[NRF51822CEAA][CUSTOM BOARD]- Help in debugging custom board
I have made a custom board using NRF51822CEAA, following the reference design. Some modules are working properly. But I'm facing following issues on some boards.
  1. When I connect the debugger from PCA10028 to program the board and use Jlink to connect, PCA10028 disconnects from PC and then reconnects. This way I'm unable to program some boards. I have checked the connections and everything is fine as the same setup works for some other boards. The error message shown while trying to connect is :
    ****** Error: Communication timed out: Requested 20 bytes, received 0 bytes ! Could not read hardware status! Can not connect to target.
  2. On some boards, I'm able to program everything but the device isn't advertising. However I'm able to use debugger and RTT is also printing. So my guess is application is running at least. Also the same program is working for the boards that are working properly.
Please help in debugging these issue.
Regards
Lalit Kumar
EDIT: I'm attaching the schematic as layout and layout as gerber files as well as EAGLE Files. the module is very small, so a good picture of it is difficult. If it is absolutely required, I'll try something. transmitter_side_sch.pdf
transmitter_side_gerber.zip
transmitter_side_eagle.zip
EDIT:
If by setup you mean the PCB, here is an image of the same. Sorry can't do better than that. If you mean connections, then I'm following the this guide.
transmitter
