max no. of devices for ios 7
Sorry, it looks like a ios question. We found that when connected ~10 or more 51822 devices, the iOS BLE will malfunction. We can no longer connect new device to the iOS. We have to reset the iOS settings and connect again. Are there any information Nordic could share about the max connections on iOS? We found the malfunction problem even we choose forget this device from bluetooth menu for all devices.
Paul
  • Hi Paul,
    This depend very much on your interval settings and data throughput, but 10 seems to be a reasonable number: lists.apple.com/.../msg00093.html
    Best regards Håkon
  • Is there any good way of making a calculation on the number of devices that you can support with respect to their connection intervals and notifications - under perfect radio conditions.
    I'd like to figure this out, as I might have more than 100 sensors within a radius of 50 meters, and they will all have a connection interval of probably 50ms. If this is a problem I might need to go for a solution with dynamic connection intervals and variable sampling rates. But if we say that only reach 10 meters in open air, the maximum number of devices within a 10 meter radius will probably be around 25.
  • The 100 sensors are running on several master devices - not the same...
  • As the person from Apple said, this is something that you will have to test. AFAIK; there is no direct formula for calculating how many devices you can have connected at the same time, w/given timing intervals.
    If you use our S120 stack, it's limited at 8 links.
  • Hi Hakon,
    Thanks for your reply.
    My problem on iOS is that even I forget all previous connected device in iOS bluetooth settings. I can't connect any more devices through my app. I have to reset choose "Erase All Content and Settings" in order to connect the next device. It looks like a bug in iOS. Have you heard similar problem from other customers?
    Paul
