Hi.
I've searched this forum and also the code for pin muxings. One of post here said that any gpio can be configured for any output. However how is this done in code? And how the p0.20 names map to names used in the config?
Currently we are trying to configure SPI 0 to for following lines:
Pin# Pin_name Signal_name
23 P0.20 RST (reset)
27 P0.22 CS (chip select)
28 P0.23 DATA (MOSI)
37 P0.27 CLK (Clock)
In code I can see config like this:
#define SSD1306_CONFIG_VDD_PIN 2
#define SSD1306_CONFIG_CLK_PIN 23
#define SSD1306_CONFIG_MOSI_PIN 24
#define SSD1306_CONFIG_CS_PIN 22
#define SSD1306_CONFIG_DC_PIN 20
#define SSD1306_CONFIG_RST_PIN 19
Does the above SSD1306_CONFIG_CLK_PIN 23 map to pin numbers here (on the die outlines): infocenter.nordicsemi.com/.../pin.html
