237617: Valid 28982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:05:30.843,292] <inf> stream_rx: [30000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 47376 and ts 312237725: Valid 29982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:05:40.843,414] <inf> stream_rx: [31000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 48376 and ts 322237832: Valid 30982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:05:50.843,505] <inf> stream_rx: [32000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 49376 and ts 332237939: Valid 31982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:00.843,627] <inf> stream_rx: [33000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 50376 and ts 342238046: Valid 32982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:10.843,719] <inf> stream_rx: [34000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 51376 and ts 352238154: Valid 33982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:20.843,841] <inf> stream_rx: [35000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 52376 and ts 362238261: Valid 34982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:30.843,933] <inf> stream_rx: [36000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 53376 and ts 372238368: Valid 35982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:40.844,055] <inf> stream_rx: [37000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 54376 and ts 382238475: Valid 36982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:50.844,146] <inf> stream_rx: [38000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 55376 and ts 392238582: Valid 37982 | Error 0 | Loss 18 | Dup TS 0 | Dup PSN 0
    [00:06:53.994,293] <inf> stream_rx: [38314]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 55690 and ts 395378616: Valid 38295 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:07:00.844,268] <inf> stream_rx: [39000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 56376 and ts 402238689: Valid 38981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:07:10.844,360] <inf> stream_rx: [40000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 57376 and ts 412238796: Valid 39981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:07:20.844,482] <inf> stream_rx: [41000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 58376 and ts 422238904: Valid 40981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:07:30.844,573] <inf> stream_rx: [42000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 59376 and ts 432239010: Valid 41981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:07:40.844,696] <inf> stream_rx: [43000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 60376 and ts 442239119: Valid 42981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:07:50.844,787] <inf> stream_rx: [44000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 61376 and ts 452239225: Valid 43981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:00.844,909] <inf> stream_rx: [45000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 62376 and ts 462239332: Valid 44981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:10.845,001] <inf> stream_rx: [46000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 63376 and ts 472239440: Valid 45981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:20.845,123] <inf> stream_rx: [47000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 64376 and ts 482239547: Valid 46981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:30.845,214] <inf> stream_rx: [48000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 65376 and ts 492239654: Valid 47981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:40.845,336] <inf> stream_rx: [49000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 840 and ts 502239760: Valid 48981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:50.845,428] <inf> stream_rx: [50000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 1840 and ts 512239868: Valid 49981 | Error 0 | Loss 19 | Dup TS 0 | Dup PSN 0
    [00:08:57.725,585] <inf> stream_rx: [50687]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 2527 and ts 519109942: Valid 50667 | Error 0 | Loss 20 | Dup TS 0 | Dup PSN 0
    [00:09:00.845,550] <inf> stream_rx: [51000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 2840 and ts 522239975: Valid 50980 | Error 0 | Loss 20 | Dup TS 0 | Dup PSN 0
    [00:09:10.845,642] <inf> stream_rx: [52000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 3840 and ts 532240082: Valid 51980 | Error 0 | Loss 20 | Dup TS 0 | Dup PSN 0
    [00:09:15.005,798] <inf> stream_rx: [52415]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 4255 and ts 536390127: Valid 52394 | Error 0 | Loss 21 | Dup TS 0 | Dup PSN 0
    [00:09:20.845,764] <inf> stream_rx: [53000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 4840 and ts 542240189: Valid 52979 | Error 0 | Loss 21 | Dup TS 0 | Dup PSN 0
    [00:09:30.845,886] <inf> stream_rx: [54000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 5840 and ts 552240297: Valid 53979 | Error 0 | Loss 21 | Dup TS 0 | Dup PSN 0
    [00:09:32.285,980] <inf> stream_rx: [54143]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 5983 and ts 553670312: Valid 54121 | Error 0 | Loss 22 | Dup TS 0 | Dup PSN 0
    [00:09:40.845,977] <inf> stream_rx: [55000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 6840 and ts 562240404: Valid 54978 | Error 0 | Loss 22 | Dup TS 0 | Dup PSN 0
    [00:09:49.566,131] <inf> stream_rx: [55871]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 7711 and ts 570950496: Valid 55848 | Error 0 | Loss 23 | Dup TS 0 | Dup PSN 0
    [00:09:50.846,069] <inf> stream_rx: [56000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 7840 and ts 572240510: Valid 55977 | Error 0 | Loss 23 | Dup TS 0 | Dup PSN 0
    [00:10:00.846,191] <inf> stream_rx: [57000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 8840 and ts 582240618: Valid 56977 | Error 0 | Loss 23 | Dup TS 0 | Dup PSN 0
    [00:10:06.846,343] <inf> stream_rx: [57599]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 9439 and ts 588230681: Valid 57575 | Error 0 | Loss 24 | Dup TS 0 | Dup PSN 0
    [00:10:10.846,282] <inf> stream_rx: [58000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 9840 and ts 592240724: Valid 57976 | Error 0 | Loss 24 | Dup TS 0 | Dup PSN 0
    [00:10:20.846,405] <inf> stream_rx: [59000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 10840 and ts 602240833: Valid 58976 | Error 0 | Loss 24 | Dup TS 0 | Dup PSN 0
    [00:10:24.126,525] <inf> stream_rx: [59327]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 11167 and ts 605510867: Valid 59302 | Error 0 | Loss 25 | Dup TS 0 | Dup PSN 0
    [00:10:30.846,496] <inf> stream_rx: [60000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 11840 and ts 612240940: Valid 59975 | Error 0 | Loss 25 | Dup TS 0 | Dup PSN 0
    [00:10:40.846,618] <inf> stream_rx: [61000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 12840 and ts 622241046: Valid 60975 | Error 0 | Loss 25 | Dup TS 0 | Dup PSN 0
    [00:10:41.406,707] <inf> stream_rx: [61055]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 12895 and ts 622791052: Valid 61029 | Error 0 | Loss 26 | Dup TS 0 | Dup PSN 0
    [00:10:50.846,710] <inf> stream_rx: [62000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 13840 and ts 632241154: Valid 61974 | Error 0 | Loss 26 | Dup TS 0 | Dup PSN 0
    [00:10:58.686,889] <inf> stream_rx: [62783]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 14623 and ts 640071238: Valid 62756 | Error 0 | Loss 27 | Dup TS 0 | Dup PSN 0
    [00:11:00.846,832] <inf> stream_rx: [63000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 14840 and ts 642241261: Valid 62973 | Error 0 | Loss 27 | Dup TS 0 | Dup PSN 0
    [00:11:10.846,923] <inf> stream_rx: [64000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 15840 and ts 652241369: Valid 63973 | Error 0 | Loss 27 | Dup TS 0 | Dup PSN 0
    [00:11:15.967,071] <inf> stream_rx: [64511]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 16351 and ts 657351422: Valid 64483 | Error 0 | Loss 28 | Dup TS 0 | Dup PSN 0
    [00:11:20.847,045] <inf> stream_rx: [65000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 16840 and ts 662241475: Valid 64972 | Error 0 | Loss 28 | Dup TS 0 | Dup PSN 0
    [00:11:30.847,137] <inf> stream_rx: [66000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 17840 and ts 672241582: Valid 65972 | Error 0 | Loss 28 | Dup TS 0 | Dup PSN 0
    [00:11:33.247,253] <inf> stream_rx: [66239]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 18079 and ts 674631607: Valid 66210 | Error 0 | Loss 29 | Dup TS 0 | Dup PSN 0
    [00:11:40.847,259] <inf> stream_rx: [67000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 18840 and ts 682241690: Valid 66971 | Error 0 | Loss 29 | Dup TS 0 | Dup PSN 0
    [00:11:50.527,435] <inf> stream_rx: [67967]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 19807 and ts 691911792: Valid 67937 | Error 0 | Loss 30 | Dup TS 0 | Dup PSN 0
    [00:11:50.847,351] <inf> stream_rx: [68000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 19840 and ts 692241797: Valid 67970 | Error 0 | Loss 30 | Dup TS 0 | Dup PSN 0
    [00:11:52.917,541] <inf> stream_rx: [68205]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20045 and ts 694291818: Valid 68174 | Error 0 | Loss 31 | Dup TS 0 | Dup PSN 0
    [00:11:52.917,816] <inf> stream_rx: [68206]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20046 and ts 694301818: Valid 68174 | Error 0 | Loss 32 | Dup TS 0 | Dup PSN 0
    [00:11:53.067,443] <inf> stream_rx: [68221]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20061 and ts 694451820: Valid 68188 | Error 0 | Loss 33 | Dup TS 0 | Dup PSN 0
    [00:11:55.057,464] <inf> stream_rx: [68420]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20260 and ts 696441841: Valid 68386 | Error 0 | Loss 34 | Dup TS 0 | Dup PSN 0
    [00:12:00.587,524] <inf> stream_rx: [68973]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20813 and ts 701971901: Valid 68938 | Error 0 | Loss 35 | Dup TS 0 | Dup PSN 0
    [00:12:00.847,442] <inf> stream_rx: [69000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 20840 and ts 702241904: Valid 68965 | Error 0 | Loss 35 | Dup TS 0 | Dup PSN 0
    [00:12:01.407,531] <inf> stream_rx: [69055]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20895 and ts 702791909: Valid 69019 | Error 0 | Loss 36 | Dup TS 0 | Dup PSN 0
    [00:12:01.577,514] <inf> stream_rx: [69072]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 20912 and ts 702961912: Valid 69035 | Error 0 | Loss 37 | Dup TS 0 | Dup PSN 0
    [00:12:06.287,597] <inf> stream_rx: [69543]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 21383 and ts 707671962: Valid 69505 | Error 0 | Loss 38 | Dup TS 0 | Dup PSN 0
    [00:12:07.807,586] <inf> stream_rx: [69695]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 21535 and ts 709191978: Valid 69656 | Error 0 | Loss 39 | Dup TS 0 | Dup PSN 0
    [00:12:10.847,564] <inf> stream_rx: [70000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 21840 and ts 712242011: Valid 69961 | Error 0 | Loss 39 | Dup TS 0 | Dup PSN 0
    [00:12:11.237,640] <inf> stream_rx: [70038]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 21878 and ts 712622015: Valid 69998 | Error 0 | Loss 40 | Dup TS 0 | Dup PSN 0
    [00:12:14.377,838] <inf> stream_rx: [70352]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22192 and ts 715762048: Valid 70311 | Error 0 | Loss 41 | Dup TS 0 | Dup PSN 0
    [00:12:15.027,862] <inf> stream_rx: [70417]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22257 and ts 716412056: Valid 70375 | Error 0 | Loss 42 | Dup TS 0 | Dup PSN 0
    [00:12:16.287,872] <inf> stream_rx: [70543]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22383 and ts 717672069: Valid 70500 | Error 0 | Loss 43 | Dup TS 0 | Dup PSN 0
    [00:12:16.937,866] <inf> stream_rx: [70608]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22448 and ts 718322077: Valid 70564 | Error 0 | Loss 44 | Dup TS 0 | Dup PSN 0
    [00:12:19.087,890] <inf> stream_rx: [70823]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22663 and ts 720472100: Valid 70778 | Error 0 | Loss 45 | Dup TS 0 | Dup PSN 0
    [00:12:19.497,894] <inf> stream_rx: [70864]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22704 and ts 720882104: Valid 70818 | Error 0 | Loss 46 | Dup TS 0 | Dup PSN 0
    [00:12:20.847,656] <inf> stream_rx: [71000]: Incoming audio on stream 0x2000588c len 40, flags 0x09, seq_num 22840 and ts 722242118: Valid 70954 | Error 0 | Loss 46 | Dup TS 0 | Dup PSN 0
    [00:12:21.238,067] <inf> stream_rx: [71038]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 22878 and ts 722622122: Valid 70991 | Error 0 | Loss 47 | Dup TS 0 | Dup PSN 0
    [00:12:24.618,041] <inf> stream_rx: [71376]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23216 and ts 726002158: Valid 71328 | Error 0 | Loss 48 | Dup TS 0 | Dup PSN 0
    [00:12:25.088,073] <inf> stream_rx: [71423]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23263 and ts 726472164: Valid 71374 | Error 0 | Loss 49 | Dup TS 0 | Dup PSN 0
    [00:12:25.837,890] <inf> stream_rx: [71498]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23338 and ts 727222173: Valid 71448 | Error 0 | Loss 50 | Dup TS 0 | Dup PSN 0
    [00:12:25.857,879] <inf> stream_rx: [71500]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23340 and ts 727242172: Valid 71449 | Error 0 | Loss 51 | Dup TS 0 | Dup PSN 0
    [00:12:25.877,899] <inf> stream_rx: [71502]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23342 and ts 727262172: Valid 71450 | Error 0 | Loss 52 | Dup TS 0 | Dup PSN 0
    [00:12:25.897,888] <inf> stream_rx: [71504]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23344 and ts 727282172: Valid 71451 | Error 0 | Loss 53 | Dup TS 0 | Dup PSN 0
    [00:12:25.917,877] <inf> stream_rx: [71506]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23346 and ts 727302173: Valid 71452 | Error 0 | Loss 54 | Dup TS 0 | Dup PSN 0
    [00:12:25.937,896] <inf> stream_rx: [71508]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23348 and ts 727322174: Valid 71453 | Error 0 | Loss 55 | Dup TS 0 | Dup PSN 0
    [00:12:25.957,885] <inf> stream_rx: [71510]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23350 and ts 727342174: Valid 71454 | Error 0 | Loss 56 | Dup TS 0 | Dup PSN 0
    [00:12:25.977,874] <inf> stream_rx: [71512]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23352 and ts 727362173: Valid 71455 | Error 0 | Loss 57 | Dup TS 0 | Dup PSN 0
    [00:12:25.997,894] <inf> stream_rx: [71514]: Incoming audio on stream 0x2000588c len 0, flags 0x0C, seq_num 23354 and ts 727382173: Valid 71456 | Error 0 | Loss 58 | Dup TS 0 | Dup PSN 0
    [00:12:26.017,883] <
  • Hi Carl,
    Thank you for your patience. I was away due to Easter holiday and got back to this today.
    If you can share your modified samples as .zips here on DevZone that will be very helpful. You can upload them with Insert->Image/video/file. Also, when sharing logs, please use the Insert->Code option. That way it is very easy to differentiate between explanations/questions and code/logs. I modified your last reply to move the logs into a code box.
    Did you have a chance to use a professional sniffer to analyze the traffic for the two cases, or most importantly bap_broadcast_sink v2? No worries if not. If you share your modified source code I can collect a trace from my desk.
    Maria
  • Hello Maria,
    Thank you for the upload instructions and message re-formatting. I do not have a professional sniffer, so only Segger trace and program log information is available. I have uploaded main.c sources for bap_broadcast_source (modified from NCS 3.2.0, zephyr/samples/bluetooth/bap_broadcast_source) and bap_broadcast_sink (modified from NCS 3.2.0, zephyr/samples/bluetooth/bap_broadcast_sink). Please let me know what other information I can provide.
    Also, I will be out of the office from April 11 until April 29.
    bap_broadcast_sink_main.zip
    bap_broadcast_source_main.zip
  • Hi Carl,
    I hope you are doing well after your time off.
    While you were already out of office, I started to run the bap_broadcast samples with your modified main on two nRF7002 DKs, but unfortunately I am not able to get the broadcast source to start on the combined device. My current prj.conf looks like this:
    CONFIG_BT=y
    CONFIG_LOG=y
    CONFIG_BT_AUDIO=y
    CONFIG_BT_SMP=y
    CONFIG_BT_PAC_SNK=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
    # Set preferred values based on BT_BAP_CONN_PARAM_RELAXED
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=50
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=70
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_PER_ADV_SYNC=y
    CONFIG_BT_ISO_SYNC_RECEIVER=y
    CONFIG_BT_BAP_BROADCAST_SINK=y
    CONFIG_BT_BAP_SCAN_DELEGATOR=y
    CONFIG_BT_ISO_MAX_CHAN=2
    # Allocate 4 RX buffers per channel
    CONFIG_BT_ISO_RX_BUF_COUNT=8
    CONFIG_BT_BAP_BROADCAST_SNK_SUBGROUP_COUNT=2
    CONFIG_BT_BAP_BROADCAST_SNK_STREAM_COUNT=2
    CONFIG_BT_BAP_BASS_MAX_SUBGROUPS=2
    CONFIG_BT_BUF_ACL_RX_SIZE=255
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_AUDIO_CODEC_CFG_MAX_METADATA_SIZE=64
    CONFIG_BT_AUDIO_CODEC_CFG_MAX_DATA_SIZE=64
    CONFIG_BT_AUDIO_CODEC_CAP_MAX_METADATA_SIZE=64
    CONFIG_BT_AUDIO_CODEC_CAP_MAX_DATA_SIZE=64
    CONFIG_BT_DEVICE_NAME="Broadcast Audio Sink"
    # Broadcaster configs
    CONFIG_MAIN_STACK_SIZE=2048
    CONFIG_BT_ISO_BROADCASTER=y
    CONFIG_BT_BAP_BROADCAST_SOURCE=y
    CONFIG_BT_BAP_BROADCAST_SRC_STREAM_COUNT=2
    CONFIG_BT_BAP_BROADCAST_SRC_SUBGROUP_COUNT=1
    CONFIG_BT_ISO_TX_BUF_COUNT=12
    CONFIG_BT_ISO_TX_MTU=60
    CONFIG_BROADCAST_ID=0x123123
    CONFIG_REBOOT=y
    During my testing and trying different Kconfig symbols I was not able to get the broadcast source to start. bap_broadcast_source is working well.
    Could you please share your prj.conf for your modified bap_broadcast_sink? Both for the main application and hci_ipc (or the network core image you are using).
    My apologies for not having better feedback to give you after your break. I realise I should have done a test run before you went away, but alas.
    Maria
  • Hello Maria,
    It may be that changes to SD Controller .conf are required. System error codes may help to indicate this. Attached are bap_broadcast_sink and nrf/applications/ipc_radio (overlay) .conf files.The latter has some extra values used here for internal testing (e.g. PAwR) which may be removed if there is any issue with Flash/RAM sizes (there should not be). Please let me know if I can provide further information.
    Thank you,
    0880.prj.confoverlay-bt_hci_ipc.conf
