NRF7002DK - NRF5340 SPI4M SPI_MISO tristate causing failure to boot (with spi_nor flash defined)
We found a weird case that when we re-populate the definition of SPI-NOR flash
- From original pin (gpio0.8/9/10, U15 populated on NRF7002DK)
- To pins (gpio1.0/1/4, exposed to pin header P3)
, the board failed to boot by hanging over here:
*** Booting MCUboot v2.1.0-dev-9b4ae4cbc9e2 ***
*** Using nRF Connect SDK v3.1.0-6c6e5b32496e ***
*** Using Zephyr OS v4.1.99-1612683d4010 ***
I: Starting bootloader
I: Bootloader chainload address offset: 0x14000
I: Image version: v1.0.0
▒: Jumping to the first image slot
At hanging state, when we connect the MISO which is gpio1.1 to GND, then it continue to boot as below:
▒[00:00:00.003,662] <wrn> spi_nor: Waiting until flash is ready
[00:04:55.588,317] <err> spi_nor: Device id 00 00 00 does not match config c2 20 16
[00:04:55.588,439] <err> spi_nor: Device id 00 00 00 does not match config c2 20 10
[00:04:55.589,721] <err> spi_nor: Device id 00 00 00 does not match config c2 28 17
*** Booting My Application v1.0.0-mfg.inno-4a483adff6c4 ***
Set up button at gpio@842800 pin 8
Set up button at gpio@842800 pin 9
[00:04:55.803,344] <inf> wifi_supplicant: wpa_supplicant initialized
[00:04:55.829,803] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:04:55.829,803] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:04:55.829,833] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 252.16862 Build 1121034987
[00:04:55.833,984] <inf> bt_hci_core: HCI transport: IPC
[00:04:55.834,075] <inf> bt_hci_core: Identity: DD:DE:F9:AF:40:1B (random)
[00:04:55.834,106] <inf> bt_hci_core: HCI: version 6.1 (0x0f) revision 0x2069, manufacturer 0x0059
[00:04:55.834,136] <inf> bt_hci_core: LMP: version 6.1 (0x0f) subver 0x2069
Bluetooth initialized, use shell to control
This test is try to find whether a spi-nor flash should be presented for booting. But the test was showing that even the true flash device is not presented, the zephyr (with flash_shell enabled) application still can boot with proper error/warning message displayed like log below. But with tricky level change on MOSI signal.
I just wonder why the level of MOSI will impact the booting procedure. Is there any explanation for the finding?
