NCS 3.4.0 - Thingy91X - build without SECURE_BOOT_APPCORE fails to flash
If I configure the sysbuild with sysbuild.conf
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_SECURE_BOOT_APPCORE=n
it builds, but on "west flash" I get
FATAL ERROR: ???/ncs/v3.4.0/app/build/app/../signed_by_mcuboot_and_b0_app.hex does not exist. Try enabling CONFIG_BUILD_OUTPUT_HEX.
but with SB_CONFIG_SECURE_BOOT_APPCORE=n that's intended to not have that file.
I tried to analyze the issue and found in Kconfig.defconfig.nrf9151:
config SECURE_BOOT
    default y
If I change that to 'n' it work to flash and the app runs well.
Unfortunately, it's not possible to overwrite that in sysbuild.conf with
SB_CONFIG_SECURE_BOOT=n
because that results in
error: SECURE_BOOT (defined at ???/ncs/v3.4.0/nrf/modules/../sysbuild/Kconfig.secureboot:7)
is assigned in a configuration file, but is not directly user-configurable (has no prompt). It gets
its value indirectly from other symbols
So:
why is
config SECURE_BOOT
    default y
instead of
config SECURE_BOOT_APPCORE
    default y
    what sample are you building? Is it a custom application?
  • Do you have a sample, where it works?
    Have you tested it with "nrf/samples/cellular/nrf_cloud_coap_fota" and adapted "sysbuild.conf" (disable "SB_CONFIG_SECURE_BOOT_APPCORE")?
    I've tested it with the "nrf/samples/cellular/udp", but had to add the files for the thingy91X.
  • Yes, I tested this now, and I run into the same issue. I will check if this is something that should be fixed. For now you can instead run
    west flash \
      -d build/udp \
      --no-rebuild \
      --hex-file build/udp/zephyr/zephyr.signed.hex
  • > I will check if this is something that should be fixed.
    Thanks!
    AFAIK, it's also required to additional flash "build/mcuboot/zephyr/zephyr.hex" (at least that's done, when setting "SECURE_BOOT=n").
  • :-) I guess, I know in the meantime the reason (-:.
    Not using SB_CONFIG_SECURE_BOOT_APPCORE is in NCS 3.4.0 broken!
    The cause for that is simple, very close to the issue migrating app using mcuboot to NCS 3.2.3 - issue with MCUboot image IDs automatically assigned?
    The way "zephyr/subsys/dfu/img_util/flash_img.c" assigns the ids is broken.
    It was (before NCS 3.4.0):
    #define FIXED_PARTITION_IS_RUNNING_APP_PARTITION(label)                                            \
        DT_SAME_NODE(FIXED_PARTITION_NODE_MTD(DT_CHOSEN(zephyr_code_partition)),                   \
            FIXED_PARTITION_MTD(label)) &&                                                     \
        (FIXED_PARTITION_OFFSET(label) <= CONFIG_FLASH_LOAD_OFFSET &&                              \
         FIXED_PARTITION_OFFSET(label) + FIXED_PARTITION_SIZE(label) > CONFIG_FLASH_LOAD_OFFSET)
    #if defined(CONFIG_TRUSTED_EXECUTION_NONSECURE) && (CONFIG_TFM_MCUBOOT_IMAGE_NUMBER == 2)
    #define UPLOAD_FLASH_AREA_LABEL slot1_ns_partition
    #else
    #if FIXED_PARTITION_EXISTS(slot1_partition) && \
        FIXED_PARTITION_IS_RUNNING_APP_PARTITION(slot0_partition)
    #define UPLOAD_FLASH_AREA_LABEL slot1_partition
    #else
    #define UPLOAD_FLASH_AREA_LABEL slot0_partition
    Now its:
    #define PARTITION_IS_RUNNING_APP_PARTITION(label) \
        DT_SAME_NODE(DT_CHOSEN(zephyr_code_partition), DT_NODELABEL(label))
    #else
    #if PARTITION_EXISTS(slot1_partition) && \
    #else
    So, SECURE_BOOT_APPCORE works, because of the "CONFIG_TFM_MCUBOOT_IMAGE_NUMBER == 2".
    And without it fails, because of "PARTITION_IS_RUNNING_APP_PARTITION(slot0_partition)", the app runs on slot0_ns_partition. Using
        PARTITION_IS_RUNNING_APP_PARTITION(slot0_ns_partition)
    again "works on my machine".
