nRF9151 DECT NR+ PHY: dect rssi_scan reads a CW tone ~40 dB below the conducted input level
Setup
  • Two nRF9151 SMA DKs (LACA A1), SDK v3.4.1.
  • Board B: mfw-nr+-phy_nrf91x1_2.0.0, running the DECT NR+ PHY Shell sample (samples/dect/dect_phy/dect_shell, unmodified).
  • Board A: LTE mfw_nrf91x1_2.0.4, used only as a CW source via AT%XRFTEST TX test, band 25, around 1890.4 MHz (inside NR+ band 1, channel 1667).
  • Conducted path: A port → 3 dB → 10 dB or 30 dB → 3 dB → B port, plus short cables.
  • Every attenuator and cable was checked individually with a tracking generator and spectrum analyzer (each within 1.5 dB of nominal).
  • Board A’s CW output, measured on the spectrum analyzer through the same pads: −9.1 dBm at a −10 dBm setting.
  • Board B’s NR+ TX output (dect rf_tool -m tx, measured as channel power on the analyzer): within ~2 dB of its setting.
Measurement: dect rssi_scan -c 1667 -t 1000 on board B.
CW level at B’s port (dBm) RSSI highest / lowest (dBm)
~−75 −104 / −109 (noise floor)
~−65 −101 / −106
~−55 −95 / −96
~−45 −86
~−25 −66
What we’ve ruled out
  • Linearity and repeatability: the reading tracks the input 1 dB per dB over about 40 dB. Swapping the 30 dB pad for 10 dB moved every reading by exactly 20 dB. It repeats within ±1 dB.
  • Tone position: placing the tone anywhere from −432 to +368 kHz from the channel centre makes no difference.
  • Leakage and saturation: opening the link gives noise only, and no saturations are reported.
Questions
  1. How is the RSSI in dect rssi_scan defined? Is it total power in the 1.728 MHz channel, per subcarrier, or something else? Is it referenced to the antenna port?
  2. Is a ~40 dB under-read expected for a narrowband (CW) signal? Does a real NR+ (OFDM) signal read correctly?
  3. Does the expected-RSSI / RX gain setting affect the reported value?
  • PS: After significant extra measurements, we have a sharper view of the situation:
    The offset depends on frequency. Band 4 reads correctly; band 1 is ~40 dB low.
    I repeated the test on NR+ band 4. Same two DKs, board B unchanged except dect sett -b 4 followed by deactivate/activate. Board A sent a CW tone at 912.4 MHz (LTE band 8 TX test), and B ran dect rssi_scan -c 535 (912.384 MHz). The path was 3 dB + 10 dB + 3 dB plus cable, about 16.5 dB.
    CW level at B’s port rssi_scan result
    ~−55.5 dBm −56 / −57 dBm (correct within ~1 dB)
    ~−45.5 dBm and above saturated (high −127, low +1, saturation counts reported)
    Summary across both tests
    • Band 4 (912 MHz): the CW reading is correct. Saturation starts somewhere between −55 and −45 dBm at the port.
    • Band 1 (1890 MHz): the CW reading is ~40 dB low. There is no saturation even at about −25 dBm at the port, so the signal appears genuinely ~40 dB weaker inside the receiver, not just reported low.
    • Board B’s transmit at 1890 MHz (dect rf_tool -m tx, measured on a spectrum analyzer) is within ~2 dB of its setting, so the shared SMA path and the transmitter are fine.
    • The tone position within the channel makes no difference at 1890 MHz.
    So the problem appears to be receive-only, at 1.9 GHz, on an nRF9151 SMA DK with mfw-nr+-phy_nrf91x1_2.0.0 and the unmodified PHY Shell sample (SDK v3.4.1).
    Questions
    1. Is there a known receive-path or front-end configuration issue for band 1 on the nRF9151 SMA DK with the NR+ PHY firmware? For example, MAGPIO or antenna-switch setup. The sample sets CONFIG_MODEM_ANTENNA_AT_COEX0="" because the NR+ firmware doesn’t support it. Could the DK’s RF switch be left in the wrong state for 1.9 GHz receive?
    2. Is band 1 RSSI expected to need a calibration or RX-gain setting that band 4 doesn’t?
    It is very strange...
    Just to confirm, your setup consists of 2x nRF9151 SMA DK connected directly together via a coax cable? Is there anything more in between? Is it performed in a radio chamber?
    Does it also happen if you swap the firmware on the DevKits ?
    What RSSI do you measure if you send a real NR+ signal with dect rf_tool -m tx ?
    Simon
  • Both boards are in separate JRE test enclosures rated for roughly 100dB shielding.  The RF ports on both boards have a "permanent" 3dB attenuator to protect the boards, then a cable between the enclosures with variable attenuator up to about 200dB, so that I can simulate any path loss. Later I will add deliberate reflections in that cable for multipath.
    "swap the firmware"?  I am loading my own code at the start of each test. We are trying to get to a controlled repeatable dev environment.
    I have not tried the NR+ signal as only one of my boards have the DECT software.  I use a SignalHound TG44A to generate test signals.
    By swapping the firmware I meant running the DECT NR+ modem firmware + app on the other DK to be sure that there is no issue with the DK hardware (or that at least the behavior is constant).
    I assume you already have the DECT NR+ modem firmware, and you can find the LTE and PTI modem firmware here.
    Can you please try it? This is to see if the RSSI is looking for an actual DECT NR+ signal.
    I'll try to replicate some of the tests on my side, but I don't have all the needed RF equipment to do it, so it would be better if you try it too.
    Simon
  • Thanks Simon. Following your suggestion, I loaded mfw-nr+-phy_nrf91x1_2.0.0 on two nRF9151 SMA DKs (NCS v3.4.1) and ran the PHY hello_dect sample on band 4, carrier 538, at +19 dBm, conducted DK to DK through about 99 dB of attenuation. Both directions: 100% frames received, RSSI −80 dBm, matched within 0.5 dB.
    One note for anyone else doing conducted tests with that sample: it sets rssi_level = -60 in the RX parameters. With the signal at −80 to −100 dBm nothing was received at all until I changed it to 0 (fast AGC). It might be worth a comment in the sample, or defaulting it to 0.
