nrf52 PCA10040 Qdec QDEC_SAMPLEPER_SAMPLEPER_256us not working
While trying to implement a simple qdec demo application, I find that QDEC_SAMPLEPER_SAMPLEPER_512us above works ok, yet QDEC_SAMPLEPER_SAMPLEPER_256us does not work at all - qdec_event_handler is not called not even once.
Any suggestions?
I am based on the qdec example, only connected to an Arduino board for psela and pselb signal generation, instead of the software qenc simulation.
#define NRF_DRV_QDEC_DEFAULT_CONFIG                     \
        .reportper          = QDEC_CONFIG_REPORTPER,    \
        .sampleper          = QDEC_CONFIG_SAMPLEPER,    \
        .psela              = QDEC_CONFIG_PIO_A,        \
        .pselb              = QDEC_CONFIG_PIO_B,        \
        .pselled            = QDEC_CONFIG_PIO_LED,      \
        .ledpre             = QDEC_CONFIG_LEDPRE,       \
        .ledpol             = QDEC_CONFIG_LEDPOL,       \
        .interrupt_priority = QDEC_CONFIG_IRQ_PRIORITY, \
        .dbfen              = QDEC_CONFIG_DBFEN,        \
        .sample_inten       = QDEC_CONFIG_SAMPLE_INTEN  \
static void qdec_event_handler(nrf_drv_qdec_event_t event)
		nrf_drv_timer_disable(&TIMER_QDEC);
		if (event.type == NRF_QDEC_EVENT_REPORTRDY)
	m_accdblread = event.data.report.accdbl;
        m_accread = event.data.report.acc;
		nrf_drv_timer_enable(&TIMER_QDEC);
void timer_qencOFF_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch(event_type)
        case NRF_TIMER_EVENT_COMPARE0:
            //Do nothing.
	m_iteration	= 0;
    uint32_t err_code;
    bool forever = true;
    // Initialize UART
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_ENABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_error_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    // Initialize hardware
    err_code = nrf_drv_qdec_init(NULL, qdec_event_handler);
    printf("\nQDEC testing started\n");
		uint32_t time_ms = 555; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    //Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
    err_code = nrf_drv_timer_init(&TIMER_QDEC, NULL, timer_qencOFF_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_QDEC, time_ms);
    nrf_drv_timer_extended_compare(
         &TIMER_QDEC, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    while (forever)
			nrf_drv_qdec_enable();               // start burst sampling clock, clock will be stopped by REPORTRDY event
			while (! m_report_ready_flag)                         // wait for a report
          __WFE();
			m_report_ready_flag = false;
    return -1;                                // this should never happen
