no device npm1300_ek (one button sample) with nRF52 DK on I2C Bus
I try to get the one button sample to work. There were several details missing to be able to compile and run this sample, which was very frustrating. After editing/updating the
prj.conf: CONFIG_I2C=y
CMakeLists.txt: set(SHIELD npm1300_ek)
nrf52dk_nrf52832.overlay:
 #include <zephyr/dt-bindings/pinctrl/nrf-pinctrl.h>
 &i2c1 {
 status = "okay";
 pinctrl-0 = <&i2c1_default>;
 pinctrl-1 = <&i2c1_sleep>;
 clock-frequency = <I2C_BITRATE_STANDARD>;
 //clock-frequency = <10000>;
 &i2c1_default {
 group1 {
 psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
 <NRF_PSEL(TWIM_SCL, 0, 27)>;
 bias-pull-up;
&i2c1_sleep {
 group1 {
 low-power-enable;
My zephyr.dts i2c1 snippet:
/* node '/soc/i2c@40004000' defined in zephyr/dts/arm/nordic/nrf52832.dtsi:172 */
		i2c1: i2c@40004000 {
			#address-cells = < 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52832.dtsi:181 */
			#size-cells = < 0x0 >;         /* in zephyr/dts/arm/nordic/nrf52832.dtsi:182 */
			reg = < 0x40004000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52832.dtsi:183 */
			interrupts = < 0x4 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52832.dtsi:184 */
			easydma-maxcnt-bits = < 0x8 >; /* in zephyr/dts/arm/nordic/nrf52832.dtsi:185 */
			zephyr,pm-device-runtime-auto; /* in zephyr/dts/arm/nordic/nrf52832.dtsi:187 */
			compatible = "nordic,nrf-twi"; /* in zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832.dts:188 */
			status = "okay";               /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:9 */
			pinctrl-0 = < &i2c1_default >; /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:10 */
			pinctrl-1 = < &i2c1_sleep >;   /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:11 */
			pinctrl-names = "default",
			                "sleep";       /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:12 */
			clock-frequency = < 0x186a0 >; /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:13 */
with claudes assistance/support i got it to compile and run. But an i2c scan i2c0 shows no device at all.
What minimal required steps/configuration have to setup to get I2C enabled and detect devices on the bus should be?
Trying with the nrf-connect (Ubuntu) Linux-Desktop app (2x USB -C, 1x LiPo Battery) i get NPM detected, the LiPo Battery to and can change parameters for ex. the LED's live, so the BOARD is working.
Any support/hint/help is appreciated.
  • After connecting a BAttery the charger status changed:
    Charger Status: 5, Error: 0, VBUS: connected
    V: 4.165 I: 0.0001 T: 24.79
    V: 4.145 I: 0.1590 T: 24.79
    Charger Status: 9, Error: 0, VBUS: connected
    Good, this means that the setup is working with the precompiled .hex that I shared.
    Then I suspect the issue is how your firmware is setup, ie. built.
    Try to delete your build folder, do not add any specific overlays or .conf files; and only set the SHIELD parameter, similar to this:
    Since we cannot overload the west cmd switch here, we just set the EK directly in CMakeLists.txt:
    # Copyright (c) 2023 Nordic Semiconductor ASA
    cmake_minimum_required(VERSION 3.20.0)
    set(EXTRA_DTC_OVERLAY_FILE npm1300.overlay)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(npm13xx_ek)
    target_sources(app PRIVATE src/main.c)
    Håkon
  • Hi, build/compiling works with that setup. Situation stays, only the LED2 (amber) is blinking. despite turning on all 3 LEDs.
    "led_off(leds, 2U);"
    works. disabling it makes the LED2 light up constantly. Strange.
    #include <dt-bindings/regulator/npm13xx.h>
    &npm1300_ek_ldo1 {
    	regulator-initial-mode = <NPM13XX_LDSW_MODE_LDSW>;
    &npm1300_ek_pmic {
    	host-int-gpios = <&gpio0 4 0>;
    	pmic-int-pin = <3>;
    	npm1300_ek_leds: leds {
    		compatible = "nordic,npm1300-led";
    		status="okay";
    		//nordic,led0-mode = "error";
    		//nordic,led1-mode = "charging";
    		nordic,led0-mode = "host";
    		nordic,led1-mode = "host";
    		nordic,led2-mode = "host";
    &npm1300_ek_leds {
    		status="okay";
    See the C-code and my npm1300.overlay attached.
    Additional, with USB-C in USB PMIC and without Battery the LED1 "CHG" is constantly on. Adding a battery, led1 turns off.
    Can you please share your full project, including your build-folder?
    Based on your description, it sounds like you have not overridden the default led setup of the EK.
    Håkon
