Advertising won't start when using Pstorage
Before starting advertising using advertising_start() function, if pstorage function is used to write data, then it gets stuck at that point as no pstorage handler callback is received and BLE advertising mode never starts. The code is similar to what is mentioned on this thread. devzone.nordicsemi.com/.../
Please let me know the reason why this is happening. I am using S130 and SDK 11.
    Issuing a softdevice flash operation should always lead to a system event that tells the application whether the operation succeeded or not. This " system" event is reported to the registered system event handler (softdevice_sys_evt_handler_set()), which should forward it to the pstorage_sys_event_handler(), and then forward it to the pstorage callback you have declared.
    One possible reasons for it the event to not be reported is if the pstorage_sys_event_handler() is not called upon system events. E.g., forgetting to add pstorage_sys_event_handler() here:
    static void sys_evt_dispatch(uint32_t sys_evt)
        pstorage_sys_event_handler(sys_evt);
    Another possibility is that if you are using a blocking function like 'while(pstorage_wait_flag)' from an interrupt context. That would stop any new system events from being serviced (flash events has the lowest interrupt priority). In other words, the event will never get through in such case.
  • Thanks for the answer. Yes I have added pstorage_sys_event_handler(sys_evt). Secondly if I use the while loop, the callback never gets called while without the while loop, callback gets called. Any reason for that
  • Your while loop is running from an interrupt context and therefore blocking any new system events from being reported. That is why you are not getting the callback. I'd suggest to just remove the while loop from your code, and instead handle error any conditions from the callback, etc.
  • Okay thanx. Also the Load callback is not showing the correct data which is being stored. What could be the reason for that.
  • A flash operation gets scheduled in-between radio events When using the SD flash API . So when pstorage store returns success it only means that the task was successfully added to the scheduler queue. It is first when the application has been notified of the "store success" through the pstorage callback that you can expect the data to be valid.
