nRF54L15 BLE RX current comsumption
I measured the power consumption of the BLE RX using the nRF54L15.(nRF54L15-DK v1.0.0)
3.0V operation
apps: scan_adv (delete advertising)
west build -b nrf54l15dk/nrf54l15/cpuapp
proj.conf
CONFIG_BT=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_OBSERVER=y
CONFIG_LOG=n
CONFIG_SERIAL=n
Result: The average current consumption was 3.73mA.
This is 330uA higher than the 3.4mA stated in the datasheet.
Is this correct behavior? Is further processing required to reduce it to 3.4mA?
  • We prioritize power consumption when selecting devices.
    We have been using the nRF52832, but later discovered a significant discrepancy between the RF power consumption listed in its datasheet and the actual measured values ​​(the measured values ​​were higher than the listed values).
    This time, the measured values ​​are also considerably higher than those listed in the datasheet.
    We have used several devices from other companies in the past, and have never encountered this kind of error.
    We hope that accurate information will be provided in the future.
    The nRF54LM20 likely has a similar problem.
  • These are the results for the nRF54LM20-DK (0.5.4).
    The SoC is the nRF54LM20B.
    The datasheet specifies 3.0V/3.3mA, but the result is 3.88mA, which is 0.58mA (!) higher.
    This may be due to an older revision of the SoC, but it's still a significant problem.
    As an additional note, the real current consumption during reception with the nRF54L15 is 3.0V/3.8mA. During scanning, channel switching and other factors cause the average current consumption to be slightly lower.
    This is an important point to note when checking with an online power profiler.
  • Hi Emil and syuji
    Thank you for your feedback. It seems erratum 20 mentions as part of the workaround that CONSTLAT should be triggered before enabling RX as well, but I agree that that could be updated to be reflected in the Conditions as well.
    I will also reignite the internal discussion about following up this being stated in the nRF54L15 (and possibly nRF54LM20) datasheet. Thank you both for your insight and feedback here so far.
    Simon
