LE audio: Simultaneous Broadcast Sink and Broadcast Source
Is it possible to configure an nRF5340 to be both a Broadcast Sink and a Broadcast Source, but with the condition that only frames received by the Broadcast Sink are sent ("relayed") to the Broadcast Source?
So long as the data stream is compressed, there should be sufficient bandwidth, but can the SD Controller support this configuration?
A simple test with NCS 3.2.0 and SD Controller received and sent data, however the received stream was unstable (100ms or so gaps in data received from Controller after some minutes followed by bursts of invalid frames).
Thank you,
Carl
  • Hi Carl,
    Maria is partly away and I will try to assist during that time.
    Firstly, I think we need to understand one thing, The SDController supporting scanning and advertising simultaneously does not translate into it being reliably sustain simultaneous broadcase sink + broadcase cource ISO audio under arbitrary BIS timing. LE Audio is much tighter than normal adv/scan
    That said, it is not that easy to see where exactly the issue is. We would need a sniffer trace without which it is difficult to see what loss/collision or starvation happened and on which side.
    Try reducing load and see if that helps, 1BIS, longer ISO interval, larger presentation delays and try using 2M PHY.
    The feature you are testing seems to be very demanding given the clock speed of nRF53
  • Hello Susheel,
    I appreciate your looking into this issue.
    About your suggestions:
    - bap_broadcast_source sample does send only 1 BIS
    (we set CONFIG_BT_BAP_BROADCAST_SRC_STREAM_COUNT=1 in prj.conf)
    - only 1 BIS is LC3 decoded (and no BIS is LC3 encoded) by
    bap_broadcast_sink sample ("relay"), so CPU load should be low
    - only 40B data is sent/received in 10ms ISO interval
    - presentation delay should not affect results as bap_broadcast_sink
    sample ("relay") only re-transmits received (LC3 encoded) frames
    - 2M PHY is configured
    Also, nRF53 supports bi-directional CIS:
    docs.nordicsemi.com/.../README.html
    Although CIS and BIS are quite different, CIS load is higher
    (due to LC3 encoding) and yet it can be bi-directional.
    The modified bap_broadcast_sink sample ("relay") operates correctly
    for several minutes, indicating load and timing are not issues
    (at least for those several minutes).
    I agree a sniffer trace would be helpful, and I had previously understood
    that Nordic could run test applications, which I uploaded.
    As SD Controller source code is unavailable, it is difficult to debug
    further here. Our Nordic sniffer does not appear able to capture
    relevant information.
    I would be grateful for any further help you may be able to provide.
    Thank you,
    Carl Stehle
  • Hi Carl, your points seems very valid.
    the root cause is likely BIG anchor drift between the two ISO trains.
    Your local Source BIG and the received Sink BIG both run at 10ms but are on independent clocks (±40ppm crystal difference = ~0.8µs drift per interval). After few minutes, the two event windows overlap enough that the SDC scheduler must drop one, most likely causing the burst errors you see.
    • detect sequence number gaps in bt_iso_recv and restart the Source BIG. Re-creation lands at a random anchor offset, buying another ~10–15 minutes before the next collision window.
    • Test on NCS 3.3.0, i recently learnt that there have been SDC scheduling improvements since 3.2.0 worth evaluating.
  • Hello Susheel,
    The issue does not occur with NCS 3.3.0 SD Controller (previously using NCS 3.2.0 SD Controller).
    I did not notice anything particular in the SD Controller CHANGELOG but perhaps certain data timings are handled differently.
    Thank you for your help.
    Carl Stehle
  • Thanks for that info Carl, yes it is possible that some small granular changes might have helped with some data timings in the newer version of the SDK.
