Where to find DT Overlay errors?
I'm setting up a board I just built in NCS, and I made an overlay file for it.  Specifically, I am setting up the UART21 peripheral and assigning pin outputs.  I made a mistake of assigning the wrong pins for UART21 (P2.08 and P2.09 rather than P2.07 and P2.08).
I thought to just try out my pin configuration in the overlay file, and see if it'll work.  NCS builds it, flashes it, and the code runs.  But there is no indication that anything is wrong besides the UART output not actually going anywhere.  As in, there isn't a compile time error, nor a run-time error.  Is this expected?
Also, why is there a PSEL register at all if there is only 1 valid value for the pin?
DevZone AI response follow up:  The AI suggested that I can set UARTE21 pins to any pins within P1.  I tried this but none of them actually output any serial data like I got on P2.08.  II also tried setting UARTE21.TXD to P2.02 as that's on the datasheet dedicated function list, but that doesn't work.
Here is the overlay file:
	aliases {
		ledonboard = &led_debug_0;
	leds {
		compatible = "gpio-leds";
		led_debug_0: led_0 {
			gpios = <&gpio2 6 GPIO_ACTIVE_HIGH>;
&pinctrl {
	uart21_default: uart21_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 2, 2)>;
		group2 {
			psels = <NRF_PSEL(UART_RX, 2, 0)>;
			bias-pull-up;
	uart21_sleep: uart21_sleep {
		group1 {
			psels = <NRF_PSEL(UART_TX, 2, 2)>,
			low-power-enable;
&uart21 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart21_default>;
	pinctrl-1 = <&uart21_sleep>;
Another thing I observed is that the `psels` fields in the `zephyr.dts` file would only have 1 of the 2 pins set as connected (the leading bit of the psel register).  Is this expected?
  • Hi seth,
    thanks for posting this issue here,
    1. Valid pins for UARTE21
    Either:
    • Any pins on Port 1 (P1.00–P1.15), or
    • The dedicated cross-domain pins on Port 2: TX = P2.08, RX = P2.07
    2. Why no build error
    NRF_PSEL() just bit-packs function, port and pin into a 32-bit value. Nothing in devicetree validates that the peripheral can physically route to that pin.
    3. Why no runtime error
    The pinctrl driver writes the value into PSEL and configures the GPIO, then returns 0. No check. UARTE TX is fire-and-forget — EasyDMA runs, ENDTX fires, driver reports success. The chip has no way to know if the line goes anywhere.
    4. The "leading bit" in zephyr.dts
    Not a connect bit — it's the function ID in the upper byte. TX is function 0, RX is function 1:
    NRF_PSEL(UART_TX, 2, 8) -> 0x00000048
    NRF_PSEL(UART_RX, 2, 7) -> 0x01000047
    5. fix
    Same overlay, but with the pins changed to the only valid P2 pair:
    psels = <NRF_PSEL(UART_TX, 2, 8)>;   /* TX = P2.08 */
    psels = <NRF_PSEL(UART_RX, 2, 7)>;   /* RX = P2.07 */
    Plus constant latency.
    On NCS 3.3.x — prj.conf only, no code:
    CONFIG_SOC_NRF_FORCE_CONSTLAT=y
    zephyr/soc/nordic/common/nrf_constlat.c requests it for you at SYS_INIT(PRE_KERNEL_1).
    On NCS 3.0.0 — SOC_NRF_FORCE_CONSTLAT doesn't exist yet, so request it yourself:
    CONFIG_NRF_SYS_EVENT=y
    #include <nrf_sys_event.h>
    nrf_sys_event_request_global_constlat();
    thanks and regards
    Nishant
    Looking at your overlay file I can see, You have used invalid pins for UARTE21. According to pin mapping documentation (QFN40 (QDAA) package pin assignments • nRF54L15 | nRF54L10 | nRF54L05 Datasheet • Technical Documentation), Pin P2.02 and pin P2.00 is dedicated for UARTE00/20. UARTE20/21 can use any pin on P1 ( If the specific pin numbers are not conflicting with other peripherals.)
    You have to enable constant latency mood to use the pin from cross domain.
    You need to add the following config in the prj.conf file
    and have to add the following code in the main.c file ([nrf fromlist] drivers: serial: nrfx_uarte: enable cross domain pins … · nrfconnect/sdk-zephyr@20db3ee · GitHub)
        /* remaining code*/
        /* optionally release when done */
        nrf_sys_event_release_global_constlat();
    Thanks.
    BR
    Kazi
  •    Thanks for the responses and info.
    I tried using the pins on Port1 today, and for some reason, this time it worked.  I tried port 1 last night  and it wasn't receiving any bytes. Today, it's working.  I'm not sure what's different today.
    Would the constant latency flag only affect receiving bytes?  I was having issues last night getting the UART to receive bytes on P2.07, while it was fine transmitting bytes on P2.08.
    Also, I'm using NCS v3.4.0 and if I only use the CONFIG_SOC_NRF_FORCE_CONSTLAT=y flag, it gives an error of "CONFIG_SOC_NRF_FORCE_CONSTLAT was assigned the value y, but got the value n. Missing dependencies: NRF_SYS_EVENT".  Is this expected?
    ''"CONFIG_SOC_NRF_FORCE_CONSTLAT was assigned the value y, but got the value n. Missing dependencies: NRF_SYS_EVENT".  Is this expected?''
    The error is expected. CONFIG_SOC_NRF_FORCE_CONSTLAT  is directly depended on the CONFIG_NRF_SYS_EVENT. You can try to set both configs
    ''  I was having issues last night getting the UART to receive bytes on P2.07, while it was fine transmitting bytes''
     P2.07 is shared with LED 2 / Trace by default, Maybe that could be an issue. You can try to which can cause reception issues if the LED is enabled or the pin is contended. You can disable this by board configurator app and also by device tree overlay.
    (+) HCI over UART: UART00 Communication Fails on Port 2 - Nordic Q&A - Nordic DevZone - Nordic DevZone
    &led2 {
        status = "disabled";
