MCUBOOT with nrf9161-sica
I’m working on a custom board based on the nRF9160 (SICA variant) and trying to enable MCUboot + TF-M with sysbuild. I’m running into an issue where the system never reaches the application after MCUboot hands over control.
Wrench Environment
  • NCS version: 3.2.2
  • Zephyr: 4.2.99
  • Toolchain: NCS toolchain (default)
  • Board: custom (rit_nordic3_nrf9160/ns)
  • Using sysbuild with MCUboot and TF-M
Problem description
The device boots into MCUboot correctly, validates the image, and attempts to jump to slot0. However, nothing executes afterward:
  • No Zephyr banner
  • No TF-M logs (e.g. [Sec Thread] Secure image initializing!)
  • No RTT output
  • No UART output from the application
MCUboot log
*** Booting MCUboot v2.3.0-dev ***
I: Starting bootloader
I: Image version: v1.1.0
?: Jumping to the first image slot
After this line → system is silent
What we verified
  • MCUboot builds and runs correctly
  • Image is properly signed and validated (ECDSA OK)
  • Partition layout looks correct (slot0 @ 0x10000, slot1 @ 0x80000)
  • TF-M is being built (build/.../tfm exists)
  • Using sysbuild (--sysbuild)
What we tried
1. Logging / console debugging
  • Switched to RTT:
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
  • Result: still no output after MCUboot jump
2. UART console
  • Initially UART console worked for MCUboot logs
  • Disabled UART console → still no application output
3. Partition Manager
  • Verified layout using partition_manager_report
  • Matches expected MCUboot + TF-M layout
4. TF-M dependency check
  • Tried disabling TF-M → build fails due to missing psa/crypto.h
  • So TF-M is required in our application
5. DTS cleanup
We started with a minimal SICA DTS:
#include <nordic/nrf9160ns_sica.dtsi>
Then adjusted our board DTS to:
/dts-v1/;
#include "rit_nordic3_nrf9160-pinctrl.dtsi"
#include "rit_nordic3_nrf9160-partitioning.dtsi"
#include "rit_nordic3_nrf9160.dtsi"
    chosen {
        zephyr,flash = &flash0;
        zephyr,sram = &sram0_ns;
        zephyr,code-partition = &slot0_partition;
Also removed:
  • duplicate includes
  • flash/sram overrides
  • extra soc {} node
Current understanding
It looks like:
  • MCUboot works and jumps correctly
  • Failure happens immediately after jump
  • TF-M does not seem to start at all
  • Likely a secure memory / SPU / TF-M platform integration issue
Given we are using the SICA variant, we suspect:
  • missing or incorrect secure attribution configuration
  • board DTS / platform not fully aligned with TF-M expectations
Questions
  1. Is nrf9160ns_sica.dtsi alone sufficient for TF-M + MCUboot setups?
  2. Are there additional required configurations for SPU / secure memory when using SICA?
  3. Is there a reference board or example using SICA + TF-M + MCUboot?
  4. What is the minimal set of requirements for a custom board DTS to work with TF-M?
Goal
We want:
  • MCUboot + TF-M working on a custom SICA-based board
  • Ability to run application (with console/menu) after boot
Any guidance or reference configuration would be greatly appreciated.
Thanks!
    are you able to build for nrf9160dk/nrf9160/ns and test the same application on that board?
    Are you getting any warnings/errors in the build log while building for your custom board? How is you custom board configured?
    Øyvind
  • Yes, I can build my application and it is running perfect without any error or warning during the build. Once I tried to add the MCUBOOT to support 2 images I started to had the problem. Without the MCUBOOT every thing is working fine
    Does the nRF9160DK fail with MCUBOOT as well?
  • The application runs perfectly on my custom board when compiled without MCUboot. However, when I enable MCUboot, the boot process hangs right when it is supposed to jump to my application. Note: I haven't tested this on the official dev board yet.
  • Are you using Sysbuild in your application? Our AI chatbot provides the following explanation on MCUboot and Sysbuild:
    Sysbuild and MCUboot are closely integrated in the nRF Connect SDK. Here's how they relate:
    Sysbuild manages MCUboot as an extra image
    Sysbuild is a higher-level build system that can combine multiple build systems — including MCUboot — into a single hierarchical build. MCUboot is one of the pre-made images available in nRF Connect SDK that can be pulled into the build via Sysbuild. [Sysbuild overview]
    Enabling MCUboot via Sysbuild
    To add MCUboot to your application, you simply enable it in the sysbuild.conf file in your project root:
    SB_CONFIG_BOOTLOADER_MCUBOOT=y
    This single option instructs Sysbuild to build MCUboot alongside your application, flash both images, and link your application as an MCUboot-bootable image. [Adding MCUboot]
    Configuring MCUboot through Sysbuild
    Sysbuild Kconfig options (prefixed with SB_CONFIG_) generally override MCUboot's own Kconfig options, ensuring a coherent environment for the entire system. [MCUboot config]
    To apply MCUboot-specific configuration, create a sysbuild/mcuboot.conf file in your project. For example, to disable serial logging in MCUboot:
    CONFIG_SERIAL=n
    [Adding MCUboot]
    Key roles MCUboot can play (configured via Sysbuild)
    | Role | Sysbuild options | |---|---| | Immutable first-stage bootloader | SB_CONFIG_BOOTLOADER_MCUBOOT=y | | Upgradable second-stage bootloader | SB_CONFIG_BOOTLOADER_MCUBOOT=y + SB_CONFIG_SECURE_BOOT_APPCORE=y | | Firmware loader mode | SB_CONFIG_BOOTLOADER_MCUBOOT=y + SB_CONFIG_MCUBOOT_MODE_FIRMWARE_UPDATER=y |
    [MCUboot in NCS]
    Configuration rules
    Importantly, Sysbuild can configure MCUboot and the application, but MCUboot and the application cannot configure Sysbuild or each other. This provides a clear separation of ownership. [Sysbuild blog]
    Øyvind
