We are using the NRF board to act as node. Samsung Galaxy S6 device is being used as the Router. We are trying to ping the node using ping6 command. The issue is that the ping6 command does not show reply back echo packet.
ping6 shows echo back only for local unicast address.
The following commands are used as mentioned here: infocenter.nordicsemi.com/index.jsp
Specifications of Board: Board: nRFgo MotherBoard Firmware is 7000. New firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 15 2016 18:03:17 Current firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Apr 23 2015 19:13:52 Segger 681532782 nRF51 Development board - 681532782
The info center also mentions that "The device will only send an echo response message if the application supports it (for example, when using Nordic's stack)."
We wish to know the following:
- The application mentioned above is the application required on Nordic board side?
- Is there a sample application available from Nordic, which sends the echo response for multicast ping6?
