run spi master example, how to know the data is received
Hi there, this problem may extend the scope, as it relates the SPI slave device (atmel winc1500). When I run the SPI master example, I can see the data transmitted on oscilloscope, but I don't know whether the data is received or not. According to the datasheet, the SPI slave should send back an ACK after the transmission, is this the direction I should go? i.e. measure the voltage of the corresponding pin?
thanks!
