Hello, when flashing t device using nrf connect icon, it fails to flash with following message
Error: Subprocess C:\ncs\toolchains\66cdf9b75e\nrfutil\home\bin\nrfutil-device.exe failed with unexpected exit code Some(101) FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path 'C:\*****\generated_nrfutil_batch.json' --serial-number 821004437
After investigation I found the generated_nrfutil_batch.json (autogenerated) use "nrfutil_device_version": "2.15.2" while the toolchain uses the 2.19.2
If I run the flash from command line editing manually the generated_nrfutil_batch.json, the flash is successfull.
I checked this ticket but it does not give a solution.
How to set the correct nrfutil_device_version in the batch file?
Thank you
